Old 09-11-2016, 10:12 AM   #1
2014 Interstate Ext. Coach
fairfax station , va
Auxiliary Chassis Battery
I don't know if this is already posted here, but the vestigial auxiliary battery under the hood has at least one good use.
I'm still trying to diagnose my chassis battery/BIM dead battery problem but I found out that this works in a pinch
Say hello to my little friend. Jump yerself.
VAtom is offline   Reply With Quote
Old 09-11-2016, 11:32 AM   #2
Boxster1971's Avatar
2013 Interstate Coach
Fulton , Maryland
Not sure from your picture where you are connecting the negative lead to the vehicle. The proper spot is the negative post above the aux battery on the LH fender wall. Here is what my Sprinter owner's manual says about this.
Name:	ImageUploadedByAirstream Forums1473615127.022662.jpg
Name:	ImageUploadedByAirstream Forums1473615144.627689.jpg
- - Mike
2013 Lounge EXT on 2012 Sprinter
- - Mike
Boxster1971 is online now   Reply With Quote
Old 09-11-2016, 11:41 AM   #3
It was just a miscellaneous bracket close-by that was also grounded to the vehicle.
Old 09-11-2016, 12:27 PM   #4
Clifton , Virginia
I have my dashcam and WeBoost connected to the aux chassis battery via the cigarette lighter socket under the driver's seat.
cjrdad is offline   Reply With Quote
Old 09-12-2016, 06:23 PM   #5
Bellevue , Washington
Thats cool! Thanks for posting.
amirm is offline   Reply With Quote
Old 09-19-2016, 09:06 PM   #6
Trying to Retire
MILATV's Avatar
Decatur , Illinois
Nice! I actually store my jumper cables on top of the Aux battery with a bungie cord (easy access as a Good Samaritan)
Mike
Mike
If you work until you have everything you 'WANT' - it will probably be too late to enjoy it.
Live in the Moment and enjoy today.
MILATV is offline   Reply With Quote
Auxiliary battery jasonsherman Batteries, Univolts, Converters & Inverters 12 09-23-2014 09:31 PM
Auxiliary battery disconnect soleniod 01DHS Mechanics Corner - Engines, Transmission & More... 1 08-08-2012 01:34 PM
Auxiliary Electric Engine Cooling Fan cooperhawk Airstream Motorhome Forums 8 02-25-2007 07:18 AM
Auxiliary catalytic heater bhsl8 Furnaces, Heaters, Fireplaces & Air Conditioning 30 07-16-2006 03:41 PM
Auxiliary Heater water control valve noiva Mechanics Corner - Engines, Transmission & More... 4 12-16-2005 03:50 PM
