Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Sprinter and B-van Forum
Old 09-01-2004, 02:13 PM   #1
Profile:
B190 engine,460 vs V10
I plan to tow a 6000lb boat occasionally long distances, can I assume both engines will work just fine but the V10 will get slightly better fuel mileage with no load? Tim
dougfur is offline   Reply With Quote
Old 09-01-2004, 02:43 PM   #2
71_safari's Avatar
Profile:
Images: 12
Proably better under load as well.
1971 Safari 23
71_safari is offline   Reply With Quote
Old 09-01-2004, 08:53 PM   #3
uwe
418
uwe's Avatar
Profile:  1963 26' Overlander
1958 22' Flying Cloud
1963 19' Globetrotter
Portola Hills , California
Images: 41
A close friend just replaced his 91 Ford E350 ( 460V8) with an 04 Ford E350. (V10)
Both had the HD towing package, and the same gear ratios etc.
The V10 is hands down a much more pleasant engine than the ancient 460 V8. The 460 was an inherent oil burner, oil leaker, and fuel hog. The V10 seems to be a much more refined engine, with no problems at all so far.
His 460 had problems from day one and was replaced under warranty once, and on his dime once, and resealed several times. I drove the old van quite a bit, and found it quite underwhelming on the power side. 9-10mpg empty would be on a good day....
Uwe
www.area63productions.com
Old 09-02-2004, 09:48 AM   #4
62 Overlander's Avatar
Profile:  2005 25' International CCD
1954 25' Cruiser
Paradise , Texas
Both are extremely durable engines. The 460 is a proven industrial engine used for everything from running water pumps and generators to pushing motorhomes and boats. We still have a '95 model in a one ton shop truck pushing 300,000 on the original engine. I have an '03 V10 as a daily driver, it just turned 80,000 and so far no problems. Empty the V10 gets about 20% better fuel economy, towing is close to the same, maybe a shade better, but the powerband is broader. The later 460's were pretty detuned to meet emissions requirements.
Paul & Annie
Paul Mayeux,
President Heart of Texas Camping Unit, Region 9
WBCCI #7162
Charter Member - Heart of Texas Camping Unit
AIR #1565
62 Overlander is offline   Reply With Quote
Looking for a B190 airstream mam5221 For Sale & Wanted 4 05-24-2004 06:24 PM
Airstream B190 Alaskan Sprinter and B-van Forum 5 11-05-2003 10:32 PM
Airstream B190 For Sale Simon Martin For Sale & Wanted 0 09-19-2003 10:46 PM
V10 Vs Psd DreamStream On The Road... 6 02-09-2003 12:03 AM
B190 Coach power problem Luckydog Sprinter and B-van Forum 21 11-12-2002 01:59 PM
