Old 06-22-2014, 05:55 PM   #101
Ravenna , Ohio
Originally Posted by graysailor View Post
TireMinder seems to be working. The problem I am having now is that the Minder tells me I have 36.5lbs of pressure but I checked the tires and all four have 40lbs. of pressure. I changed the batteries with the same results. The trailer tire pressures are still accurate. Just not sure how to adjust the TV so that it will be more accurate. Difficult system to set up and adjust.
I wouldn't be too concerned about a 3.5 psi difference. Is your hand gauge a digital 0.5 reading gauge that you have checked against a certified calibrated gauge?
I did a post on gauge accuracy Oct 26 2012 on my blog and had 36% of the group of gauges fail.
Retired tire engineer (50 years). Write a blog on RV Tire Safety Net. Give seminars for FMCA across the US. Tucson AZ in Mar 2024 is next.
Tireman9 is offline   Reply With Quote
Old 06-22-2014, 05:56 PM   #102
Ravenna , Ohio
Don't forget "TireMinder" is the trade name of one brand of aftermarket TPMS and not all TPMS are the same.
Old 06-22-2014, 05:59 PM   #103
Ravenna , Ohio
Originally Posted by paullovern View Post
Graysailor: I'm not sure if you are driving an interstate but when we took delivery the dealer told us to disregard the tire pressure placard in the driver's door jamb and fill all tires to 60 psi. So if you're at 40, you may decrease your tire life.
Interesting. Have to wonder what information the dealer had that justifies him giving you that info. Did he have the motorhome weighed and did he do the calculations?
Did he mention the Interply shear forces in trailer applications and the decrease in cornering force generated?
Is he willing to put his advice to ignore the placard in writing?
Old 06-22-2014, 06:49 PM   #104
Ag&Au's Avatar
Port Orchard , Washington
I am curious what gauge you are checking the Tire sensors against. 3.5 Psi out of 40 is less than a ten percent error. 10 percent error would be considered a good external tire gauge. Since the tire sensors are four separate sensors being compared (I assume) to a single external tire gauge, I would say, if as I understand it all the tire sensors are in showing the same difference from the external guage, that they are giving the most accurate readings. Unless you pay much more for an external gauge than most people do, it is not going to be a particularly accurate tool. Not to mention that you only need to drop one once and its accuracy becomes a big unknown. I imagine that the Interstate's sensors are probably calibrated accurately before they leave the factory. Trust me: Trust them before you trust your external gauge.
Ken
Old 06-23-2014, 04:25 AM   #105
CapriRacer
CapriRacer's Avatar
I'm in the , US
I'm with Roger on this. A dealer verbally suggesting that a Federally mandated label is incorrect and should not be followed is like ignoring the prescription your doctor wrote out and using something the clerk at the pharmacy told you about.
I'm continually amazed at what people will offer as advice and continually amazed at how many people will listen.
CapriRacer is offline   Reply With Quote
Old 06-23-2014, 07:11 AM   #106
TinCan
graysailor's Avatar
2016 30' Classic
Apache Junction , Arizona
I have a Flying Cloud 25. I maintain 65lbs. on the trailer tires. TV is a Ford F150 which I maintain 40lbs. I double check with two external gauges. They both read about the same.
TinCan
graysailor is offline   Reply With Quote
Old 06-23-2014, 07:49 AM   #107
Mantua , Ohio
The door sticker may be for a stock Sprinter, not an AI. For an Interstate you need close to the max tire pressure because you are close to the max weight. You do not have to weigh an Interstate, they are all close to maxed out weight wise for the Sprinter chassis or close enough that it does not matter. Jim
Old 06-23-2014, 09:22 AM   #108
Newbie
joemikeb's Avatar
2013 Interstate Coach
Fort Worth , Texas
Thumbs up
FWIW the door sticker in my 2013 AI, the MB Owner's Manual, the Airstream manual, my dealer's recommendation, and the tire shop that put on the extended valve stems all concur the tire pressure should be 61 pounds.
I tried a TPMS with valve stem sensors, but they were not passthrough and I had to remove the sensor to adjust the pressure in the tires. Removing the sensors was a total pain in the nether regions of my anatomy so that one went back to the dealer for a refund.
