Old 04-03-2016, 07:19 AM   #1
2014 Interstate Ext. Coach
West Lafayette , Indiana
Awning not working
The awning on my IS 2014 ext not working. Based on others i have tried to replace fuse under drivers seat #10 which is 15 amp and awning still does not work. Is that the right fuse? What other things should i check to get my awning to move?
cbg indiana is offline   Reply With Quote
Old 04-03-2016, 10:48 AM   #2
73shark's Avatar
2011 Interstate Coach
Overland Park , Kansas
Assuming that it used to work, first I'd check to see if there's voltage at the switch. If there is, then check for voltage at the motor w/ the switch depressed. If there is, then the motor appears to be the problem.
Power Awning stopped working Doc Foster Awnings 22 05-23-2016 08:17 AM
Front interior light not working, middle and rear working? jonnyo Lights - Interior & Exterior 4 04-03-2016 09:16 PM
Dometic heater zone 2 not working on furnace, not hot on HP sfgirl General Repair Forum 13 11-06-2015 01:21 PM
Help! Battery not charging, outlets not working when plugged in AirGal04 Electrical - Systems, Generators, Batteries & Solar 9 06-06-2014 09:15 PM
vent fans missing/not working Rog0525 Roof Vents, Skylights & Fans 2 07-02-2002 04:23 PM
