Old 07-01-2015, 11:43 PM   #15
lewster's Avatar
Naples, FL , Hood River, OR
Optimas in the Group 24 size typically have a 55 amp/hour capacity. Compare this to a Lifeline GPL-24T which has an 80 amp/hour capacity and you can see where the differences begin. A pair of Lifeline golf cart 6VDC batteries (GPL-4CT) have the same footprint as a group 24 battery but being taller, have a 220 amp/hour capacity. Plates on a golf cart style battery are twice the thickness as a group 24, which is where the extra durability is realized.
Lifelines are heavier (more lead), have larger plate surface areas (solid rectangular plates vs. the '6 pack' Optimas) and have a 5 year pro-rated warranty. They are also available in a variety of sizes and voltages.
Old 07-02-2015, 04:14 PM   #16
Boxster1971's Avatar
2013 Interstate Coach
Fulton , Maryland
Originally Posted by c21bill View Post
I have a 14 AI with the 50w panel. How difficult (& costly) would it be to upgrade to the 100w panel that comes on the 15's?
That should be an easy straight forward upgrade. You can likely stay with the same wiring and controller as I'm sure that is what Airstream did.
- - Mike
2013 Interstate Lounge EXT on 2012 Sprinter
- - Mike
Old 07-02-2015, 04:51 PM   #17
73shark's Avatar
2011 Interstate Coach
Overland Park , Kansas
Might want to verify that the existing wire gauge is sufficient to handle the increased current.
You could also speak w/ Robert Kendall (800-261-3602) at Atkinson Electronics that makes the solar controller and display.
Old 07-02-2015, 05:12 PM   #18
Rockwell , North Carolina
I have suspected for some time that my batteries have not been holding a charge. When we recently returned from an overnight camping trip, the batteries were completely charged. I turned off the power and did not plug in just to see what would happen. Less than 24 hours later, they were down to a little over 10 volts.
I found a distributor less than 20 miles away so I removed the batteries. This was a bit more complicated for me as I had to remove the cabinet I had installed on that side. After unloading the cabinet, I removed six screws to unfasten it. I was able to slide it over far enough to get to the battery box.
On the battery box is a sticker warning about live voltage and a recommendation to unhook the ground from the van battery and to unhook the ground wire next to the gas pedal.
The batteries are in a tray. I had a bit of trouble pulling the tray out because the batteries were bulged out on the sides.
The distributor checked the batteries and found one to be down to a little over 9 volts while the other one was a little over 10. They called the Lifeline rep and told them that I had a 2013 AI. They put me on the phone with the rep whose first question was, "Do you always have the motor home plugged in when you are not using it?" When I answered yes, he asked again to be sure. He then proceeded to tell me that Lifeline was somewhat unhappy that Airstream wired the inverter/charger outside the cutoff switch circuit. So the charger is always on and will run down the batteries. Having the AI plugged in all the time was the answer he was looking for. He then said he would ship two new batteries to my house and charge me $139.95 each. I thought that was very fair. I had them the next day.
The rest of the story is that when I bought the AI used the house batteries and the truck battery were both dead. Mercedes replaced the truck battery but the dealer told me that since the house batteries were deep cycle batteries, they would be fine once charged. Also, to complicate matters, I later discovered that the alternator was not charging the house batteries while I was driving due to a blown fuse. If I had known then what I know now, I would have insisted that the dealer replace the house batteries.
My unit is an early 2013 so it has the Tripp Lite inverter. After my conversation with the Lifeline rep, I called Tripp Lite to ask if it was OK to always have the AI plugged in while in storage. They said it would be fine to do that as it has a sensor so keep if from overcharging. That goes against some of the things I have read here. I am assuming the factory knows their equipment well enough to give me a straight answer. I did not tell them what had prompted the call.
jerhofer is offline   Reply With Quote
Old 07-02-2015, 05:31 PM   #19
73shark's Avatar
Make sure the A1 dip switch is in the up position for AGM batteries.
So the 2013 has moved the batteries out of the hole and put them on the floor level? Did they remove the battery box?
Old 07-02-2015, 09:04 PM   #20
lewster's Avatar
Nope,
The black steel battery box is still there.....vented thru the sidewall of the van. I typically remove it, as it allows for the installation of larger AGMs with no issues. You will have to elevate the space in the floor that accommodated the steel box....... and don't forget that your generator positive cable runs thru the floor in the same location and IS NOT MARKED.