I replaced it with the TireSafeGuard TPMS ($279 for six wheels) with passthrough valve stem sensors. It has simple automatic initialization feature that takes with the average pressure in all six tires and uses that as the standard pressure. When I compare the monitor readings with a calibrated manual pressure gauge the TPMS readings are within + or - a few pounds. Certainly close enough for government work. The monitor can handle up to 18 wheels and different tire pressures on the trailer or toad using manual setup because of the varying base pressures. When you are stopped for an extended period the TPMS goes to sleep to conserve battery life and the batteries in the sensors are replaceable. On the road, the faster you are moving the more frequent the sampling rate. The system comes with a range extending antenna, but it is unnecessary to read the AI tire pressures and temperatures. however I may need to for the toad.
So far the only complaint I have is the glue used on the furnished mounting bracket won't stand up to the heat of a North Texas summer day and the darn thing falls off. Some industrial strength Velcro should fix that. The planned permanent mounting point is the CB radio knock out panel in the overhead and tapping into the wiring that is already there for power. It works well enough that I am going to get additional sensors for the tow dolly and the toad vehicles.
A final note. IMHO metal extended valve stems are essential for valve stem sensors and be sure to get the ones designed to work with the aluminum and steel wheels used on the AI.
Make errors — otherwise the Great Spirit realizes
you have finished your purpose on earth.
— Navajo saying
joemikeb is offline   Reply With Quote
Old 06-23-2014, 12:34 PM   #109
UKDUDE's Avatar
2014 Interstate Ext. Coach
Sedona , Arizona
Great information, joemikeb - thanks.
Regarding tire pressures, I cannot imagine Mercedes Benz would issue a door sticker that couldn't take into account anything other than the vehicle being fully loaded. Without that, owners would be left guessing. And we know RV upfitters pretty much load up the chassis towards the limit.
Regarding the passthrough sensors, they look pretty hefty. Do they affect wheel balancing?
Old 06-23-2014, 03:09 PM   #110
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
Welcome to the internet.
2019 Ford Expedition Platinum
Old 06-23-2014, 07:06 PM   #111
Newbie
joemikeb's Avatar
Fort Worth , Texas
Actually the sensors are pretty light weight in fact probably lighter than the non-passthrough sensors they replaced. In any case, I installed the sensors before I had the tires balanced.
— Navajo saying
Old 06-24-2014, 05:34 AM   #112
CapriRacer
CapriRacer's Avatar
I'm in the , US
Jim,
Federal law mandates that when a vehicle modifier (and Airstream would count in this case) modifies a vehicle, they become responsible for the vehicle tire placard and must alter it appropriately, if needed.
I imagine that Airstream is large enough and has done vehicle modifications for so long, that they are not only aware of the federal regulation, had conversations with both the Feds and MB on the subject, but also have taken more than just a superficial look into what is written there - like doing some handling studies. If they haven't replaced the vehicle tire placard with one of their own, it is because they are convinced it is appropriate.
This is not to say that your argument doesn't have merit for other vehicle modifiers, but I think Airstream is just not in the same category as the rest. But just so you are aware, what you are arguing is that not only is Airstream derelict in its responsibility to the law, but also to its customers. I would be very careful with that accusation.
Old 06-24-2014, 08:00 AM   #113
Ravenna , Ohio
Tireman2: we bought the AI used with the to reminders already on. I was getting an inordinate amount of false alarms to the point that I didn't believe it when it alarmed. I was getting pressures of 82 psi and an hour later 58 psi on the same tire. I replaced 3 of the 6 and changed all the sensor batteries. I then bought a truckers pressure gauge and meticulously set the cold temp pressure to 60 psi on all tires. Now I get no alarms and my confidence in the system is returning.
No telling what the previous owner did with the TPM settings. Glad you figured it out and have a functioning system.
Happy Camping.
Old 06-24-2014, 08:39 AM   #114
Ravenna , Ohio
A bit of a summary here:
- You should have a Digital tire gauge. I have posted the results of my tests of dozens of gauges that RVrs were using and the bottom line is that about 15% were off by more than 5 psi which IMO makes that tire gauge a good door stop or tent peg. I have provided information on how to do your own gauge "Calibration Check" to confirm the accuracy of the gauge you use daily and how to maintain your "Master Gauge"
- If you follow the advice from the two Tire Engineers on this thread you will be setting the pressure based on the appropriate method here:
- On your TV inflate to pressure based on the Door sticker and Owner's manual for "Fully Loaded" operation. BUT get on a scale at least once to confirm you are not overloaded.
