Old 11-17-2015, 08:27 PM   #1
Glamper1's Avatar
Battery Disconnect
Howdy
What causes the battery disconnect to blink when in the off position?
Glamper1 is offline   Reply With Quote
Old 11-18-2015, 09:00 PM   #2
UKDUDE's Avatar
2014 Interstate Ext. Coach
Sedona , Arizona
If it's continually blinking, it means the switch by the door is out of synch with the motorized battery disconnect knob at the rear. Try rotating the knob to the middle of its travel and then flick the switch by the door. The blinking should stop when the motorized disconnect is in the off (disconnected) position.
To disconnect or not to disconnect urnmor Towing, Tow Vehicles & Hitches 36 02-22-2017 10:24 AM
Battery Disconnect Switch, Solar & AGMs SilverGate Batteries, Univolts, Converters & Inverters 29 11-03-2010 10:52 AM
Car Battery Low Disconnect in '68 crair Batteries, Univolts, Converters & Inverters 3 06-13-2006 05:29 PM
Battery Disconnect Light FiveGreers Electrical - Systems, Generators, Batteries & Solar 2 04-03-2006 08:01 AM
