02-22-2015, 09:01 AM
Airstream interstate training video available soon
Yesterday I paid $130 to have Airstream in Fairfield California
training me on my 2014.5 AI.
I bought mine in Tuscon Arizona but didn't receive great training
so I thought some retraining would do me good.
Tomorrow I will post a link so that everyone here
have access.
It's about 51 minutes long and pretty good.
Stay tuned.
Best,
Ben
02-22-2015, 02:00 PM
2015 Interstate Ext. Coach
Great Falls
, Virginia
Awesome! I am glad I recorded my training but I didn't record everything I should have
03-01-2015, 02:19 PM
03-01-2015, 05:08 PM
2011 Interstate Coach
Overland Park
, Kansas
Originally Posted by Glamper1
Good video.
You can reach the front low point drain valves w/o completely removing the drawer which makes it a little easier. Not sure I'd use the pump to drain the fresh water tank when you can just remove the drain plug in the tank unless Airstream eliminated it. Also for winterizing, it's much easier to put the RV antifreeze in the fresh water tank and let the pump circulate it thru the system. Lot easier and less messy.
2011 Interstate SOLD! Upfitted 2017 Transit 350. SOLD!
03-01-2015, 06:51 PM
2024 Interstate 19
Fulton
, Maryland
Originally Posted by 73shark
Good video.
But getting the favor of the antifreeze out of your fresh water tank takes a lot of rinsing cycles. I added the device from Camping World that lets me fill the water lines with anti-freeze with the water pump. I then leave the fresh water tank empty all winter and then add a bit of bleach in the spring when I reactivate the water systems. I usually winterize mine two or three times a year as I make trips from frozen Maryland to warmer places in Florida and other points south.
- - Mike
2013 Lounge EXT on 2012 Sprinter
- - Mike
2024 Airstream Interstate 19e AWD
Previous: 2013 Airstream Interstate 3500 Ext Lounge
03-01-2015, 07:14 PM
Overland Park
, Kansas
I only put a couple of gallons in which just barely covers the bottom of the tank. Just rinse by running the hose for a couple of minutes w/ the drain plug out. Never noticed any after taste.
03-02-2015, 09:17 AM
Great Falls
, Virginia
thanks for sharing
03-02-2015, 01:48 PM
San Diego
I quit watching right after the "teacher" said to get an inline water filter and then mentioned the potential high pressure from outside water sources as the reason
03-02-2015, 04:37 PM
Figment of My Imagination
2012 Interstate Coach
From All Over
, More Than Anywhere Else
There is still a drain plug, of course. Draining the fresh tank by pumping as much water out as possible just means to USE the water for something, anything, before dumping the remainder. No point in wasting perfectly good water if you don't have to.
One possibility is to attach a 25-foot hose to your external shower fitting, and use your fresh water to wash the outside of the van. You can use up most of a tank in giving it a thorough rinse.
03-02-2015, 07:14 PM
Overland Park
, Kansas
But he wasn't telling him to "use" it, just pump it out thru the low-point drains.
03-02-2015, 08:21 PM
2024 Interstate 19
Fulton
, Maryland
Glamper1 - the video is not showing up as full screen image on my PC. It looks like a cropped image that is mostly blacked out. It this right?
03-02-2015, 08:24 PM
From All Over
That IS kind of pointless. I like my version better.
03-02-2015, 08:31 PM
Overland Park
, Kansas
It is the way it was shot. Suspect cell phone held vertically instead of horizontal.
03-02-2015, 08:33 PM
2024 Interstate 19
Fulton
, Maryland
OK - thanks
03-03-2015, 08:08 AM
On an Ipad if u have one for full enlargenent double tap the screen
03-03-2015, 04:30 PM
Overland Park
, Kansas
Does that change the format from portrait to landscape or just make it fill the screen w/ the same proportions?
03-03-2015, 04:38 PM
2024 Interstate 19
Fulton
, Maryland
I tried the video on my iPad and you can just change the orientation from landscape to portrait, which is obviously how the video was shot.
The only part of this video that confuses me is the claim by the dealer rep that you have to start the engine to get the battery isolator to close and allow charging all batteries by plugging into shore power. The Precision BIM has built in logic to charge the vehicle starting battery when plugged in based on measuring the voltages - so starting the engine is not necessary.
- - Mike
- - Mike
03-03-2015, 04:44 PM
From All Over
Not the first time a dealer rep has misunderstood technical specs.