PS: if you upgrade to the Magnum MMS-1012, you won't have to worry about leaving in plugged in 24/7/365, as it's charging section is a lot smarter than the TrippLite's.
Old 07-02-2015, 09:15 PM   #21
Nope,PS: if you upgrade to the Magnum MMS-1012, you won't have to worry about leaving in plugged in 24/7/365, as it's charging section is a lot smarter than the TrippLite's.
Is there a large enough advantage to justify the cost? How difficult is the installation? Does the installation involve changes to the control panel in the overhead cabinet?
Old 07-03-2015, 09:43 AM   #22
lewster's Avatar
Hey Jerry,
That depends on what you consider advantage. Cost of batteries, time spent worrying about proper charging from the TrippLite, not getting sufficient charge from 'dip switch settings', etc would be enough for me to pull the trigger on a Magnum. Basically, plug in the coach and forget it's there and have the batteries at 100% when you are ready to use it.
The swap under the lounge is fairly simple. You will need their ME-RC remote for proper monitoring and programming of the charger section, but the communication cable is re-usable. Upgrading the cables to 1/0 would be required as well, and I use a class 'T' inverter fuse to replace the little ANL type that Airstream uses.
You can even add Magnum's ME-BMK, which is a shunt controlled full function battery monitor which reads directly thru the new remote panel.
Best part........it is fully compatible with the new lithium battery charging requirements should you decide to go in that direction in the future.
Old 07-03-2015, 10:05 AM   #23
2015 Interstate Ext. Coach
New Orleans , Louisiana
Magnum Fan Runs Constantly
Hi,
I managed to drain the house batteries on my 2015 Grand Tour. They recharged yesterday. I'm trying to figure out what pulled them down in a few days. I left it unplugged last night and the batteries were down a bit this morning. I have noticed that the Magnum fan (in this unit behind the power distribution panel on the street side seat) runs constantly. It's hot and quite humid here, but is this normal? The battery disconnect switches off all of the usual suspects (propane valve, sensor, tv signal boost). Any guidance on tracking down other potential parasitic draws?
We've also few sunny days, so I'm not getting a lot of help from the solar...
thanks/r
NOLA_russ is offline   Reply With Quote
Old 07-03-2015, 10:44 AM   #24
UKDUDE's Avatar
2014 Interstate Ext. Coach
Sedona , Arizona
Originally Posted by NOLA_russ View Post
Hi,
thanks/r
Are you perhaps leaving the inverter on - from the Magnum control panel? That would drain the batteries pretty quickly and would probably cause the Magnum fan to run excessively. Even using the battery disconnected switch, it doesn't disable the Magnum and several other monitoring and system resources, and it's easy to leave the inverter on.
Old 07-03-2015, 10:48 AM   #25
I thought as soon as I hit send that I needed to add that the inverter is off. You're right though, it's an easy one to miss. It'd be great to have a "turn everything off, really" button....
Old 07-03-2015, 11:42 AM   #26
lewster's Avatar
Do you not have an inverter disconnect switch in the positive inverter feed between the fuse and inverter? I add this to all of my inverter installations.
Great to isolate the inverter for hard re-sets and isolation purposes.
Lew Farber
AM Solar Certified Installation Center
Lifeline Batteries**Magnum Inverters
541-490-6357
Old 07-03-2015, 01:41 PM   #27
Fulton , Maryland
Airstream does not install an inverter cut off switch. The battery cut off they do install cuts off very little. I plan to rewire mine so the battery cut off shuts off all house battery functions. I also have a cut off for my solar panels as recommended by AM Solar when I bought my system form them.
- - Mike
- - Mike
How Amazingly Stupid (on my part) DryFly Electrical - Systems, Generators, Batteries & Solar 2 08-04-2013 12:01 AM
Very Pleased Sbb Our Community 5 05-28-2013 08:18 PM
Pleased with how she shines!! airstrmkids Cleaning, Stripping & Polishing 4 05-12-2011 12:39 AM
Amazingly designed full-time homes audiv8q Full-Timing, Winter Living & Workamping 32 05-11-2011 02:13 PM
Very pleased rgyhiljoy Member Introductions 0 05-13-2006 11:34 AM
