Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Sprinter and B-van Forum
Old 12-01-2014, 08:03 PM   #1
Rockwell , North Carolina
Bathroom Expansion Panel
In my quest to reduce the squeaks and rattles, I initially placed some Velcro strips where the metal retainer for the bathroom expansion wall meets the metal plate. That made a difference but I recently noticed that the wall will still move in at the top causing some noise. There is a retention piece at the bottom but nothing at the top to keep the wall from moving inward.
To remedy that, I scrounged through my scrap metal pieces and came up with a piece that, after some modifications, keeps the expansion wall from moving inward. I removed one of the screws that mount the metal retaining plate and attached a metal piece that has a ninety degree bend that the expansion wall fits into. Again I used some pieces of Velcro to minimize the contact noise. I also installed Velcro strips on all of the drawers, the bathroom door and the wardrobe door to make everything fit tighter and to eliminate two hard surfaces from touching. It has helped but I still have some challenges.
jerhofer is offline   Reply With Quote
Old 12-01-2014, 11:30 PM   #2
73shark's Avatar
2011 Interstate Coach
Overland Park , Kansas
I stopped mine from rattling by blocking it out/extended permanently so it can't move.
2011 Interstate SOLD! Upfitted 2017 Transit 350. SOLD!
Old 12-02-2014, 05:44 AM   #3
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
On mine, the door doesn't rattle much while I'm driving; the door latch was what rattled! I reduced the rattle by the simple expedient of giving the bolt a downward twist after inserting it in the receiver hole so that the latch is jammed tight. I also don't have to worry anymore about the latch working itself loose so that the extension can swing open on its own (as happened a few times before I learned the trick).
Old 12-02-2014, 10:47 PM   #4
weirdstuff's Avatar
2018 23' International
SANTA BARBARA , CA
Not sure if it made rattling better or worse, but, we removed the side panels, so that ours stays in the closed position all the time (and toilet seat can raise, since the side panels were what got in the way of that).
We saw no point, for us, in having the panel extended out. And this way, it gives us a tiny bit more room in the aisle.
weirdstuff is offline   Reply With Quote
Bathroom Expansion Bruhar 1993 Excella 1000 2 09-07-2023 11:48 AM
segment protectors held with expansion nuts? Skooter 2005 and newer - Bambi all models 1 05-28-2014 08:05 PM
Expansion anchors instead of elevator bolts for shell on floor replacement? timzog Repairing/Replacing Floor &/or Frame 4 12-12-2011 05:43 PM
Aluminum expansion and contraction Rileybear Ribs, Skins & Rivets 16 07-05-2011 05:46 AM
Expansion and contraction of new flooring delquattro Repairing/Replacing Floor &/or Frame 2 09-11-2004 01:41 PM
