Old 06-14-2014, 04:49 PM   #1
Anacortes , Washington
Airstream Interstate sink faucet parts
I have a 2007 Interstate which came with Dometic SMEV Model VA 736 sink.
This has a round black glass top which raises up to reveal the stainless steel sink with fold down faucet. You swing up the faucet and this has a moveable goose neck through which the water flows when you operate the tap.
The goose neck part fits into the faucet body and is held there by a threaded ring. You can easily remove the goose neck if needed by unscrewing the threaded ring which is of chrome plated plastic construction.
This ring pretty well disintegrated on our sink -- it ended up in five pieces. I need to replace this and have not been able to find any place who sells these. Many RV parts departments do have a sinilar chrome plated threaded plastic ring so we bought one but found the threads don't match up -- Guess since this sink is made in Italy they have metric threads. Anyway the piece we got from Camping World does not fit and so far have been unsuccessful finding the right part.
Has anyone out there had the same problem and where can I find the correct replacement part? Any and all comments welcomed.
Thanks in advance.
Interstate20 is offline   Reply With Quote
Old 06-14-2014, 05:19 PM   #2
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Might try here: Dometic WAECO International - SMEV Mobile kitchen solutions for caravans & motorhomes
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 06-14-2014, 05:45 PM   #3
Boxster1971's Avatar
2013 Interstate Coach
Fulton , Maryland
Have tried an Airstream dealer that services Interstates?
- - Mike
Old 06-14-2014, 09:33 PM   #4
BikerBill
2014 Interstate Ext. Coach
Poconos of Pa , Pennsylvania
Good luck. Our 2014/13 is basically the same sink. It leaked at the gooseneck where the plastic ring you speak of is. Could not get parts and all it needed was a new washer, which I could have gotten myself. But my dealer was a sent a whole new spigot assembly from AI and all it needed was the gasket. Last I looked the whole spigot was available from a RV company in Wash. state, that deals with the Canadian distributor and the cost was over $200. AI did not want the old one back either. So some other lucky soul got it as spare parts.
Bikerbill is offline   Reply With Quote
Old 06-17-2014, 08:59 PM   #5
Looking for sink tap parts
Here's an update about my quest to get a replacement threaded ring holding the sunk gooseneck in place.
Thanks for the suggestions -- Mr. Protag I did contact the place you kindly mentioned -- it is a dealer in Germany and I got a prompt reply but sadly all they suggested was to go out and buy a whole new faucet. I had earlier emailed another Dometic dealer this time in the UK and basically got the same reply. It is beginning to look like no-one sells just minor sink parts. I did contact our local dealer but they were not much help.
Old 06-18-2014, 05:14 AM   #6
Lily&Me's Avatar
Normal , Illinois
Perhaps try a Menard's, Home Depot, Lowe's, etc., which carry bits and pieces of all sizes.
This gasket may likely be a standard size, placed in this specialized part.
If those fail, I would suggest a plumbing supply place. We found water heater plugs in one of these, and picked up a couple as they are hard to find.
Maggie
Old 06-18-2014, 12:18 PM   #7
Fulton , Maryland
Maggie
This is good advice.
I took a look at the SMEV catalog and the sink is sold without the faucets. They sell the faucet set as an added option. This is probably why neither Dometic or Airstream have replacement part for faucets. We'll need to determine the faucet manufacturer or try a plumbing supply place.
It also looks like a marine supply place might help as these faucets are more of a marine item than an RV item. This one is close:
Whale Faucet Compact Single Chrome - Star Marine Depot
- - Mike
Old 06-18-2014, 01:47 PM   #8
Lily&Me's Avatar
Normal , Illinois
Of course. I hadn't thought of a marine supply place. They are a good source for lots of items for small RV's.
Maggie
Old 06-18-2014, 07:01 PM   #9
Sebastopol , California
I have found the most obtuse plumbing and electrical parts at Grainger's. Their catalogue is about 5" thick and my bet is what you want is in there.
Sebtown is offline   Reply With Quote
Old 06-18-2014, 08:21 PM   #10
UKDUDE's Avatar
Sedona , Arizona
I just took a close look at my faucet. It has a very faint label on the on/off tap: "ARGO". Searching on the internet I found a single reference to a company in Italy, but absolutely nothing else.
I believe the faucet is packaged with the sink, and the sink is made by SMEV, which is part of the Dometic group. I think you should follow it up with Dometic.
Old 06-18-2014, 10:23 PM   #11
Fulton , Maryland
Not surprised it would be an Italian item like the side step. Here is the Argo faucet web site in English, but they don't have much infor there other than that they make faucets for RV (caravan) and boat manufacturers.
benvenuti su Rubinetterie ARGO
- - Mike
Old 06-19-2014, 04:25 AM   #12
Lily&Me's Avatar
Normal , Illinois
Seriously, think simple rather than complex, standard rather than specialized.
I'd bet money this gasket can be replaced thru a Menard's, etc. or plumbing supply place.
Maggie
Old 06-19-2014, 05:17 AM   #13
BikerBill
I think if you reread the original post it was not a "gasket" that disintegrated. It was the chrome plated plastic nut that secures the gooseneck to the faucet base. And that would be metric thread and/or a specially made part. yes, try Grainger, but doubtful. A new complete faucet is available from some company in Seattle for like $200 or so. Mine was just the gasket which was easily replaceable.
Old 06-19-2014, 06:31 AM   #14
Lily&Me's Avatar
Normal , Illinois
You're right, Bill, my error in terminology.
I would still recommend a more rudimentary search, first, especially before replacing the unit for want of a small part.
It may be available, or someone in these stores could help locate a source.
Maggie
need new bath sink faucet KHarris Sinks, Showers & Toilets 3 09-05-2006 10:31 PM
leaky bath sink faucet maxandgeorgia Sinks, Showers & Toilets 1 08-05-2006 02:19 PM
One sink, two sinks, red sink, blue sink? Janet H General Interior Topics 7 07-26-2006 06:17 PM
not enough hot water from kitchen sink faucet codybear Fresh Water Systems 3 01-24-2006 10:20 PM
single hole faucet for kitchen sink IPM Airstream Motorhome Forums 8 08-10-2004 07:17 AM
