Old 06-25-2016, 07:30 PM   #1
2013 Interstate Coach
Lantana , Texas
Antenna Issue
First thanks again to the folks that contribute to the forum it helped in the purchase of our 2013 AI Lounge. On our first outing and having a great time.
We can't seem to get any reception on either TV with the antenna. I checked cables turned on the booster just static. Besides the connection up top which at the moment I can't get too is it possible I am missing something basic? The DVD works and I hooked my I pad up to the HDMI and it works great.
Ken
texasm3 is offline   Reply With Quote
Old 06-25-2016, 07:33 PM   #2
Cannonball's Avatar
2014 22' FB Sport
San Antonio , Texas
Have you checked the TV input? There is usually a choice for cable or Antenna. Sounds like you are on cable, not antenna.
Cannonball, Deep in the Heart of Texas!
WBCCI #4387, Air #84080
Cannonball is offline   Reply With Quote
Old 06-25-2016, 08:02 PM   #3
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
Are you in a place with no signal? We get that from time to time depending on where we are.
Old 06-25-2016, 08:54 PM   #4
Bellevue , Washington
This kind of antenna only works if you are close to the TV station/metropolitan areas. Anything outside of that and you will get zero reception. Test it when in town and if it still does not work, then it may be a wire/amplifier issue.
amirm is offline   Reply With Quote
Old 06-25-2016, 08:55 PM   #5
Boxster1971's Avatar
Fulton , Maryland
Try these steps first.
1) Need to be in area with TV stations, usually within 30-40 miles.
2) Turn on Antenna booster.
3) In TV setup menu make sure in "Over the Air" mode.
4) Run Auto Channel Scan in Setup Menu.
Then if still no results you may have a connector problem.
My 2013 is simply amazing at pulling in TV stations when I thought there were none around us.
- - Mike
2013 Lounge EXT on 2012 Sprinter
- - Mike
Old 06-25-2016, 09:00 PM   #6
UKDUDE's Avatar
2014 Interstate Ext. Coach
Sedona , Arizona
If you're using the antenna, then make sure the booster in the compartment above the driver is switched on. Then each TV needs to be set up for antenna (not cable). Then start auto tune and see if it locates any stations.
Old 06-26-2016, 07:12 AM   #7
Lantana , Texas
I couldn't get off cable until I did channel scan. I thought I could switch with out doing that. Works great. Thank you!!!
Old 06-26-2016, 08:31 AM   #8
2013 25' FB Flying Cloud
Tallahassee , Florida
Don't forget to point the antenna in the right direction. Also you can use the Internet to fine the correct direction to point. I think it's antenna point . Com
Omega Man is offline   Reply With Quote
Old 06-26-2016, 08:54 AM   #9
73shark's Avatar
2011 Interstate Coach
Overland Park , Kansas
AI uses an omni-directional antenna.
Antenna Removal & Replacement with Cell/Wifi Antenna BoldAdventure Electronics & Connectivity 10 08-14-2017 07:24 AM
Rooftop Antenna Installation - Spring Mount Cellular Antenna Astw Electronics & Connectivity 4 08-04-2016 08:51 AM
Furnace issue turns out to be AS issue 92landyacht Land Yacht/Legacy Motorhomes 16 01-20-2016 10:19 PM
Pulling the Air TV Antenna Replace With A Satellite Antenna Chuhhuniban Electronics & Connectivity 9 03-23-2015 12:43 PM
Window replacement issue davespann 1966 - 1968 Safari 4 09-09-2008 04:20 PM
