Old 07-25-2015, 01:23 PM   #1
Bathroom Floor Drain
We have an Interstate 2014.5 for almost a year. We haven't tried showering in it yet but I did use the sink nozzle to wash the floor there by discovering that the floor drain fills to the top and does not drain any further. Does anybody else have experience with this issue or suggestions as to what it might be?I appreciate your help.
camlivy is offline   Reply With Quote
Old 07-25-2015, 01:50 PM   #2
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
First rule of troubleshooting, check the easy things first. So, easiest thing, is your gray tank full?
For information only— there are no P-traps in an Interstate, instead there are check valves in each drain (except the toilet) that prevent water from backing up. They're called Hepvo valves— that's a brand name. (Hepvo Waterless Valve) But they have one quirk. If the Hepvo valve is open to drain water when the gray tank reaches the point of overflowing, the weight of the water above the valve holds the valve open. So unlike the Airstream trailers with P-traps, if you were to fill the gray tank to overflowing while running the galley sink, the galley sink would back up but the shower wouldn't.
So in your case it's possible that you just happened to fill the gray tank to overflowing as you were washing down the shower.
If that's not your problem, then the next most likely thing is construction debris (excess sealant, whatever) blocking the drain. Especially since you've never used the shower before. But the Hepvo valve creates a problem there, in that you can't just fish the drain with a plumber's snake or you'll damage the valve.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 07-26-2015, 10:08 AM   #3
Thx protagonist. The gray water is not full and both sinks are draining fine. When I watch the water go down the floor drain, I see the daylight of the transparent tank until it starts backing up about 6" below the floor. We discovered this problem when AS was not level, and repeated the experiment when level. With same results. Still under warranty so I guess we can take it back in.
Re working kitchen drain- pex for drain lines?? Bwilson11 General Repair Forum 4 04-20-2014 08:42 PM
Removing drain from bathroom sink??? Ellie & Carl Sinks, Showers & Toilets 5 05-18-2010 10:10 AM
bathroom sink won't drain dhe9 Plumbing - Systems & Fixtures 3 11-11-2008 10:19 AM
'62 Bambi - Bathroom sink drain dudebb 1961 - 1963 Bambi 3 06-04-2007 07:57 PM
A/C Drain ...leaking at drain hose connection Sav'h Steve Furnaces, Heaters, Fireplaces & Air Conditioning 5 08-01-2004 04:09 PM
