Old 09-01-2015, 08:04 PM   #1
2012 Interstate Coach
Reno , Nevada
Bathroom Fan smoked - again!
Anyone else have a problem (after problem after problem) with the bathroom ventilation fan in the Interstate?
I barely had our 2012 Lounge for 3 months and it quit - dealer said a diode needed replacing in the fan/motor. A diode for a DC motor with a switch? Okay, well...so now it works again.
Died again after a couple years, but still under warranty so the whole unit was replaced by the same dealer.
Now here we are just 2 months outside the 3-yr warranty and we smell the burnt wire smell of another dead fan.
Any suggestions on where to get a replacement fan (or maybe just the motor? or diode??)?
Do I need to scrape all the goop off the roof to remove/replace it from above, or can I do the whole deed from inside the bathroom?
thanks in advance...
EddieTheWire is offline   Reply With Quote
Old 09-01-2015, 08:52 PM   #2
kennethowens's Avatar
1975 Argosy 24
Malakoff , Texas
Sounds like too much motor for the wire size
or bad ground connection at the motor location.
Low voltage...due to a current limiting cause...such
as a bad ground at the fan - will cause overheating
and failure. Look at the wire also...if insulation is slightly
melted...the motor is wanting more current(wire size &/or
source voltage) or it's a bad ground. Supply voltage
drops when the motor is turned on. If the supply voltage
drops >10% with motor running....ya may have source
issues.
Easiest thing for a dealer to do is shove a new part in the place
and write it up in warranty. Masking the source problem.
Low current flow looks & smells like overload.
May not help...but sticking a new motor into the same problem
didn't help either.
Symptom of problem is not the source of problem.
kennethowens is offline   Reply With Quote
Old 09-01-2015, 11:02 PM   #3
Figment of My Imagination
Protagonist's Avatar
My bathroom fan lasted three and a half years before going kaput during the WBCCI International Rally at Farmington. I was at happy hour at the Vintage Airstream Club tent when a sandstorm blew in, so I wasn't in the van to shut off the fan and close the vent, and the fan motor gave up the ghost after it swallowed too much airborne dust. Didn't even blow a fuse, just after the sandstorm the motor wouldn't turn anymore. Had the dealer replace it while the van was at the dealer for other work.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 10-17-2015, 03:06 PM   #4
UKDUDE's Avatar
2014 Interstate Ext. Coach
Sedona , Arizona
My bath fan has gone kaput too - after a thin sticky-backed sealing foam came unstuck and wrapped itself around the blades. Is this covered under the standard 3-year warranty? I don't have any paperwork for this in my kit of instructions and no model identification is visible.
Old 10-22-2015, 07:52 PM   #5
AtlantaCpl's Avatar
2013 Interstate Coach
Atlanta , Georgia
I found a unicorn. A service tech that not only knows Interstates back and forward but the work ethic to diagnose the real problem and address it. He works for RBM Mercedes dealer in Alpharetta Georgia which is an authorized repair facility.
Root cause - lousy workmanship at the airstream point of install. The wires for the fan run between the outside of the fan housing and the frame. Guaranteed you will find the insulation was damaged during install or vibration during trips and shorting, causing the diode or switch to burn out. 5 minutes to add electrical tape and carefully place the wires are causing hundreds of these to fail. God I hate capitalism sometimes.
Don't just fix the switch or diode, force the tech to show you how the wires are shielded from shorting against the frame or housing. In the case of mine, the damage to the insulation was very difficult to spot until the tech shined a light right on it. He predicted it was there and sure enough it was.
Brian
AtlantaCpl is offline   Reply With Quote
Old 10-26-2015, 05:01 AM   #6
Chattanooga , Tennessee
Fan kaput
Brian
We went to the same dealer (RBM of Alpharetta, GA) and our nonworking fan was diagnosed as being completely kaput--and this with our rig being just over 1 year old. And, unfortunately in our case (since our rig was a manufacturer buyback due to a lemon law and therefore no longer under warranty per Airstream), it would be a $450 repair. We declined. Not worth $450 for a fan that would be seldom used. And, it appears, may end up just failing again in the near future.
BrianKrueger is offline   Reply With Quote
Old 12-20-2015, 11:26 PM   #7
Reno , Nevada
btw, why is there a diode? DC flows one way only. Maybe they fear someone will wire the fan backwards and it will suck air INTO the bathroom instead of exhaust the air?
Old 12-20-2015, 11:42 PM   #8
Actually, yes. The 12vDC motor itself is inherently reversible, but is being used for an exhaust-only application, so standard practice is to include a diode to ensure the fan attached to the motor is used as an extractor fan only. The same motor can be used in other industries for other applications besides just extractor fans, where the diode might be replaced by a three-way switch to allow forward/off/reverse.
WBCCI #1105
TAC LA-4
Old 12-21-2015, 04:55 AM   #9
TCwheels's Avatar
2011 20' Flying Cloud
Traverse City , Michigan
This is shaded pole motor or "c" frame motor, correct? Costs between $5-$10 dollars from the manufacturer. How on earth can the repair cost $450, I wonder?
"Don't let perfect be the enemy of better."
TCwheels is offline   Reply With Quote
Old 12-21-2015, 07:43 AM   #10
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
I doubt it is shaded pole. They are AC motors. Chances are good that it is a permanent magnet DC motor. Not sure what the diode is for. Other than to protect the fan from reverse polarity. Most DC permanent magnet motors use a Hall effect switching system instead of a commutator and brushes. The diode protects the circuit board would be my guess.
Old 12-22-2015, 06:32 PM   #11
AtlantaCpl's Avatar
Atlanta , Georgia
My theory is the diode is there in case someone left the dome up while driving 70mph down the freeway. Whether the fan is on or off that could back flow current into the circuit. The inverter probably doesn't like a current coming in this fashion, and could make very unpredictable behavior or blow something out.
Brian
Old 12-22-2015, 10:40 PM   #12
2011 Interstate Coach
Muskogee , Oklahoma
If this is the same model you can buy a replacement motor from a dealer:
http://ventline.com/home
http://ventline.com/i/u/6148923/f/RV...Vent_11-11.pdf
http://www.etrailer.com/Accessories-...VD0218-00.html
or
or just simply replace the complete unit:
Amazon.com: Ventline VP-543 12V Smoke Van Roof Air Vent: Automotive
For the motor only replacement you are only out 20 bucks.
I would find a more honest dealer, buy the parts yourself, and have it replaced. Actually, I would simply replace it myself. It is not that difficult. Here is a good tutorial:
https://boldandadventurous.com/how-t...our-airstream/
2011 Interstate WD/Lounge
gmillerok1 is offline   Reply With Quote
Old 07-25-2016, 04:30 PM   #13
jgeurin's Avatar
Tulsa , Oklahoma
Well, I had the same issue come up. The diode is apparently fried. I just removed it. I plan to be careful about closing the vent on the highway, and just living without it.
jgeurin is offline   Reply With Quote
Logging In Again and Again and Again Secguru Forum Admin, News and Member Account Info 4 11-01-2010 11:15 AM
Can non-smokers be happy in smoked-in trailer/towing vehicle gardener General Interior Topics 45 04-12-2010 05:20 AM
Removing Smoked Plexiglass Window Shields Lee Davis Windows & Screens 4 09-13-2005 02:41 PM
Acrylite (Smoked, Curved & Installation) Cat Windows & Screens 4 05-23-2005 02:04 AM
