Old 10-12-2015, 08:32 AM   #1
Boxster1971's Avatar
2013 Interstate Coach
Fulton , Maryland
Battery and Inverter Upgrade
Starting a new thread on my battery and inverter upgrade to post incremental progress rather than telling the story when I'm done. There is just enough room under the Sprinter XL of my Interstate to install two Lifeline GPL-4CT AGM batteries on each side. This is the same area that Airstream now installs the batteries on all new Interstates. I'll have 440 AH of capacity with four 6 volt batteries in series-parallel arrangement. My goal is to use the microwave when camping without hook-ups. A battery and inverter upgrade was always part of my long term plan when adding 400 watts of solar. I looked at using large lithium batteries but concluded that I'd have to add even more stuff to make a lithium upgrade work. I didn't want to give up any internal storage space so putting the batteries under the van seemed the best place. I'll remove the original battery box under the lounge seat and install the inverter in that location.
Here is a photo of a battery rack on the floor of my shop.
Name:	ImageUploadedByAirstream Forums1444658989.549089.jpg
A view of a rack installed without batteries during one of my many fit checks. The clearances in this void under the van are less than 1 inch on either end.
Name:	ImageUploadedByAirstream Forums1444659192.828444.jpg
I have to use a small floor jack to install the batteries as seen in this photo.
Name:	ImageUploadedByAirstream Forums1444659386.719014.jpg
I did a road test yesterday with batteries installed and it works as planned. Photos of both racks with batteries installed.
Name:	ImageUploadedByAirstream Forums1444659429.226631.jpg
Name:	ImageUploadedByAirstream Forums1444659459.965078.jpg
That last photo also shows a new junction box I added to relocate wiring from the generator, which needed to be moved to make room for batteries on the driver side.
I'll post progress as I move forward. I removed the racks after the road test and will now paint everything before the final installation.
- - Mike
2013 Lounge EXT on 2012 Sprinter
- - Mike
Old 10-12-2015, 01:25 PM   #2
Ron_CA's Avatar
2015 Interstate Ext. Coach
San Diego , California
Make mine Orville Redenbacher please
While I commend you on your efforts, Man that is a lot of work. Results should be worth it though.
Ron_CA is offline   Reply With Quote
Old 10-12-2015, 01:35 PM   #3
73shark's Avatar
2011 Interstate Coach
Overland Park , Kansas
Looking good. Where did you move the generator? Or just shift a little?
Old 10-12-2015, 04:10 PM   #4
Fulton , Maryland
Yes - it has turned out to be more difficult then I thought when I started. Fortunately working on my Interstate is part of my a hobby to fix things. This last spring I installed 500 sq.ft. of solid oak floor on the bedroom level of our town house. That was even more work.
- - Mike
- - Mike
Old 10-12-2015, 04:14 PM   #5
Fulton , Maryland
I just have to relocate the 120V AC wires from the generator. Also have to reroute the generator control cable. They run right though the area I'm installing the new batteries. Generator staying in the same spot.
- - Mike
- - Mike
Old 10-12-2015, 06:08 PM   #6
Depere , Wisconsin
you are amazing
summerwood is offline   Reply With Quote
Old 10-12-2015, 07:00 PM   #7
Rockwell , North Carolina
Good job!
jerhofer is offline   Reply With Quote
Inverter Upgrade 1986 345 Docseuss Classic Motorhomes 8 07-19-2015 07:48 PM
Parallel non inverter generator with inverter generator? mtbguy Generators & Solar Power 3 07-15-2015 01:48 PM
Converter,battery and solar upgrade SilverSinbad Batteries, Univolts, Converters & Inverters 2 01-19-2015 10:57 AM
Inverter Use and Battery Level TouringDan Batteries, Univolts, Converters & Inverters 28 05-13-2010 09:09 PM
Battery and Univolt upgrade report - 1981 280 MoHo outofcontrol Batteries, Univolts, Converters & Inverters 5 03-22-2009 06:29 AM
