Old 07-07-2015, 04:21 PM   #1
FunWaggin's Avatar
2014 Interstate Ext. Coach
Raleigh , North Carolina
Any Tailgater (portable satellite) experts out there?
Need help from anyone using the Tailgater. I am unable to get satellite reception when I connect directly to the coach at the cable port in macerator compartment. I have connected the receiver to the satellite cable pre-wired above the drivers seat. I have removed the wire used to complete the cable connection from the coaxial plate as instructed in the AI manual. Please let me know if I am omitting a necessary step. I am hopeful it's not a coach wiring problem.
(I am able to get satellite service when I connect the receiver directly to the satellite.)
Thanks!
FunWaggin'
FunWaggin is offline   Reply With Quote
Old 07-07-2015, 05:42 PM   #2
Rockwell , North Carolina
When I bought my 2013 AI used, it had a Tracvision in motion antenna installed. Since that system uses Directv, and I have Dish, it was not a viable option for me. I bought a Tailgater. The first time I used it, it did not work with the exterior input. However, I later discovered that when the Tracvision had been installed, the wiring had been altered. I took it back to the original wiring and I now can run a cable from the cable input in the overhead cabinet to the receiver and it works great.
If you hook up cable to that exterior input, does it work? If not, there may be a wiring issue. On the antenna amplifier in the overhead cabinet, is it in the off position. It has to be off for the exterior antenna hookup to work. I have attached the AV wiring diagram. It may be some use to you in tracking down the problem.
jerhofer is offline   Reply With Quote
Old 07-07-2015, 06:06 PM   #3
FunWaggin's Avatar
Thanks so much, Jerhofer! Cable works fine using the external port so I am hopeful I can get the satellite to work. Should I be connecting the receiver to the coaxial faceplate? If so, should the input side of the faceplate be connected to the Dish receiver using the existing jumper cable?
FunWaggin'
Old 07-07-2015, 07:34 PM   #4
FunWaggin'
Yes you do run the wire from the cable-in on the faceplate to the receiver. As long as cable works when wired to the exterior input, your Tailgater should work as well. Are you using the HDMI connection from the receiver to the TV? This thread may help as well.
http://www.airforums.com/forums/f240...ic-130356.html
Old 07-07-2015, 07:38 PM   #5
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Try as an experiment bypassing the connections in the coach altogether and running your tailgater direct into the receiver. If the tailgater fires that will tell you if the problem is in the coach wiring
Old 07-08-2015, 05:52 AM   #6
Lineolated's Avatar
2014 Interstate Coach
Centre County , Pennsylvania
Here are a couple of things to try:
- make sure the monoprice splitter is set to use the correct input, otherwise no signal to the TV.
- after setting up the tailgater, unplug the receiver so it will reboot (powering off is NOT equivalent to unplugging!)
Good luck!
Lineolated is online now   Reply With Quote
Old 07-08-2015, 06:29 AM   #7
fairfax station , va
tailgater
FunWaggin'
I'm not thinking you you use the "satellite" prewire at all; that is for a roof mounted satellite. The tailgater output just comes out the normal cable outlet which is then routed to the power injector and then dish receiver.
VAtom is offline   Reply With Quote
Old 07-08-2015, 08:14 AM   #8
FunWaggin's Avatar
Wow! I love this forum! All comments have been really helpful. My first mistake was using the pre-wire for the roof mount satellite! Ughhhhhh! I'm going to give it a try today using the coaxial faceplate and since cable works fine I'm anticipating the Tailgater should work too. I'll be sure to unplug for the reboot and now I understand what the Monopiece is all about! If I still have problems at least my A/V guy will have a diagram (thanks Jerhofer!)
FunWaggin'
Old 07-08-2015, 08:29 AM   #9
K.C. , Missouri
Let us know how it works out. I have read some say that if there is a splitter anywhere in the wiring between your outside connection on the trailer and where you are feeding the receiver inside, you may have a problem. I have a SOB trailer, and am not able to get the tailgater to work thru the trailer wiring. My solution was to run a separate wire to the outside ( from the receiver ), and then use a female-female splice to connect the wire to the tailgater antenna. This works for me.
gmw photos is offline   Reply With Quote
Old 07-08-2015, 12:05 PM   #10
1978 25' Tradewind
1979 28' Airstream Excella 28
Mountain Home , Arkansas
If you have two TV's in the coach, then there is a splitter somewhere in the line. Find the splitter and replace it with "power passing" high frequency splitter and you should be OK. The tailgater gets its power from the receiver and most splitters will not pass power and have a frequency limit of about 1000Mhz. DISH receivers need 2400Mhz to work properly
ednormandy is offline   Reply With Quote
Old 07-08-2015, 12:35 PM   #11
Fernandina Beach , Florida
I am so glad you asked this, I have had the same problem. The Tailgater directions say that the cable must go directly to the Satellite receiver and I hate having to run through a window. I know some have had success with this and I am looking for to understanding more as well.
Thanks!
Mldun is offline   Reply With Quote
Old 07-08-2015, 08:03 PM   #12
Mine works fine wired into the cable inlet on the exterior of the home. The only output on the Tailgater receiver is one HDMI connector. There is a HDMI cable hooked up to both TV's that is run to the cabinet above the cab area. To run both TV's from one receiver you will need a HDMI splitter. Run an HDMI cable from the receiver to the splitter and then plug in both HDMI cables from the TV's. This will allow watching the same image from the Tailgater on both TV's.
However, I recently removed the rear TV. We weren't using it and I kept banging body parts on it. I intend to mount a swing out mirror in that location. That will make my wife happy!! Happy wife, happy life!!
Old 07-09-2015, 01:18 PM   #13
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
Can't help you with the Interstate since I using the Tailgater with my Classic. The key for me to using the outside wiring entry point is to make sure we are not trying to connect the receiver to the port inside which services the broadcast TV antenna amplifier. In my case I have a inside port labeled satellite which is usually jumpered to another port. When I remove that jumper and connect the receiver to that port, I have a straight connection from that port to the port on the outside of the trailer. Most folks having problems connecting the satellite dish to the outside connector is the fact that they are connecting to the wrong inside port with the receiver, or have to move some jumper wires which takes the broadcast antenna amplifier out of the connection.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 07-09-2015, 05:54 PM   #14
FunWaggin's Avatar
I was able to get the Tailgater to work using the cable inlet on the coach! Next step is to follow Jerhofer's instruction and purchase an HDMI splitter so the rear TV will access satellite channels.
FunWaggin'
Any experiences with Tailgater Portable Satellite System by Dish? MarkMc Computers, Internet & Satellite 28 06-15-2013 09:16 AM
Any Glass Experts out there? ddstech Exterior Restoration Forum 1 10-13-2010 06:18 AM
Any UPS experts out there? guy99 Off Topic Forum 6 12-14-2006 06:31 PM
Any Michelin Tire Experts Out There? Double D Tires 13 03-05-2006 05:14 AM
