Old 09-10-2013, 11:33 AM   #1
2014 Interstate Ext. Coach
melrose , Massachusetts
aluminum wheel cleaner
My wheels have a haze on them that doesn't wash off - what should I use to polish them - thanks
jennian is offline   Reply With Quote
Old 09-10-2013, 03:52 PM   #2
UKDUDE's Avatar
Sedona , Arizona
The Alcoa wheels are supposed to have a highly polished finish from new; the Alcoa instruction manual says you should wash them with high pressure washer and mild detergent. And then polish them with a quality automotive polish.
http://www.alcoa.com/alcoawheels/cat...al-English.pdf
If they were tarnished from new, ask your dealer to replace them under the warranty.
Old 09-10-2013, 04:25 PM   #3
UKDUDE's Avatar
Sedona , Arizona
Actually I just checked the part number on mine - 250802. The trailing '2' apparently means the highly polished surface is on the inside - meaning the outside of the outside rear wheels. So I guess the fronts don't show any polished finish and you may have to use a brush on them.
Old 09-10-2013, 05:54 PM   #4
AtlantaCpl's Avatar
2013 Interstate Coach
Atlanta , Georgia
I made the mistake of using Mothers tire foam cleaner on mine as it specifically said it was non acidic and ok for aluminum wheels. Unfortunately it is for wheels that have a clear coat applied and when used on the Interstate polished aluminum rims without a clear coat managed to etch the wheels in less than 2 minutes I had it on there. Many new and innovative curse words were created on this day.
I had to invest in a PowerBall, PowerCone, and some aluminum polish. Blue Magic and Mothers Billet polish seemed to be the favorites in the auto forums. I got both from Amazon and tried each with the PowerBall to see which worked better. No perceptible difference. Both took care of the haze but I'm waiting for cooler fall weather to pull off the lug nuts and get in the tight spaces. What a pain in the butt.
Your question reminded me I meant to post this experience so others would not make the same mistake.
AtlantaCpl is offline   Reply With Quote
Old 09-10-2013, 06:36 PM   #5
2010 25' FB Flying Cloud
Davenport , Iowa
what about the Mr Clean eraser?
Airtandem is offline   Reply With Quote
Old 09-11-2013, 08:49 AM   #6
73shark's Avatar
2011 Interstate Coach
Overland Park , Kansas
It's too bad Airstream didn't use the Alcoa Dura-Bright wheels. Alcoa adds something to the alloy to prevent tarnishing.
I use Meguiar's Power Cone and Mothers aluminum polish.
Old 09-11-2013, 08:59 AM   #7
Wingeezer's Avatar
2005 30' Classic
Burlington , Ontario
I use Mother's Mag & Aluminium Polish + elbow grease & blue nitrile gloves!!
Works well on my Alcoa wheelsl
Brian
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
Old 09-11-2013, 09:17 AM   #8
73shark's Avatar
Yes gloves are a necessity unless you want to have black fingers for several days. I use Simple Green to wash off any brake dust before polishing also.
Old 09-11-2013, 07:51 PM   #9
Boxster1971's Avatar
Fulton , Maryland
Best I can tell from the Alcoa web site the Sprinter 3500 wheels are not available with their Dura-Bright finish.
- - Mike
Boxster1971 is online now   Reply With Quote
Old 09-11-2013, 08:04 PM   #10
73shark's Avatar
Could be. I thought they were when I checked a couple of years ago but may have not looked at the right place.
I bought mine used w/ 4K on it and the wheels were water spotted and while I can make them shine, can't get the residual from the spots completely off. Probably would have to use a buffing wheel and I'm not that concerned w/ them. They don't show unless you get real close.
Old 09-12-2013, 06:38 PM   #11
Teamaron's Avatar
Boca Raton , Florida
http://www.amazon.com/gp/aw/d/B000EAPSMQ
Try this
I've tried many and the results speak for themselves.
Teamaron is offline   Reply With Quote
« Bedding | Top | newbie »
