Old 04-06-2016, 12:13 PM   #15
San Luis Obispo , California
We've had our AS for about 10 days. Took out for its maiden trip over the weekend. The PS rear nite shade won't retract now. Printed out the User Manual from the manufacturer's website. Tried to re-program as described on p. 9, but no luck. Have an appt on the 20th to repair. We also noticed two shades that need a "limit adjustment" so they won't crinkle. Other than that, we enjoyed our first outing.
slomanbob is offline   Reply With Quote
Old 04-07-2016, 08:43 AM   #16
Houston , Texas
Check for a blown fuse. I had the 5amp fuse blow so my rear door shades became inoperable. Replaced fuse and all is well.
Mcrider is offline   Reply With Quote
Old 04-09-2016, 12:42 PM   #17
Mcrider: Thanks for the suggestion. I've traced the wiring and both the PS mid & PS rear shades are powered by the same fuse. Inasmuch as the mid shade is working properly, I'm assuming it's not the fuse.
Old 04-10-2016, 08:06 AM   #18
Depere , Wisconsin
Slomanbob...I have exactly the same problem after my recent 6 week trip...blew the 5 amp fuse and PS rear shade became inoperable. Replaced fuse and PS mid shade is fine. My rig is in for service now and I will let you know the cause of the problem PS rear shade
summerwood is offline   Reply With Quote
Old 05-20-2016, 12:55 PM   #19
Waynesville , North Carolina
Thanks for the manual download. Do you have to take off the side panel to get to the rollers? If so, is it easy to do... do they snap in somewhere?
jarreau is offline   Reply With Quote
Old 05-20-2016, 02:01 PM   #20
Houston , Texas
Remove screws located in overhead luggage compartment. Then the side panel will pull away sufficiently to access wiring if needed. Limit. Programming switches can be reached without going to this trouble.
Old 11-23-2016, 03:33 PM   #21
Houston , Texas
Hopefully Airstream has improved the install of these Automotion Shades. I've now had a rear door shade toast a motor. Had to remove the rear interior panel to replace it. And on my current trip I just had another one eat it's own programming switch (twice this has happened). The programming leads can get tangled in the shade as it retracts and will rip the wires apart. I'll better engineer/secure that when I get home and repair. Crappy install by Airstream.
Old 11-25-2016, 11:21 PM   #22
2017 Interstate Lounge Ext
Temple City , California
Crappy workmanship for sure. Double sided tape to secure the wire harness is a joke. One of my night shade is not in sync with all night shade function. It'll work independtly, tried to re sync according to the manual but doesn't work. Any clues how to re sync with the rest?
dapolrbear is offline   Reply With Quote
Old 11-26-2016, 07:45 AM   #23
2017 Interstate Grand Tour Ext
Gallatin Gateway , Montana
Similar problem with our '17 AI Touring - i.e., cargo door night shade refuses to close; dealership ordered parts over 3 weeks ago - still haven't arrived from Airstream! Seems ordering parts from Airstream is a frustrating and slow process!
bob323 is offline   Reply With Quote
Old 11-27-2016, 06:43 AM   #24
ScottP's Avatar
2018 30' International
2018 Interstate Lounge Ext
Bend , Oregon
The past several model years have migrated from manual to electric shades as you know. While the electric shades are sexy, they seemed poorly engineered and installed.
Our '17 unit has seen a dramatic improvement in the install and performance of the electric shades.
2017 4x4 Interstate
Bend, Oregon
2018 Int. Lounge 9 pass 4x4
Bend, Oregon & Rye, New Hampshire
Previous 9 pass Interstate's owned:
2014.5, 2015, 2016, 2017 (4x4)
ScottP is offline   Reply With Quote
Old 11-27-2016, 05:51 PM   #25
Houston , Texas
If the rear shades will not operate, check the fuse. They are fused separately and mine would blow regularly. Switched to a 7.5 amp fuse and that stopped happening.
To re-synch, place the shade in the opposite position of the others and re-program. You will have to re-program the "ALL" Button as well.
What did they change in the '17 install?
Old 11-28-2016, 06:36 AM   #26
Assuming that both rear shades share the same fuse, I doubt it's a fuse since one rear shade works and the other doesn't. And it's ONLY the night shade on the passenger side cargo door which doesn't work. The sun shade on that door works fine!
Any ideas?
Old 11-28-2016, 08:24 AM   #27
Depere , Wisconsin
auto shades
I had a similar problem with one of my night shades i.e. It would work independently but not with all-shade mode. I eventually turned off all power to the rig and waited a minute, then reprogrammed the shade per the manual using the all-shade mode. All of the shades now work as specified.
Old 11-29-2016, 06:52 AM   #28
Houston , Texas
Ah, I didn't pick up that nuance. I had the same issue. Failed motor for the night shade. Sun and Night shade comes as a unit so you have to replace it in one go. If under a year, it is still under warranty. If not and you plan to do it, you have to pull the back door trim off. Not hard, but you need trim tools, patience and time. There are two spring clips that hold the blind in (on the glass facing side of the window. Push up and it releases the blind frame.
cleaning day/night shades bina Upholstery, Blinds, Walls & Interior Finishes 5 02-23-2007 12:36 PM
Day-Night Pleated Shades Alumaholic Upholstery, Blinds, Walls & Interior Finishes 8 10-19-2006 12:41 PM
Day/Night Pleated Shades Minnie's Mate Upholstery, Blinds, Walls & Interior Finishes 10 11-03-2004 09:03 AM
Cleaning Day/Night Shades LTD30 Upholstery, Blinds, Walls & Interior Finishes 0 07-15-2004 10:57 PM
