Old 09-10-2015, 11:47 AM   #15
2014 Interstate Ext. Coach
Chattanooga , Tennessee
Electic knife for cutting foam?
Originally Posted by 73shark View Post
An electric knife can cut foam very well without leaving ragged edges like a box cutter will sometimes.
You must have a different electric knife than I have (two serrated blades moving back and forth). The one I have is used to cut our Thanksgiving turkey once a year (not that well, I might add). I'm pretty sure it would shred the foam.
So I looked at Amazon and the first page of results for "electric knife" show the kind I have. Is that what you mean? Or is there a different type of electric knife that I should have in my toolkit?
BrianKrueger is offline   Reply With Quote
Old 09-10-2015, 12:06 PM   #16
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Foam should be cut with a "hot knife."
http://www.amazon.com/Horizon-Hobby-...r+cutting+foam
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 09-10-2015, 12:43 PM   #17
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
I have been cutting foam for years with an electric knife. Have not shredded one yet.
MICHAEL
Old 09-10-2015, 01:04 PM   #18
1999 28' Excella
New Orleans , Louisiana
I bought a cheap electric knife on forum advice to cut our topper for our twins..worked quick, easy and great job. Loved getting that tip.
badkat is offline   Reply With Quote
Old 09-10-2015, 01:15 PM   #19
coloradopete
coloradopete's Avatar
1988 25' Excella
Montrose , Colorado
Air mattress
We purchased a "Select Comfort" dual air mattress about 7 or 8 years ago for our 25' Excella and have been very happy with performance. Using such an air mattress does require being aware of elevation change, as the air pressure required for comfort at 5000' will expand the mattress greatly at say 7000'. So you must deflate the mattress before traveling to higher elevation. We use a small portable DC to AC converter to power the pressure pump if AC power is not readily available.
coloradopete is offline   Reply With Quote
Old 09-10-2015, 01:43 PM   #20
AI owner since June 2013
Lake Mary , Florida
We purchased single TempurPedic memory foam toppers which we lay side by side - they overlap a few inches but they sleep very well. They also roll up and store easily in the overhead lounge storage cubby. We are big TempurPedic fans and these toppers have worked well for us. We just bought a king RV Superbag to use on top of the toppers to eliminate the need to try to sheet the foam toppers.
FlaBucki is offline   Reply With Quote
Old 09-11-2015, 06:29 AM   #21
Zil
egg harbor city , South Jersey
cutting foam with an electric carving knife is a skill to be learned. The first cut, or if trying to cut too fast, is not good. I leave the line i wish to cut over the edge of a table, with a board on top to hold the foam. Then with a sawing maneuver, slowly go the length. The web site of "The Foam Factory" is worth a read.
Zil is offline   Reply With Quote
Old 09-11-2015, 10:03 AM   #22
Cincinnati , Ohio
We've been using two therm-a-rest mondo-king mattresses and have been very satisfied. We do add some extra air beyond the self-inflated fill.
bropeace is offline   Reply With Quote
Old 09-14-2015, 02:54 PM   #23
k9jackie's Avatar
2015 Interstate Ext. Coach
Great Falls , Virginia
Name:	ImageUploadedByAirstream Forums1442263976.007632.jpg
ID:	248024 this is the queen aero bed I bought... Folds up small. Can't wait to try it this week when I go to the Hershey RV show
2014.5 Airstream Interstate Ext.
k9jackie is offline   Reply With Quote
Futon Mattress to Replace Front? Gaucho Bed Mattress? lanajane General Interior Topics 8 05-26-2016 04:07 PM
Mattress Cover, or Foam Mattress with Cover (Full Size) (price reduced AGAIN!) duckdave Airstream Classifieds 0 08-03-2014 12:15 PM
Mattress corner detail for 32 x 74 twin mattress Silverexpress 1999 Safari 2 09-29-2013 06:00 AM
Anyone use an Air Deflector? flyfisher Our Community 12 02-19-2004 07:42 PM
Ever use a foam mattress pad? drboyd Upholstery, Blinds, Walls & Interior Finishes 13 02-12-2004 04:30 PM
