Old 05-21-2014, 10:13 AM   #1
Jeff
jkinglet's Avatar
2013 Interstate Coach
Seattle , Washington
Images: 37
Audio ports HDMI cords
From an audio/visual novice. 2013 Interstate, in the upper storage behind the slider above the driver are empty audio ports (white,red,blue) against the wall of the storage area along with 2 HDMI cords coming from somewhere and leading to nowhere, and a second Coax cable. I assume the second coax is for satellite? Anyone know what the audio ports are for and uses for the HDMI cables? Can't find any explanation or description in the manuals.
jkinglet is offline   Reply With Quote
Old 05-21-2014, 05:12 PM   #2
Boxster1971's Avatar
Fulton , Maryland
Yes second coax is for adding a satellite system. The two HDMI cables are there to allow you to add a Blu-ray player and connect to each TV individually. Check the color match on the HDMI plugs on your TVs.
- - Mike
Old 05-21-2014, 05:18 PM   #3
Fulton , Maryland
Oh - BTW the owners manual from Airstream for the Interstate are the worst in the industry. The manual they gave me for my 2013 model still had the image of a Freightliner Sprinter on the cover and the rest of the manual was just as old; 2008-2009 vintage being passed off as manual for 2013 model. The one I downloaded from the Airstream web site was the same outdated manual.
COME ON AIRSTREAM YOU CAN DO BETTER!!!
- - Mike
Old 05-21-2014, 05:44 PM   #4
Jeff
jkinglet's Avatar
Images: 37
Thanks. I see the different HDMI color caps. What are the audio ports for? Are they for Blu Ray Audio output? And does the audio route to the headphone ports again? I really would like to utilize the coach speakers for DVD audio but sounds like I may have to take it to Car Toys or a shop to make that happen since the sound is routed to the headphone ports unless you use the tinny TV speakers (aarrgh) thus sacrificing Dolby digital and surround sound.
Old 05-21-2014, 07:24 PM   #5
Fulton , Maryland
Not sure which audio ports you are talking about. The TV sound is either from the TV speakers or from headphones using headphone port and switched to headphones.
If you want the TV audio routed to Kenwood unit and coach speakers you will have to add wires and likely your best bet is a good car audio shop.
- - Mike
Old 05-21-2014, 08:37 PM   #6
Jeff
jkinglet's Avatar
Images: 37
Audio Ports
Here they are, on the wall between the two coax boxes. Sorry about the quality..it's dark in there..Next job, motion light inside.
Old 05-22-2014, 08:04 AM   #7
Fulton , Maryland
I'll have to check and see if my rig has this connector. I've never noticed it - but as you said it's dark in that over head cabinet. Sure would be nice if that was connected to the Kenwood Aux In for audio.
- - Mike
Old 05-22-2014, 08:10 AM   #8
Fulton , Maryland
Mine has same connector. It is video and audio to the forward TV. Not to Kenwood unit.
- - Mike
HDMI Switcher with 3 inputs ghaynes755 Audio, Video & TV 1 04-29-2014 08:42 PM
Adding HDMI to Bedroom emdubyadee Audio, Video & TV 21 03-31-2013 10:25 PM
What US ports ship trailers to UK Edinburgh Shipping & Export/Import 15 09-21-2012 03:07 AM
HDMI Splitter Cable GerryH Audio, Video & TV 1 12-14-2011 11:26 AM
HDMI cable for 20' Flying Cloud mistermcfrug Audio, Video & TV 18 02-09-2010 02:22 PM
