Old 06-27-2016, 05:42 PM   #1
Paul Dobbin's Avatar
1994 35' Land Yacht Diesel
Franklin NC , North Carolina
Airstream Interstate & towing
We've been Airstream Land Yacht Forum participants for a dozen years and are thinking of downsizing. Our Land Yacht has a 230 HP Cummins Diesel and a 6 speed Allison Automatic transmission. We tow an aluminum car trailer with an antique car, weights approaching 5000 lbs at times. We have plenty of torque and power to get up to merge speeds on Interstate Highways. Only problem is we're to long for comfort (35 + 20 = a small train in small towns)
QUESTION: How good are the Airstream Interstates at towing? Suggestions and comments welcome.
Paul
"The Roadhouse" our Land Yachts name
Paul Dobbin is offline   Reply With Quote
Old 06-27-2016, 06:16 PM   #2
Bellevue , Washington
While I have not done it, a recent thread I read had pretty positive reports on it. See http://www.airforums.com/forums/f240...ng-129776.html
amirm is offline   Reply With Quote
Old 06-28-2016, 03:16 AM   #3
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
A stock Interstate makes an entirely adequate tow vehicle for any trailer (or toad) up to 5000 pounds. However, it can be made better by the addition of a RennTech ECU tune, which provides a boost to the horsepower and torque, though at a penalty to fuel economy at speeds over 60mph.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 06-29-2016, 12:45 PM   #4
Loma Mar , California
Not a lot of experience with towing with our 2016 Interstate....
.... but last summer I towed a 1,500 pound 16' Alumina dual axel trailer with a 2,500 sports car on it for a over a hundred miles.
In preparation I centered the car on the trailer (center of gravity) and checked visually the tongue weight that seemed right, towing was truly excellent. I was very surprised.
I would do it again and for longer distances.
Haasman
Haasman is offline   Reply With Quote
Old 06-29-2016, 02:47 PM   #5
Houston , Texas
I've towed 4300 lbs with an Acura MDX and it has done better than most framed trucks with 17+ mpg for over 3500 miles. I've had two lighter loads on the '16 AS GT (1700 and 2500 lbs) and it has done just fine. In October it will get tested with the 4300 lbs (aluminum trailer with an NSX onboard). Brake controller is already installed. I suspect it will do as good if not better than the MDX.
Mcrider is offline   Reply With Quote
Old 06-30-2016, 10:10 AM   #6
PSchw's Avatar
2005 39' Skydeck 390 SD
Livingston , Texas
I tow a 2007 Honda Element fully loaded with my none extended 2013 Interstate and u get about 17 to 15mpg all of course depending on your driving style.
The none extended has the benefit of more capacity and shorter overhang.
Peter
PSchw is offline   Reply With Quote
Old 06-30-2016, 03:24 PM   #7
Gainesville , Florida
When I had my early model AI, I towed a 19 foot Bambi. It was adequate and redundant.
Old 07-02-2016, 02:08 PM   #8
The SilverSleeper
Beaubill's Avatar
1992 25' Excella
1988 23' Excella
Daphne , Alabama
Our Condo
This is our 2BR 1&1/2 bath. Boondocks in summer use generated and a/c in the van, in the winter use the heat in the trailer. Some times we hook up both in the campground that have 50 & 30amp service, can run both refrigirater son elec. MPG 14.5 to 17.3
ID:	265773   Click image for larger version
Beaubill is offline   Reply With Quote
Old 07-02-2016, 06:30 PM   #9
Hittenstiehl's Avatar
1961 28' Ambassador
1961 19' Globetrotter
Mesa , Arizona
Beaubill very nice set up, best of both.
Hittenstiehl
Hittenstiehl is offline   Reply With Quote
Old 07-03-2016, 11:19 AM   #10
My thoughts exactly. Airstream should use those pictures in their brochures!
Old 07-05-2016, 02:27 PM   #11
Airstream towing Airstream
Beaubill,
That looks like about the weight we need to tow, 5000 lbs. Have you used that rig in the Smoky Mountains yet ? That's where we live and where it has to perform for us because it's up hill and down to go any direction.
After 27 years of towing and RVing, we know most anything does well on flat land (Like Florida), but we don't live there any more.
Paul
Old 07-05-2016, 03:30 PM   #12
See post number 7. That was in the smokeys and just barely adequate,.
Old 07-05-2016, 08:23 PM   #13
2015 Interstate Ext. Coach
Lake Mary , Florida
Nobody mention lights output in our 7-pin hitch connector. Recently I put a step-bar with law-consumption LED lights, and it works fine, and it is the same as trailer lights.
But when I turn all vehicle lights off, I found few small LED diodes still stay very slightly lighted. I checked voltage on the hitch connector, and have found 3.6 volts permanently staying there.
My question for those who understands in vehicle electricals:
is the above a normal in the trailer hitch lighting outputs, and if yes - whould 3.6 volts possibly drain the vehicle's battery through permanently connected diodes there?
Mr. B is offline   Reply With Quote
Old 07-05-2016, 08:25 PM   #14
Lake Mary , Florida
This is where 3.6 volts are permanently exist, even when all vehicle lights are in off position:
(yes there was 7-to 4 pin connector when I was measured)))
Magnum MMS1012 1000W Pure sine Wave Inverter w/50 Amp Charger & Remote exallen Airstream Classifieds 0 06-05-2016 03:25 PM
Goucho couch,original am/fm 8 track & lots of wood & aluminum from interior remodel gquailhunter Airstream Classifieds 0 09-19-2015 04:25 PM
Samsung tv goes on & off & on & etc jump Electronics & Connectivity 22 03-03-2015 06:01 PM
Mercedes Interstate 22' 3500 :: 2013 Airstream Interstate Suru Airstream Registry Discussions 0 05-05-2013 09:23 AM
