Old 10-16-2012, 09:09 AM   #1
LAFAYETTE , Colorado
Bath exhaust fan quit
2012 INTERSTATE: Bath fan quit, any ideas what to check, fuse ok.
TY PECK is offline   Reply With Quote
Old 10-16-2012, 10:32 AM   #2
wayneskid's Avatar
2010 22' Interstate
Anchorage , Alaska
This is not an unusual problem and I had the same thing happen to my 2010 Interstate. The cause was that the foam gasket that is intended to seal the vent when it is closed (pulled down) came loose and was sucked into the fan blades preventing them from turning. The fix was to remove the vent cover from the top of the van and remove the old gasket material including the pieces stuck in the fan blades and install new a new foam gasket made from household weather strip material.
- wayne
2010 Interstate 3500 Twin Bed
(2008 Freightliner CRD Sprinter)
AIR #44779
TAC AK-1 !!
wayneskid is offline   Reply With Quote
Old 10-16-2012, 11:27 PM   #3
73shark's Avatar
2011 Interstate Coach
Overland Park , Kansas
Mine quit. Dealer removed & reinstalled and it worked. I hate it when that happens cuz I know it will fail again.
Old 10-17-2012, 05:56 AM   #4
deauxrite's Avatar
2007 27' Safari FB SE
Full Timers just passing through , Arizona for a couple of weeks and then on to Utah!
If there is no obstruction to the fan blades and the fuse is ok, try jumping across the switch. I just replaced the original plastic bodied switch on mine and all is well again.
Living life on the Road
deauxrite is offline   Reply With Quote
