Old 02-22-2015, 09:01 AM   #1
Glamper1's Avatar
Airstream interstate training video available soon
Yesterday I paid $130 to have Airstream in Fairfield California
training me on my 2014.5 AI.
I bought mine in Tuscon Arizona but didn't receive great training
so I thought some retraining would do me good.
Tomorrow I will post a link so that everyone here
have access.
It's about 51 minutes long and pretty good.
Stay tuned.
Best,
Ben
Glamper1 is offline   Reply With Quote
Old 02-22-2015, 02:00 PM   #2
k9jackie's Avatar
2015 Interstate Ext. Coach
Great Falls , Virginia
Awesome! I am glad I recorded my training but I didn't record everything I should have
k9jackie is offline   Reply With Quote
Old 03-01-2015, 02:19 PM   #3
Glamper1's Avatar
Here is the video... http://view.vzaar.com/2881217/video
Old 03-01-2015, 05:08 PM   #4
73shark's Avatar
2011 Interstate Coach
Overland Park , Kansas
Originally Posted by Glamper1 View Post
Good video.
You can reach the front low point drain valves w/o completely removing the drawer which makes it a little easier. Not sure I'd use the pump to drain the fresh water tank when you can just remove the drain plug in the tank unless Airstream eliminated it. Also for winterizing, it's much easier to put the RV antifreeze in the fresh water tank and let the pump circulate it thru the system. Lot easier and less messy.
Old 03-01-2015, 06:51 PM   #5
Boxster1971's Avatar
2013 Interstate Coach
Fulton , Maryland
Originally Posted by 73shark View Post
Good video.
But getting the favor of the antifreeze out of your fresh water tank takes a lot of rinsing cycles. I added the device from Camping World that lets me fill the water lines with anti-freeze with the water pump. I then leave the fresh water tank empty all winter and then add a bit of bleach in the spring when I reactivate the water systems. I usually winterize mine two or three times a year as I make trips from frozen Maryland to warmer places in Florida and other points south.
- - Mike
2013 Lounge EXT on 2012 Sprinter
- - Mike
Boxster1971 is online now   Reply With Quote
Old 03-01-2015, 07:14 PM   #6
73shark's Avatar
I only put a couple of gallons in which just barely covers the bottom of the tank. Just rinse by running the hose for a couple of minutes w/ the drain plug out. Never noticed any after taste.
Old 03-02-2015, 09:17 AM   #7
k9jackie's Avatar
thanks for sharing
Old 03-02-2015, 01:48 PM   #8
Ron_CA's Avatar
San Diego , California
I quit watching right after the "teacher" said to get an inline water filter and then mentioned the potential high pressure from outside water sources as the reason
Ron_CA is offline   Reply With Quote
Old 03-02-2015, 04:37 PM   #9
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
There is still a drain plug, of course. Draining the fresh tank by pumping as much water out as possible just means to USE the water for something, anything, before dumping the remainder. No point in wasting perfectly good water if you don't have to.
One possibility is to attach a 25-foot hose to your external shower fitting, and use your fresh water to wash the outside of the van. You can use up most of a tank in giving it a thorough rinse.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 03-02-2015, 07:14 PM   #10
73shark's Avatar
But he wasn't telling him to "use" it, just pump it out thru the low-point drains.
Old 03-02-2015, 08:21 PM   #11
Fulton , Maryland
Glamper1 - the video is not showing up as full screen image on my PC. It looks like a cropped image that is mostly blacked out. It this right?
Old 03-02-2015, 08:24 PM   #12
That IS kind of pointless. I like my version better.
WBCCI #1105
TAC LA-4
Old 03-02-2015, 08:31 PM   #13
73shark's Avatar
It is the way it was shot. Suspect cell phone held vertically instead of horizontal.
Old 03-02-2015, 08:33 PM   #14
Fulton , Maryland
OK - thanks
Soon to be gone reservations available at Long Key State Park, FL n2916s On The Road... 0 12-07-2014 06:46 PM
USB Input available with Audio/Video Upgrade package Wayward Audio, Video & TV 4 04-30-2013 05:39 PM
Free Airstream parts may be available soon. dsakaki General Interior Topics 9 10-17-2005 08:35 AM
