Old 11-09-2015, 09:14 PM   #15
UKDUDE's Avatar
2014 Interstate Ext. Coach
Sedona , Arizona
Originally Posted by Marks71 View Post
Ok I started playing with the manual disconnect this am for the first time ever. (My bad). Turns out there's an "always" on, an always off, and an in between position that allows the remote to operate it. My installer inadvertently turned it back to always on after his install, rendering the remote useless. I put it back in the in between position and all is now well
I swear I can't find anything about this in the manual
Sorry to take everyone's time. Thanks for all the comments
The switch by the door operates the motorized disconnect at the rear under the sofa. But that motorized disconnect can be rotated manually, in which case it gets out of synch with the switch. And I think a red light on the switch indicates it's out of synch. So rotating it back usually corrects the problem!
Old 11-09-2015, 10:13 PM   #16
2015 Interstate Ext. Coach
Chicago , Illinois
I'm going to repeat because I don't think most responders are getting my point
Problem solved this am, but I haven't seen anything in a manual or any comments that correspond
*my manual switch has 3 positions: off, on, and in between. Only in the in between position does the switch work. I discovered this by playing with it, then my solar installer sent me an email with the same info. He said he mistakenly turned it back all the way to on, instead of the intermediate stop
2015 grand tour.
Marks71 is offline   Reply With Quote
Old 11-09-2015, 10:16 PM   #17
Chicago , Illinois
Sorry. My post above is poorly worded
Only in the in between position for manual disconnect knob does the remote switch work
Old 11-10-2015, 05:35 AM   #18
Montrose , Pennsylvania
Do you know where I can find this switch in my 2016 Grand Tour? I don't see anything in the manual about it either!
bsedor is offline   Reply With Quote
Old 11-10-2015, 06:31 AM   #19
lewster's Avatar
Naples, FL , Hood River, OR
Should be next to your 120VAC breaker panel. Pull the laminate cover panel from below the rear side seat on the driver's side and it will be evident.
Lew Farber
AM Solar Certified Installation Center
Lifeline Batteries**Magnum Inverters
541-490-6357
Old 11-10-2015, 01:02 PM   #20
Chicago , Illinois
Yes, the manuals are awful. I have a 2015, and it should be the same
* rear side seat on driver's side
* pull off that laminated door with the hand holds on top and bottom, right under that seat
* right next to the breaker panel is a large red knob, about the size of a gas stove burner knob
* as I said, mine has the 3 positions: off, on, and something in between, that seems to allow my remote switch at front of coach to operate. In the off or on position, the remote switch up front doesn't seem to do anything.
Good luck
Mark
Old 11-11-2015, 08:11 AM   #21
Mark,
You described the disconnect switch better than I did. I agree that when the knob is moved all the way in one direction or the other to the On or Off position, the switch by the door is disabled. The switch has to moved to the center, third, position for the switch to work. I discovered this in a similar manner when a service person put the switch in the Off position. You are correct that the manual is silent on this feature.
jim.waters is offline   Reply With Quote
Old 11-11-2015, 08:13 AM   #22
Good luck
Mark
Got it! Thanks for the insight.
Battery disconnect not turning off Hammertime Sprinter and B-van Forum 10 08-26-2017 05:47 PM
To disconnect or not to disconnect urnmor Towing, Tow Vehicles & Hitches 36 02-22-2017 10:24 AM
Battery Disconnect Switch Not Working Toronto_Guy Batteries, Univolts, Converters & Inverters 9 04-13-2015 05:39 PM
Battery Disconnect not turning on... ATE123 Sprinter and B-van Forum 13 04-06-2015 07:38 PM
Help! Battery not charging, outlets not working when plugged in AirGal04 Electrical - Systems, Generators, Batteries & Solar 9 06-06-2014 09:15 PM
