Old 05-25-2015, 11:04 AM   #1
2013 Interstate Coach
Flemington , New Jersey
Alcoa Wheels
Does anyone have an effective procedure to remove the oxidation and heavier pitting / gunk on the non dura-brite Alcoa wheels?
The regular polishing compounds only go so far.
Mario
2013 Interstate
2014 Little Guy 5x10 Silver Shadow
Tiato is offline   Reply With Quote
Old 05-25-2015, 11:54 AM   #2
Missouri Valley , Iowa
Mario,
I have used Mothers Aluminum polish with the mandrel / sponge type polishing tools also from Mothers. The tool goes in your drill and does a pretty good job with the polish. An even better polishing liquid I found is the Wicked Metal Polishing. To remove pitting though, I think you will need to have that done at a truck detailing shop. I have taken wheels from my trailer or our semis to the Freightliner Detail Shop in Omaha, NE. My 15" trailer wheels were about $35 each a couple years ago. To remove clearcoat and polish 4 wheels 2 years ago was $270.
Dan
Farmer Dan is offline   Reply With Quote
Old 05-25-2015, 03:40 PM   #3
73shark's Avatar
2011 Interstate Coach
Overland Park , Kansas
I've found that the non-Dura Bright wheels, it's best to polish after each trip. Just trying to get water spots off is a career.
Old 05-25-2015, 06:30 PM   #4
Boxster1971's Avatar
Fulton , Maryland
To remove small pits and heavy brake dust build-up I use the finest grade Scotch-Brite pad. It's equivalent to 0000 steel wool. It does make the surface dull but clean. Then I polish them using a polishing compound and the Mothers foam tools in a cordless drill.
It's a real chore so I only due it once or twice a year. I've been thinking one of these times I'll just leave the wheels dull from the first step using the Scotch-Brite pad.
- - Mike
2013 Lounge EXT on 2012 Sprinter
- - Mike
Old 05-25-2015, 11:00 PM   #5
2015 Interstate Ext. Coach
Bellevue , Washington
I appreciate my dura-brite Alcoa wheels. bare aluminum wheel is such a chore.
s2kysk is offline   Reply With Quote
Old 05-26-2015, 09:04 PM   #6
X New Yorker
X New Yorker's Avatar
Springfield , Massachusetts
Would wheel covers prevent this headache? I'm soooooo tired of hearing about my ugly rims!!!!
Once these are clean and shinny AGAIN, it there something to keep them that way?
And... why did Alcoa make and Airstream use such an inferior product? I never had this issue with any of my car rims (stock or after market).
X New Yorker is offline   Reply With Quote
Old 05-26-2015, 11:06 PM   #7
73shark's Avatar
I thought AS started using the Dura-Bright wheels in 2013. If so, they're supposed to just need washing. But it sounds like yours aren't.
I'll bet none of your previous aluminum wheels were bare. IOW, they were clear-coated which can be problematic in its own right. Brake dust can ruin it and wheel weights will break the clear-coat down and then oxidation sets in. Ugly. Nice thing about the new flange-less wheels, no weights on the outside.
Old 05-27-2015, 05:31 AM   #8
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
I'm primarily a trailer guy, and not that familiar with the Sprinter chassis. That said, this sounds like an issue we had years ago, when semi-metallic pads first came into common use. Is there a ceramic pad available for these motor homes? It would greatly reduce brake dust and pitting.
Old 06-02-2015, 06:02 PM   #9
Teamaron's Avatar
2014 Interstate Ext. Coach
Boca Raton , Florida
Name:	ImageUploadedByAirstream Forums1433289633.122853.jpg
This has worked best for me. But it doesn't last forever. It seems they still oxidize over time.
Teamaron is offline   Reply With Quote
Old 06-02-2015, 08:56 PM   #10
73shark's Avatar
Short of clear coating, bare aluminum is hard to protect since it's a relatively active material. So I've found it best to just polish after each trip. And clear coat has its own set of problems.
Pitted Alcoa wheels SeanWilmNC Land Yacht/Legacy Motorhomes 13 07-06-2017 03:57 PM
Alcoa wheels gusser Member Introductions 4 10-10-2007 08:35 AM
New ALCOA wheels on my old Airstream MelloMike Brakes & Brake Controllers 2 07-20-2004 03:08 PM
