Old 10-14-2013, 08:49 PM   #1
Kwils25's Avatar
2014 Interstate Ext. Coach
Taylor Ridge , Illinois
Another Kenwood Question
Since the last thread concerning Kenwood issues was resolved successfully, I thought I would try my luck. I have a Kenwood DNX890HD in my 2014 Interstate and am having mixed results trying to get the rear speakers to work.
I can get the rear speakers to work with the HD radio by toggling the zone 2 button on the remote. I cannon get the rear speakers to work with any other function. I've played around with the audio settings and haven't had any luck.
Does anyone have any suggestions?
Kwils25 is online now   Reply With Quote
Old 10-16-2013, 08:04 AM   #2
Ralph & Shin
Rsknutson's Avatar
Frederick , Maryland
Kwils25,
I also have DNX890 in my 2014 AS. If the controls are not responding as described on page 107 of the Kenwood instruction manual I would contact Kenwood directly to help troubleshoot. I had a problem with the Garmin GPS where the gps would freeze up all the time even after resetting the system several times. It was decided after a conference call between AS customer service and Garmin support to replace the entire system under warranty. There is a firmware update for the DNX890 that was released in May 2013, the update includes fixes but not specifically for audio, but still a good idea to update it after you get past your issue. If you don't have the manual you can download it from Kenwood's website at http://kenwoodusa.com, hope this helps.
_____________
Ralph & Shin
WBCCI #6954
Rsknutson is offline   Reply With Quote
Old 10-16-2013, 10:41 AM   #3
Kwils25's Avatar
Thanks Rsknutson for the post. I've just sent an inquiry into Kenwood.
Old 10-18-2013, 12:57 PM   #4
Kwils25's Avatar
I did get a reply from Kenwood, seems the unit was wired wrong. See the reply below:
"I understand you are experiencing audio issues with your DNX890HD. This usually happens if the vehicle is equipped with a stock amplifier and it is not receiving power from your car stereo. The Kenwood harness has a blue with white stripe cable that can be used to provide power to this amp. If you connected the solid blue wire to the power control of your amplifier, the unit will only provide power while the antenna is being used (FM radio). Once you switch to CD or USB, this wire stops providing your amplifier with power thus you will get no audio."
Now, where do I find the amplifier in order to check this out?
Keith
Old 10-18-2013, 09:25 PM   #5
Boxster1971's Avatar
2013 Interstate Coach
Fulton , Maryland
I'd recommend you take it back to your Airstream dealer for fix if you can.
- - Mike
