Old 05-04-2019, 03:46 PM   #1
2017 Interstate Grand Tour Ext
Bozeman , Montana
Awning and Step - No Power - Help!
Hello all -- I was doing a repair on the awning today and lost power to both the awning and step. I've read that they share a common fuse or relay but can't locate it. We have a 2017 AI Grand Tour.
One source I read suggested fuse 10F, 20A but that is not the case with our unit.
Does anyone know if there is a common component and which one/where to look? Thanks very much!
David J
ArcherTC is offline   Reply With Quote
Old 05-04-2019, 07:14 PM   #2
barrie , Ontario
Dave
We have the same RV and the awning fuse is located in your power center. I tried to attach an image of the fuse panel which shows the fuse (yellow)as 10 amps second from the top called cir.2
Make sure you have not hit the hold switch for the step. We did this once when we couldn’t get the step out.
I can send you images if you want to reply to My email.
catjer is offline   Reply With Quote
Old 05-04-2019, 10:54 PM   #3
Prof. of Pending Projects
wachuko's Avatar
2018 Tommy Bahama Interstate
Orlando , Florida
In our 2018 (2017 chassis), fuse is in the driver’s seat. A 15 amp fuse in position 10
Here, take a look:
And the link to the threadI created when my awning was deploying by itself:
http://www.airforums.com/forums/f240...lf-190386.html
Safe travels!
Wachuko
WBCCI #26769
2018 Airstream Interstate 3500 Lounge EXT Tommy Bahama w/ARS
wachuko is offline   Reply With Quote
Old 05-05-2019, 07:34 PM   #4
Bozeman , Montana
Thanks all for the help, but so far I've checked fuses 10 and 12 and they are okay.
Makes sense that this is a problem with the circuit that prevents both the awning and step from opening when the engine is running ??
Any other advice greatly appreciated!
David J
Step by Step 1959 Over59 1954 - 1959 Overlander 237 11-18-2015 03:41 PM
How About a Collection of Step by Step Repair Procedures? josephhh Airstream Motorhome Forums 32 07-06-2015 09:47 PM
Repair of sloppy step and addition of second step 1969 triterra Steps 5 02-16-2015 01:40 PM
Step-by-step sewing an awning yukionna Awnings 11 12-28-2006 01:37 PM
Need step by step instructions Grady White Repairing/Replacing Floor &/or Frame 3 06-25-2002 02:35 PM
