Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Sprinter and B-van Forum
Old 10-19-2016, 03:54 PM   #1
Dalwyn's Avatar
2015 Interstate Grand Tour
Southaven , Mississippi
Bathroom Fan Exhaust Leak
Has anyone had any problems with the bathroom fan exhaust leaking around the housing? Our unit will be going back into the shop on the 25th to have the leak fixed for the 3rd time. It seems that after the exhaust fan is pushed up a couple of times it will begin to leak the next time it rains. Not sure if there is a permanent fix or if there is a replacement type unit.
Dalwyn
Dalwyn is offline   Reply With Quote
Old 10-19-2016, 04:02 PM   #2
Muskogee , Oklahoma
More than likely, it has not been correctly repaired. My guess is that the bracket was screwed on using a powerdrill, and they cracked the flat housing, so when the put more sealant on it, it won't stay sealed because it moves, literally, with the wind.
To repair it correctly, you need to remove the sealant, inspect the screws and holes in the plastic and reseal it.
2011 Interstate WD/Lounge (since sold).
2020 Leisure Van WonderRTB
gmillerok1 is offline   Reply With Quote
1977 bathroom exhaust fan triciaandjeff Member Introductions 1 05-11-2016 05:05 PM
Replacement Fan Motor for Roof Exhaust Fan SaabLover Furnaces, Heaters, Fireplaces & Air Conditioning 20 01-08-2014 04:00 PM
Bathroom Light/Exhaust Fan Switch shebeen 1974 - 1977 Overlander 2 06-26-2011 12:15 PM
Bathroom Exhaust Fan for 71 Safari rrpranch Roof Vents, Skylights & Fans 12 06-26-2007 06:57 AM
bathroom exhaust fan handle replacement charlie tuna Roof Vents, Skylights & Fans 8 09-08-2006 06:40 PM
