If you ask me, those alarms are just annoying and not super useful. I mean, the awning one could be useful, but we ran into the same problem where it was just slightly not making contact and took a good hour to think about what was the problem as it was our maiden voyage out camping.
There are only certain alarms on the Sprinter, correct? All being described above.
Door alarm when starting with the front doors open (driver door at least)
Step alarm
Awning alarm
Parking brake alarm
Carbon Monoxide detector
Pretty obvious alarm for the smoke detector
We have a sliding door alarm but that’s audible and a warning on the dash
Proximity alarms but on models newer than yours, correct?
We have a Victron inverter/charger alarm which you probably don’t have.
Anyone else know of anything that has an alarm?
Might be your parking brake. They are known to be fussy and I think there’s some info out and about on the internal parts in the arm mechanism failing. Might have an issue with it making contact while driving and sounding the alarm intermittently. You might pull it and try to drive and see if it’s the same alarm/sound.
