Old 11-08-2015, 10:15 PM   #1
2015 Interstate Ext. Coach
Chicago , Illinois
Battery disconnect not working
I had new solar and charger / controller installed Friday. Took our van camping and plugged in most of the weekend. When out and about, did not hit the battery disconnect, because I had enough charge and didn't worry about it.
However, when pulling out of camp today, I hit the disconnect and turned everything off, as I normally do, in anticipation of storing on a lot tomorrow am and for the next few weeks.
When I stopped this evening, the fridge was on; I tried the lights and they worked; basically , everything worked, even with battery disconnect hit. In summary, our disconnect switch now does not disconnect anything.
Any guesses whether this is a switch fail (can that happen?) or is it possible our solar installer inadvertently bypassed the disconnect (can that happen?) when he was hooking up the new charger/ controller?
Appreciate any informed opinions.
Mark
Marks71 is offline   Reply With Quote
Old 11-09-2015, 04:20 AM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
The solar panels need to be connected to the batteries, so they can be charged. Depending on the type of system, they may need to have bypassed the cutoff switch in order to wire the solar panels.
Old 11-09-2015, 07:10 AM   #3
Boxster1971's Avatar
2013 Interstate Coach
Fulton , Maryland
Mark - I assume your 2015 Interstate has a remote switch for the disconnect near the sliding door. Have you checked the actual switch to see if it is turning off via the remote switch? It should be located under the lounge seat.
- - Mike
2013 Lounge EXT on 2012 Sprinter
- - Mike
Old 11-09-2015, 07:32 AM   #4
Chicago , Illinois
No I haven't. I"ve always just relied on the remote. I"ll check the actual switch today when I get back to the vehicle. I should have thought about that, but it was late last night and I was just trying to figure it out. Thanks
So what will the outcome(s) mean? ...if the actual switch turns off, does that mean it's a switch fail by the remote? Or could the solar install have somehow bypassed the remote?
Old 11-09-2015, 08:02 AM   #5
lewster's Avatar
Naples, FL , Hood River, OR
All of my solar installations bypass the disconnect, as the charging output from the solar controller should be fed directly into the batteries. I also include separate disconnects that will isolate the array and solar charge line if desired.
This should not effect the OEM disconnect switch. If you still have DC power to your fuse block, then the solar installer must have bypassed the disconnect.
I would have the system re-checked for proper wiring thru the disconnect.
Lew Farber
AM Solar Certified Installation Center
Lifeline Batteries**Magnum Inverters
541-490-6357
Old 11-09-2015, 08:26 AM   #6
Chicago , Illinois
Lew Farber
541-490-6357
Lew, thanks. I'm still a little unclear. so base case, solar should be wired directly to batteries for obvious reasons. Should NOT affect the disconnect. This disconnect switch has always worked until now. Could it simply be a fuse?
Or Is there any way the solar install could have affected the remote disconnect? (e.g. it must be wired somehow to interrupt power from batteries to the coach .. maybe a wire was snipped, or shaken loose, or something during install of the solar charger-controller?)
What do you think?
Old 11-09-2015, 09:42 AM   #7
lewster's Avatar
All is possible. Not being able to look at the installation or trace the wiring makes it very difficult to determine.
If the installer you used is local, I would have them re-examine the wiring to find the problem.
Lew Farber
541-490-6357
Old 11-09-2015, 10:31 AM   #8
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
With the isolation switch in the battery disconnect position, do you still have 12v inside the coach at night? If so, I would say the switch is not doing it's job as the only 12v supply at night would be the battery.
I don't know exactly what mechanism is used to isolate the chassis battery from the house battery, but perhaps that might need looking into.
Lewster?
Past President, El Camino Real Unit WBCCI#6620
Street Rod Builder (see avatar)
Kite flier (check out links below)
http://www.youtube.com/my_videos?feature=mhee
https://www.youtube.com/watch?v=6y1_U2XQ0bI
Old 11-09-2015, 11:10 AM   #9
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
Another thought. Is it possible that the solar installer wired directly to the coach battery and to the coach side of the isolator switch to, for some reason, allow the coach to be powered by solar only with the switch in the isolate position? I would see no reason for that, but the 12v is coming either from battery or the solar if you are unplugged from shore power.
Old 11-09-2015, 12:03 PM   #10
Chicago , Illinois
Ok I started playing with the manual disconnect this am for the first time ever. (My bad). Turns out there's an "always" on, an always off, and an in between position that allows the remote to operate it. My installer inadvertently turned it back to always on after his install, rendering the remote useless. I put it back in the in between position and all is now well
I swear I can't find anything about this in the manual
Sorry to take everyone's time. Thanks for all the comments
Old 11-09-2015, 12:05 PM   #11
Raymond , Iowa
The solar should always bypass the disconnect (I think). It sounds like things might have been rewired so that the everything bypassed the disconnect. But I am not sure why that would have been done, since that has no relation to having new solar. More likely I would think is that the manual (rear) and electric (front) cut off switches are out of sync. Try manually turning the rear one to line up with what the front one says, then turn the front one, then check the back one.
Titus is offline   Reply With Quote
Old 11-09-2015, 12:29 PM   #12
2014 Interstate Ext. Coach
Isn't there a manual override on the battery switch? If the switch is manually moved to the ON position, maybe the on/off switch by the door won't work???
jim.waters is offline   Reply With Quote
Old 11-09-2015, 02:10 PM   #13
AI owner since June 2013
Lake Mary , Florida
I had a similar issue with my 2014 AI. It turned out the manual switch under the lounge was turned the wrong direction (according to the dealer tech) so that it did not rotate closed by use of the door switch. Once he showed me how it should work, I have not had an issue since then.
FlaBucki is offline   Reply With Quote
Old 11-09-2015, 03:35 PM   #14
2009 23' Flying Cloud
Egg Harbor Township , New Jersey
battery disconncect switch
I experienced the same problem where the battery disconnect switch wasn't working. So I installed a new disconnect switch from colonial airstream and it worked. Never even knew about the manual switch but now it works. Dan'l
dregan67 is offline   Reply With Quote
Battery disconnect not turning off Hammertime Sprinter and B-van Forum 10 08-26-2017 05:47 PM
To disconnect or not to disconnect urnmor Towing, Tow Vehicles & Hitches 36 02-22-2017 10:24 AM
Battery Disconnect Switch Not Working Toronto_Guy Batteries, Univolts, Converters & Inverters 9 04-13-2015 05:39 PM
Battery Disconnect not turning on... ATE123 Sprinter and B-van Forum 13 04-06-2015 07:38 PM
Help! Battery not charging, outlets not working when plugged in AirGal04 Electrical - Systems, Generators, Batteries & Solar 9 06-06-2014 09:15 PM
