Old 07-13-2019, 08:19 AM   #1
2017 Interstate Grand Tour Ext
Dayton , Montana
Airstream Weber Grill
I had trouble getting my old portable gas grill to heat up when I plugged into the quick connect gas outlet. I broke down and bought the Airstream branded grill for RV low pressure propane systems. It is really light except for the incredibly heavy cast iron grills. Lots of aluminum and plastic. I heated it up to burn it in before I put my filet on it. It took a little while to bring to heat but it got up to 475 before i killed it.
I will let you know how she cooks next time out. But it is a big upgrade from my old setup.
ID:	346279   Click image for larger version
Pez Vela is offline   Reply With Quote
Old 07-13-2019, 08:54 AM   #2
Gsmblue's Avatar
2015 25' Flying Cloud
Bend , Oregon
Those grills are great! I don’t have the airstream branded one, but i am sure it performa the same!
http://britishairstream.blogspot.com
Mad Astrophysicist turned sales guy that works to fund his dirty snowbaording habbit, mwah-ha-ha . . .
Gsmblue is offline   Reply With Quote
Old 07-13-2019, 10:29 AM   #3
Baby Zeppelin's Avatar
2018 28' Flying Cloud
Suwanee , Georgia
Originally Posted by Gsmblue View Post
Those grills are great! I dont have the airstream branded one, but i am sure it performa the same!
Same here. Got the Q 1100, removed the regulator and installed hardware and hoses as needed to connect to the LP port beneath/beside the battery box. Works great.
Erik & Carol
Suwanee, Georgia
AS: 2018 Flying Cloud 28 "Baby Zeppelin"
TV: 2017 Ford F250 Lariat w/ Blue Ox Sway Pro
AIRForums #126944 WBCCI #1297
Baby Zeppelin is offline   Reply With Quote
Old 07-13-2019, 04:28 PM   #4
mikeinca's Avatar
2018 30' Classic
Santa Rosa , California
Nice! How long is the feeder hose? Can you get a reasonable distance away from the low pressure source on the AI/trailer when you grill?
The good thing about science is that it's true whether or not you believe in it.
― Neil deGrasse Tyson
2018 30' Classic Twin
2017 F250 4x4 6.7 max tow Platinum
200W portable solar
240Ah LifePo4 upgrade
mikeinca is offline   Reply With Quote
Old 07-13-2019, 06:48 PM   #5
Tom Nugler's Avatar
1972 25' Tradewind
McHenry County , Illinois
These are perfect grills for light to medium duty camp cooking.
We bought the predecessor to your grill, a Baby Q, back around 2005-06. Cleaned after every trip, still lights first or second push, grate, burner and body still in excellent shape.
This is the most versatile grill I've ever owned.
I suspect if you ever sell the Airstream the grill won't be part of the package.
Tom
AirForums # 2806
WBCCI / VAC # 6411
Not All Who Wander Are Lost.
Avid supporter of trailing edge technology.
Tom Nugler is offline   Reply With Quote
Old 07-13-2019, 07:11 PM   #6
gator.bigfoot's Avatar
KW , Ontario
Bought the first one one 2007. Weber Q200 then later bought the Q100 in 2012. Found that the smaller version actually is a better fit for us. I pull the lid off to get into the storage compartment in the back of the AS. I also have the stand, which works great.
gator.bigfoot is offline   Reply With Quote
Old 07-14-2019, 09:49 AM   #7
UncleBad's Avatar
2018 27' Tommy Bahama
Oro Valley , Arizona
Could someone post a picture of the Airstream branded Weber grill hose and connection side on the Weber?
I am not able to see the entire hose in the pictures above, thank you!
2018 27FBQ Tommy Bahama - "Indecision" w/Blue Ox SwayPro, Centramatics, Dual EasyStarts, Airstream Connected, Airtug Trailer Tug HD
2012 F250 6.7 Powerstroke King Ranch - "Earl", Centramatics, Viair On Board Air
UncleBad is offline   Reply With Quote
Old 07-14-2019, 11:34 AM   #8
Dayton , Montana
More pictures for size and request
ID:	346541   Click image for larger version
Old 07-14-2019, 12:08 PM   #9
2011 23' Flying Cloud
Durango , Colorado
Looks like my original Weber Q xxx which has performed exceedingly well for 8 years. Id rather use it at a greater distance from the trailer, though, so the little propane bottles work for me.
Safe Travels,
Joe & Joan Donnaway
Durango, CO
JamuJoe is offline   Reply With Quote
Old 07-14-2019, 06:52 PM   #10
UncleBad's Avatar
Thanks for the pictures!
So the hose looks like a normal, long, quick connect hose.
Is there a pressure regulator on or built into the grill?
Old 07-14-2019, 06:57 PM   #11
Boxster1971's Avatar
2013 Interstate Coach
Fulton , Maryland
To use the Weber Q with a low pressure source like the external connector on an Interstate you will need to remove the built-in regulator on the Q grill. It was mentioned earlier in this thread.
- - Mike
Old 07-14-2019, 07:06 PM   #12
mikeinca's Avatar
2018 30' Classic
It's true that the Weber models in general have a pressure regulator which makes them incompatible with the low pressure source on our Airstreams.
The idea behind the specific AS/Weber branded grill that the OP just bought is that it has no regulator at all so that it will work, without modification, with the low pressure propane source on the trailer or coach. AFAIK, this Airstream/Weber Q grill is only available from the Airstream store.
200W portable solar
Old 07-14-2019, 07:13 PM   #13
Prof. of Pending Projects
wachuko's Avatar
2018 Tommy Bahama Interstate
Orlando , Florida
Links to purchase: Weber Q1200 Airstream Grill
And an Airstream article - link
Safe travels!
Wachuko
WBCCI #26769
2018 Airstream Interstate 3500 Lounge EXT Tommy Bahama w/ARS
wachuko is offline   Reply With Quote
Old 07-14-2019, 07:41 PM   #14
Wannabe RV'er in training
Alex AVI's Avatar
2018 Interstate Lounge Ext
High Desert , Las Vegas , Nevada
.that really nice grill from Airstream Weber
Alex AVI is offline   Reply With Quote
The Perfect BBQ Grill and Awning for my New Airstream sthrngary 2016 - Current Flying Cloud 41 04-14-2019 07:49 AM
Rare Tito’s Custom Airstream Grill di-dc Airstream Classifieds 0 09-12-2018 08:47 AM
Rare Tito's Custom Airstream Grill AirstrmQueen Airstream Classifieds 1 02-16-2017 02:00 PM
rd webber - tow combo? R. D. Webber Member Introductions 8 10-27-2007 08:28 PM
