Old 08-08-2014, 12:22 PM   #1
2014 Interstate Ext. Coach
Miami Beach , Florida
Battery Disconnect Switch Issue
The battery disconnect switch on our 2014 Interstate will not switch off. Whether you flick the switch up or down, the red light stays on...until it drains the battery when the RV is idle. Any ideas on a quick fix for a not-so-handy person like me? Thanks in advance for your time.
ATE123 is offline   Reply With Quote
Old 08-08-2014, 12:31 PM   #2
2011 25' FB Flying Cloud
Anywhere & , Everywhere
The light stays on in either switch position when you're hooked to shore power. When not connected to shore power the light should go off when the switch is turned to off.
Al - K4GLU is offline   Reply With Quote
Old 08-08-2014, 12:34 PM   #3
clancy_boy's Avatar
2003 22' International CCD
Kiln , Mississippi
Images: 8
Buy a manual disconnect switch that mounts on the battery terminal. It will be a positive mechanical disconnect. Get a battery trickle charger while in storage.
Michael & Tina with Layla and Preston BZ
The family has grown.
2003 22' INTERNATIONAL CCD
Old 08-08-2014, 12:37 PM   #4
Yep- I am not hooked up to shore power. Just driving around the country...and it won't turn off. Was hoping there was a quick fix that could avoid a trip to the shop.
Old 08-08-2014, 12:39 PM   #5
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Yours is a 2014, so that means you're using the remote switch, right? There should still be a big red manual switch on the curb side inside the hatch under the sofa next to the fuse panel. Use that one until you can get the remote one fixed.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 08-08-2014, 07:54 PM   #6
Right as usual, Protagonist. Thanks!
Old 08-10-2014, 05:32 AM   #7
One more question- with the battery disconnect switch not working by sliding door and using the manual red switch under couch, does it matter how far I turn it and/or whether or not I turn it on/off a couple times a day? Also, does the engine need to be when I turn the switch? Thanks.
Old 08-10-2014, 06:38 AM   #8
You can't turn it any farther than it will go. It should be about a quarter turn from on to off.
I'd turn it on and off with the engine off, mostly for the protection of your Battery Isolation Module (BIM) which is a relay that connects your house and chassis electrical system so that your alternator can charge both sets of batteries at once.
WBCCI #1105
TAC LA-4
Old 08-10-2014, 06:50 AM   #9
Copy that. Thanks again.
Old 10-24-2014, 01:53 PM   #10
scottsdale , Arizona
Mine is doing the same thing! (I posted in another thread too). Did you ever get this fixed? Thanks
e93pvaz is offline   Reply With Quote
Old 10-26-2014, 08:53 AM   #11
Trying to Retire
MILATV's Avatar
Decatur , Illinois
When I replaced my batteries I had problems getting things to work again. Cut off switch didn't work; 30amp service wouldn't switch over, scared me.
Not sure what sequence was that made it all work but Started the vehicle and let it run for3-5 minutes, then started the generator for 2-3 minutes, then when I shut the generator off the 30 AMP came on and all the switches started working fine.
Might just try that - maybe it does a reboot on some switch or something; not sure. But I can't count the number of times I've fixed employees computers by having them turn it off and on again!.
Mike
If you work until you have everything you 'WANT' - it will probably be too late to enjoy it.
Live in the Moment and enjoy today.
MILATV is offline   Reply With Quote
Old 04-25-2017, 08:14 PM   #12
2008 23' Safari SE
San Luis Obispo , California
My 2008 Safari batter disconnect switch is stuck off. No little red light even when connected to shore power. No lights will come on etc. what can I do?
CEGorton is offline   Reply With Quote
Old 04-25-2017, 08:56 PM   #13
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
I believe that on some versions there are two fuses, one on each side of the solenoid. Check those fuses if yours has them.
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Old 04-25-2017, 09:05 PM   #14
2008 23' Safari SE
I checked both green fuses and wires look connected. Still no power but solar system should have kept batteries going whether or not on store or use. Still think it is stuck in store position. No red light either way. Need to take it somewhere tomorrow and am freaking out.
Battery Disconnect Switch Not Working Toronto_Guy Batteries, Univolts, Converters & Inverters 9 04-13-2015 05:39 PM
Battery Disconnect Switch Question MaryD Batteries, Univolts, Converters & Inverters 4 07-13-2013 08:19 AM
Battery Disconnect Switch nsbcpa Batteries, Univolts, Converters & Inverters 5 08-10-2012 05:11 PM
Battery Disconnect Switch, Solar & AGMs SilverGate Batteries, Univolts, Converters & Inverters 29 11-03-2010 10:52 AM
Solar and the Disconnect Switch/Charging/Phantom Loads Xray Generators & Solar Power 9 01-23-2005 11:55 AM
