Old 09-10-2014, 04:33 PM   #1
Jeff
jkinglet's Avatar
2013 Interstate Coach
Seattle , Washington
Images: 37
Attwood Water Heater issue redux
2nd time around on this. Simply put: L.P. ignites on first click at sea level-L.P.won't ignite at altitude (above approx.2k feet). Model GE9 EXT. Electric works fine. Attwood Mobile doesn't respond to email inquiries and the local service center won't return phone calls. Soooo, I thought maybe someone out there knows a quick fix, if any (i.e.,how to adjust the oxygen/L.P. mix for altitude). Thanks. Jeff
jkinglet is offline   Reply With Quote
Old 09-10-2014, 05:07 PM   #2
drboyd's Avatar
1978 25' Tradewind
Metro Phoenix , Arizona
So, this tells me it's not getting enough oxygen at altitude. Personally, I'd try opening the air vents a little and see if that helps. Here's a video on how to do that. Of course, your mileage may vary, and your mother warned you not to mess with propane.
Old 09-10-2014, 05:15 PM   #3
Jeff
jkinglet's Avatar
Images: 37
Thanks. You are on my Christmas list. Doesn't get any simpler than that! I'll include the "RV Doctor" on that same Christmas list.
Old 09-10-2014, 05:22 PM   #4
drboyd's Avatar
1978 25' Tradewind
Obviously, if more air makes it worse, go for less air.
Oh, boy! Between you and my wife, I'll have two lumps of coal in my stocking!!!
new w/h.. Attwood or Suburban? sunnynsequim Water Heaters, Filters & Pumps 3 04-12-2014 05:23 AM
Attwood on demand delayed AGAIN wharfrat8995 Water Heaters, Filters & Pumps 1 05-29-2012 11:04 AM
196O Overlander buying an Attwood furnace? Lothlorian Furnaces, Heaters, Fireplaces & Air Conditioning 2 10-07-2010 12:51 PM
Attwood Water Heater... Trouble Shoot... Lothlorian Water Heaters, Filters & Pumps 9 12-31-2009 12:22 PM
Attwood heater stinks, then dies! Gasp! Anniedog Water Heaters, Filters & Pumps 0 10-17-2007 07:00 PM
