04-01-2015, 01:14 PM
2014 Interstate Ext. Coach
Miami Beach
Battery Disconnect not turning on...
I apologize in advance if I have posted about this before, but the battery disconnect on my 2014 Airstream Interstate will not turn on...which means I can't turn the generator on...and I'm not near shore power. (The vehicle is idle in my driveway.) The dealership told me to leave the vehicle is in the sun, which it is, and the solar panels should give the battery enough juice to flick back on so I can run the generator...but that is not working. Is there a quick step-by-step fix someone can offer for a dummy (me)?
Thanks in advance to anyone that responds!
04-01-2015, 02:25 PM
BikerBill
Poconos of Pa
, Pennsylvania
Did you try turing the switch back under the couch manually? The electric switch on the sliding door area controls the motorized rotating switch for the battery, as I seem to remember on my traded-away 2014/13 AI.
And yes, you may need some time to charge up the battery via the solar panel. And make sure you have all appliances that could draw power from the battery also turned off while you are trying to charge the battery, including the TV amplifier in the overhead cabinet.
04-01-2015, 03:54 PM
Sedona
If the coach batteries are flat, then the motorized disconnect switch cannot function.
To get the generator running, try this:
Start the chassis (Mercedes) engine and let it run for 5 minutes. Keeping the engine running, see if the disconnect switch will then turn on correctly. Then switch on the propane gas solenoid in the box behind the right rear wheel. Then from inside attempt to start the propane generator. If that starts up, you can switch off the chassis engine, and allow the generator to continue charging up the batteries.
04-01-2015, 04:42 PM
2011 Interstate Coach
Overland Park
, Kansas
The batteries can be fully charged but if the manual/motorized disconnect switch is in the OFF position, the generator can't be started and the propane can't be turned on. At least that's how mine works.
04-01-2015, 08:38 PM
2015 Interstate Ext. Coach
San Diego
^^^ This is what I would try ^^^
04-02-2015, 07:31 AM
Naples, FL
, Hood River, OR
If the engine is running and the house batteries are low (below 80%), the BIM should link the 2 battery banks together to allow charge from the alternator into the house batteries.
The gen. start is on the house batteries, so the charging current from the alternator should suffice to start the gen.
Lew Farber
AM Solar Certified Installation Center
Lifeline Batteries**Magnum Inverters
541-490-6357
04-02-2015, 12:49 PM
Winemaker
2012 28' Flying Cloud
Avila Beach
I had a similar problem on my 2012 28ft FC last year. The solenoid/contactor would not latch or disconnect even with full charge on the batteries. I replaced the solenoid myself for $65 and all is perfect now. Even when the trailer was new it was a little sticky so...I suspect it was bad from the get go.
04-02-2015, 04:24 PM
Miami Beach
Thanks for everyone's advice.
Now the battery disconnect is on, but the generator won't turn on. The propane is on, but the generator won't work. Any ideas?
04-02-2015, 04:34 PM
Naples, FL
, Hood River, OR
Can you measure the voltage of the house batteries?
04-02-2015, 05:11 PM
Sedona
Need to be a little more specific here for us to understand this:
1) What did you do to get the battery disconnect on? Did you start the chassis engine and let it run, and then it turned on from the door switch?
2) Does the generator turn over with its own starter button?
3) Have you confirmed there is propane available by lighting any of the burners?
4) Do the interior lights come on when the battery disconnect is on?
Your dealer ought to have gone over these things with you when you bought it, and hopefully you had established a friendly relationship with him; you may need to use him to get this going.
04-02-2015, 07:03 PM
Overland Park
, Kansas
Are there any red flashes on the starter switch? IIRC, there is a manual push button to start the generator on the generator itself. You will need to check the Onan manual to verify this and its location.
04-06-2015, 10:21 AM
Miami Beach
YES to #1, #3 and #4. No to #2. I have a call into the manager at my dealership to try other options, but I should not have to manually start the generator by sliding under the vehicle when this happens.
04-06-2015, 02:51 PM
Sedona
The Onan Manual indicates a 5 amp fuse located on the generator itself to protect the control and remote control circuits. Perhaps that needs replacing. The remote control circuit would be the generator start/stop switch inside the display panel.
Didn't you have similar issues last year? Perhaps the same fuse keeps blowing.
04-06-2015, 08:38 PM
Miami Beach
I did have the same issue last year- you're good! But, I brought it to the dealer...they dealt with it...and I never learned (or remembered) the cause/solution. I'll mention your idea to the dealer tomorrow. Thanks!