- If you have a multi-Axle trailer you should be running the pressure on the tire sidewall. I have written in my Blog and provided the technical justification and need to follow this advice. You should still go across a scale and calculate the actual tire loads to confirm you are not overloading one or more tires
- If you have Motorhome you need to confirm your unit's "corner weights". Use one of the worksheets I have provided links to. Use Load/Inflation chart from your tire manufacturer, to confirm you are not overloaded and identify the heavier loaded tire on each axle. Using the pressure for that load add 10% (without exceeding the wheel max) and that is your Cold set pressure for all tires on that axle.
- If you follow the above there should be no reason to be chasing your tire inflation around unless you have a major change in Morning temperature ( More than say 30°F ) as you would only need to "Top Off" the air once a month at most.
- Don't be too anal about inflation. Variations of 1 to 3 psi day to day are normal. You should not need to make adjustments unless the Cold pressure is 4 or 5 psi away from your goal. (Multi-axle trailers might try and get no lower than 3 psi below tire sidewall pressure)
- TPMS are a WARNING device and like Insurance we should all be using them. Also just like Insurance they cannot "Prevent" bad stuff from happening but with luck they may give sufficient advance warning to lessen the impact of the bad stuff that does happen.
- If you are parked for more than a day you need to cover your tires that will be in direct sunlight with WHITE tire covers. This protects against both UV and higher temperature damage which can shorten tire life.
If you follow this advice I think you will find that tires become less of a worry for you.
Old 06-24-2014, 08:57 AM   #115
UKDUDE's Avatar
Sedona , Arizona
Thank you Tireman9. Can you please tell us where you posted all this information?
Peter
Old 06-24-2014, 11:47 AM   #116
Boxster1971's Avatar
2024 Interstate 19
Fulton , Maryland
I think you are wrong. Those stickers are for a modified Interstate. The max pressure on the tire is 80 psi, way too high.
- - Mike
2024 Airstream Interstate 19e AWD
Previous: 2013 Airstream Interstate 3500 Ext Lounge
Old 06-25-2014, 09:35 AM   #117
acstokes's Avatar
2009 30' Classic
Melbourne, FL , Searsport, ME
Tireman is correct. TPMS is more than just insurance. It also avoids the hassle, aggravation, and possible extensive damage and injury that may result from a blowout or deflation. I believe TPMS should be mandatory for all duel or triple axle TTs.
Fred Stokes
RV Rearview Camera Systems, LLC
WBCCI #2810
acstokes is offline   Reply With Quote
Old 06-25-2014, 09:52 AM   #118
UKDUDE's Avatar
Sedona , Arizona
I'm still waiting for a link to Tireman9's digital gauge recommendations PLEASE I have a Milton 986 and believe it to be good quality and accurate, but since the scale is from 10-160 psi, it's really hard on my eyes. An accurate digital gauge that can handle duallies would be ideal.
Old 06-25-2014, 10:18 AM   #119
John&Vicki's Avatar
1990 25' Excella
Sisters , Oregon
Dill TPMS For Sale
Hopefully it's appropriate to post this here.
I bought a Dill TPMS a few months ago and have decided not to install it at this time. I paid $279.00 plus shipping. Still NIB, I'm offering it for $250.00 shipped.
http://www.tirerack.com/accessories/...ELTPMS&ID=2179
I also have a ad in the Classifieds section.
Poppy
John Audette
Air Cooled Porsche Specialist -
Two roads diverged in a wood, and I took the one less traveled. ~ Robert Frost
John&Vicki is offline   Reply With Quote
Old 06-25-2014, 02:08 PM   #120
73shark's Avatar
2011 Interstate Coach
Overland Park , Kansas
Originally Posted by Birdmaestro View Post
Dill TPMS For Sale
Poppy
Probably won't fit the Alcoa wheels on the Interstate.
2011 Interstate SOLD! Upfitted 2017 Transit 350. SOLD!
Advice needed, and perhaps a tip or two. Curtis-79MH Airstream Motorhome Forums 12 06-26-2007 01:43 PM
HELP PART NEEDED! Aluminum Termination Cap... InsideOut Waste Systems, Tanks & Totes 46 03-20-2006 06:08 AM
Help!! Refrigerator Access Door Needed! Melissa Hamilton Exterior Storage Compartments & Access Doors 13 01-19-2004 04:03 PM
Organization Experts Needed! Andy R Forum Admin, News and Member Account Info 7 04-10-2003 06:53 PM
Propane Tanks - New OPD Needed? montanaandy LP Gas, Piping, Tanks & Regulators 18 06-17-2002 12:11 PM
