Old 07-15-2018, 12:55 AM   #1
Wannabe RV'er in training
Alex AVI's Avatar
2018 Interstate Lounge Ext
High Desert , Las Vegas , Nevada
AMS POWER SHADE Mechanical Limit Adjustment Procedures
Docs on how to properly adjust your power shades mechanical motor limits top limit & bottom limit. Applies to both old or new generation of mechanical limit adjustment
ID:	316954   Click image for larger version
ID:	316956   Click image for larger version
Alex AVI is offline   Reply With Quote
Old 07-22-2018, 05:10 PM   #2
swilly43's Avatar
escondido , California
Thank you for posting the procedure. I found the tools to do this in my documentation folder but I have never been able to get the tools up close enough to the motor to use them. There must be a trick to it but so far I have been stymied on how to access them. I need to replace one set of motors on the drivers side rear. Has anyone located information on how to remove the shades for replacement? I presume, once you have them out, the limit adjustment access would be much improved.
swilly43 is offline   Reply With Quote
Old 07-23-2018, 05:18 AM   #3
Auburn , Georgia
Are the shade motors bad or have they just lost the program signal from the remote ? It is not likely both would go out at the same time without a loss of power to both. You didn't mention trying the reprogramming of the rear DS shades and that could fix it. The first step in reprogramming is holding the small switch located in the shrink tubing ( page 9 of attachment ) and the shade should move down and back up quickly. If the shade moves the motor is OK and just finish the programming instructions.
If the above fails next step would be to check if power wires are making good connections and this would require removal of the wall panel. The screws holding it in place are in the bottom of the overhead cabinets. There are two in the front and one in the rear cabinet, and one that is up above the fold down wing for the bed that you access from the bottom.
File Type: pdf AutoMotion Dual Roller Shade Manual.pdf (1.22 MB, 17 views)
GETRIDAONE is offline   Reply With Quote
2016 GT EXT Shade Adjustment Ynefel Sprinter and B-van Forum 20 10-01-2017 03:56 PM
How About a Collection of Step by Step Repair Procedures? josephhh Airstream Motorhome Forums 32 07-06-2015 10:47 PM
Holding Tank Procedures SilverCabin On The Road... 28 11-14-2007 10:14 AM
WBCCI Forum- Voting Procedures wheel interested WBCCI Forum 14 04-22-2007 05:06 PM
