Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Sprinter and B-van Forum
Old 05-05-2015, 08:38 AM   #1
1998 19' "B" Van Airstream 190
Monroe , Louisiana
B190 Bedroom lights
I can not get my bedroom lights to come on. And yes I've tried the switch on the back of the cabinet. Changed bulbs, ect. still won't come on. Help.
mike
michaelthomp is offline   Reply With Quote
Old 05-05-2015, 09:12 AM   #2
batman's Avatar
1964 22' Safari
modesto , California
Do you have a multi meter? Have you checked for a blown fuse?
batman is offline   Reply With Quote
Old 05-05-2015, 09:30 AM   #3
Lily&Me's Avatar
Normal , Illinois
Are other things working?
If not, is your battery switched to "use"?
Maggie
Old 05-07-2015, 05:39 AM   #4
Skater's Avatar
1995 30' Excella
Bowie , Maryland
I'm assuming you flipped the switch on the cabinet, then tried the switches on the lights, right? It's not a three-way setup; the switch on the cabinet controls power to the lights, so if the individual light switches are off, when you flip the one on the cabinet, nothing will happen. (I'm also assuming your battery is charged or the converter is on and working.)
In mine, that switch also controlled - for some reason - the lights over the couch. I guess it was so that if you crawled in bed then realized that you left one of those on, you had a way of turning them off without leaving bed.
Check fuses, but in my B190, there was so much on each circuit that you'd notice other things not working if that was the problem.
Beyond that: Check the bulbs, check for voltage at the light as others said. Odd that both of them would be out. Perhaps pull the switch and check the wiring there, too.
1995 Airstream Classic 30' Excella 1000
2014 Ram 2500 Crew Cab with Cummins 6.7L Diesel
Sold but not forgotten: 1991 Airstream B190
Sold: 2006 F-250 6.0L Powerstroke Supercab
Skater is offline   Reply With Quote
Reading Lights Under Front Cabinets in Bedroom 25FB KJRitchie 2006 - 2010 Classic (all lengths) 3 08-13-2019 05:17 PM
Class 25FB: Replacing the Bedroom Reading Lights KJRitchie 2006 - 2010 Classic (all lengths) 0 05-08-2014 09:37 AM
Bedroom lights won't work! julieibach Lights - Interior & Exterior 1 01-24-2011 10:14 PM
ALL bedroom lights are out??? Rickey R. Lights - Interior & Exterior 6 11-08-2010 05:06 AM
Bedroom Lights Don't Turn On/Turn Off and turn back on after a couple minutes. alecg Lights - Interior & Exterior 9 09-01-2010 02:01 PM
