Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Sprinter and B-van Forum
Old 11-09-2006, 12:57 AM   #1
Profile:  Patchogue , New York
B190 inverter instead of generator?
Can you buy an inverter to give 120 volt off battery bank to operate the ac or microwave? Or is my only alternative to buy a generator? I don't plan to use it much but I don't want to invest thousands in a generator that is not used.
gingfred is offline   Reply With Quote
Old 11-09-2006, 05:56 AM   #2
peegreen's Avatar
Profile:  1998 31' Excella 1000
South Berwick , Maine
I'm sure there are inverters large enough to run those appliances. The inverter will cost you thousands not to mention the ginourmas battery bank you will need and then a generator to recharge them. Choices: If you need micro and ac, camp where there's an electric hookup, if not, do without those luxuries. The other option would be a small, quiet, portable generator.
WBCCI 24291
New England Unit
Metropolitan NY Unit
peegreen is offline   Reply With Quote
Old 11-09-2006, 08:10 PM   #3
The guy with the B-van
Skater's Avatar
Profile:  Bowie , Maryland
Send a message via ICQ to Skater Send a message via AIM to Skater Send a message via Yahoo to Skater
You can buy a converter to do what you want, but you'll have to either add batteries or run the engine while using the microwave to supply enough power. (If the engine alternator can supply enough power - I'm not sure.)
The suggestion of a small generator, such as one of those Hondas, is a good idea. They'd be useful in emergency situations at home, too. Check the amperage, though - I'm not sure how much power the microwave draws.
1991 Airstream B190 - 7.5L/460 cu in V8.
Jasper remanufactured E4OD.
Stehl Tow Dolly. Tekonsha Prodigy brake controller.
Pioneer head unit, Sirius tuner.
WBCCI #13270 - Washington, DC unit
B190 Owners: The new site B190 Enthusiasts is dedicated to the 1989-1999 Airstream B190.
Skater is offline   Reply With Quote
Generator filters 1985air345 Mechanics Corner - Engines, Transmission & More... 7 04-05-2004 09:17 AM
Onboard generator bhsl8 Generators & Solar Power 39 07-29-2003 06:31 PM
B190 Coach power problem Luckydog Sprinter and B-van Forum 21 11-12-2002 01:59 PM
Inverter problem Don McKelvay Electrical - Systems, Generators, Batteries & Solar 2 11-03-2002 06:40 AM
Generator for a Tradewind uwe Generators & Solar Power 6 08-02-2002 09:51 AM
