Old 02-10-2019, 08:38 PM   #1
skiphoyt's Avatar
Dataw Island , South Carolina
Another AI 19 challenge
I have had numerous, not unexpected issues with our 4 month old AI19. Not unexpected because it was a very early production and the show vehicle at Hershey. With the help of Colonial (long distance) and Mike at Airstream we have sorted out and addressed most issues. One still remaining is the every morning and now even during the day low voltage warning, 11.25 house and start. Batteries were all replaced last month. I will need to get a service appointment and see if they can diagnose and fix it.
NEW PROBLEM! Parked in driveway noticed volts dropping below 12 on house batteries...everything off that could be...decided to try the generator auto start feature... it immediately fired up and ran for about 20 minutes..volts up to 12.25...automatically shuts down...volts drop rapidly and it restarts as expected. I shut generator off. Later went out to run errand and noticed a massive pool of oil under the generator on our new tappy driveway $’s! I will try to see exactly where oil coming from but without a lift not easy. Anyone else experienced a major oil leak? I can’t imagine any oil left in generator at this point with at least a quart on the driveway.
skiphoyt is offline   Reply With Quote
Old 02-10-2019, 08:52 PM   #2
skiphoyt's Avatar
Oil spill
Additional picture of oil from generator.
Old 02-11-2019, 06:22 AM   #3
Long Island , New York
Ugh! Can you back up onto blocks etc. to get some better visuals on the source of the leak? Or you could hold your phone under there and get some shots now, with flash On if needed. Use a flashlight to get some side-lighting of the bottom of the gen, and you might luck out with some productive images IMO.
Good luck,
Peter
Old 02-11-2019, 06:59 AM   #4
Your rig is still under warranty, obviously. Even still, it would be useful to examine the undercarriage and determine where the problem is, as it will probably dictate whether or not you can make a warranty claim (presumably if road debris punctured the generator, that would be covered by your insurance rather than by the new vehicle warranty).
Eventually you may want to get yourself a quad of ramps, which can be either purchased or DIY'd. IMO, it's the safest way to get under the Interstate without paying for a lift. I made ours out of scrap wood that I retrieved from waste piles when our subdivision perimeter fence was replaced. You can see well-worn surfaces here - we use these frequently.
Old 02-11-2019, 11:32 AM   #5
2018 16' Sport
Keene , New York
Replace
We own an AS16 2017 and we had multiple battery issues. We had a factory 12 v Interstate marine deep cycle which we replaced once at the six month point under warranty. Last year we removed them and replaced them with 2 6 volts with 600 mamp capacity and found that they work much better.
Tad Zelski is offline   Reply With Quote
Old 02-11-2019, 01:49 PM   #6
skiphoyt's Avatar
Good luck,
Peter
Thanks Peter...I did talk to Airstream this morning and was informed that service cannot work on Cumming’s generators? They would need to pull the generator and send it to them or have me locate a Cumming’s service center. This all sounded like a huge hassle soooo under the coach I went. Found the dipstick plug just hanging loose and no oil left in generator. It is impossible to fill without some type of syringe due to only about 4” clearance with propane tank. Will sesrch Amazon or put something together to add the oil. The ramps that are mentioned sound like a good investment with all the times I spend under the 4 month old ‘bus’.
Old 02-11-2019, 05:46 PM   #7
So it decided to change its own oil, eh?
We have another model year, but this post might help anyway. We didn't acquire any special equipment. We just sort of "slobbed" it with the partial aid of a funnel we had on hand. Put a tarp underneath so that you can clean up easily.
OIL CHANGE FOR AN UNDERMOUNTED, CONSTRICTED ONAN 2500 LP GENERATOR
Old 02-11-2019, 06:10 PM   #8
skiphoyt's Avatar
Great information
Great post and thank you! On the AI 19 no spare but propane tank much closer than yours...no way to get any type of funnel in position. I did order a $3.00 large syringe with tubing from Walmart. Pick up tomorrow and we’ll see. I think I saw on the cover panel that this 2500 takes .6 of a quart...I will keep a close eye on the fill...dipstick doesn’t show any oil but suspect there is a small amount remaining or I will take drain plug out to find out. From the size of the driveway stain it looks like I dropped 2 quarts! What challenge will tomorrow bring? Bringing back memories of my boating days.
Old 02-11-2019, 06:12 PM   #9
Lily&Me's Avatar
Normal , Illinois
With a brand new rig, I would be cautious on working on it yourself, lest you void your warranty.
You should have the documents on your generator in your materials you received from your dealer, and it would also be under warranty, I would think.
Might call a Cummins place with the generators serial number, and see what they suggest and/or arrange for them to service it under warranty.
Maggie
Old 02-11-2019, 06:21 PM   #10
skiphoyt's Avatar
Maggie
I agree but....if I had not been hands on for the last 4 months it would most likely been in the shop most of the time. It is our daily driver and I have seen parts of this coach that I never expected to view. I am retired, have the time to sort the issues out. We still love our ‘bus’!
Old 02-11-2019, 06:26 PM   #11
Wannabe RV'er in training
Alex AVI's Avatar
2018 Interstate Lounge Ext
High Desert , Las Vegas , Nevada
SKIPHOYT - Part nos. & vid courtesy of WACHUKO on "Onan Oil Change" (if you have not already dug up the ONAN docs from their website):
Alex AVI is online now   Reply With Quote
Old 02-11-2019, 07:04 PM   #12
skiphoyt's Avatar
Thanks Alex AVI...Atwood Gear Pump exactly what I was looking for! Thanks
Old 02-11-2019, 09:02 PM   #13
swilly43's Avatar
escondido , California
Something to consider about your warranty. How much time does it take to damage the generator bearings by running with low oil? If it fails after your warranty runs out, it will be expensive to repair/replace. If it were me, I would contact the responsible party and get a claim in process so that you do not get a nasty surprise later.
swilly43 is offline   Reply With Quote
Old 02-11-2019, 10:02 PM   #14
Thumbs up
Ditto. There are probably Cummins shops near you, Skip.
Good luck,
Peter
Another Challenge. overlander63 Off Topic Forum 203 10-20-2018 01:02 AM
A New Challenge-1963 Overlander rehab project overlander63 1960 - 1964 Overlander 896 04-07-2017 05:48 PM
Deck the Halls - challenge! Janet H Our Community 3 12-20-2003 01:02 PM
An ID challenge afrangos Airstream Motorhome Forums 13 07-14-2003 06:40 AM
take the VIN# challenge femuse Our Community 1 03-17-2003 02:18 PM
