03-17-2016, 08:52 AM
2015 Interstate Ext. Coach
San Diego
Airstream Interstate 4x4
2016 Airstream Interstate 4x4 is out.
Increased traction with 4 wheel Hi / Low but also comes with increased ground clearance. Not sure how that would affect on road stability.
http://youtu.be/jIE9gvImaZo
03-17-2016, 09:19 AM
2024 Interstate 19
Fulton
, Maryland
But it still has that very vulnerable LP fill panel mounted low behind the curbside rear wheels. UGH!
03-17-2016, 11:28 AM
2014 Interstate Ext. Coach
Sedona
I took a look at a RoadTrek 4x4 the other day. It certainly looks higher (and sort of more commanding), but that rear overhang is still going to prevent most folks from venturing down any real 4x4 trails. My personal goal is to drive my RV round the Monument Valley trail, and for those who don't know it, it really requires a proper 4x4 with a high ground clearance.
Incidentally, from Airstream or RoadTrek, you cannot have the VB Air Suspension with 4x4; it's an either/or option. You must get an authorized VB fitter to do it for you. Advanced RV is one of those.
03-17-2016, 02:14 PM
Figment of My Imagination
2012 Interstate Coach
From All Over
, More Than Anywhere Else
Probably ought to call it all-wheel drive rather than 4×4, because really it's 6×6 with the dual rear wheels.
Anyway, I suspect the main advantage isn't the marginally increased ground clearance; you could still high-center it on the low-hanging generator and your break-over and departure angles haven't improved by more than a degree or two. And of course you can get an all-wheel-drive vehicle stuck even better than you can get a rear-wheel-drive vehicle stuck; you just have more wheels dug axle-deep into the soft soil.
I think the main advantage will be the improved control in slippery conditions due to having power to the wheels doing the steering.
03-17-2016, 03:55 PM
San Diego
From what I found this is not an AWD system..."unlike Mercedes-Benz’s 4MATIC all-wheel drive, the torque split isn’t variable, so it’s best to leave the Sprinter in two-wheel-drive mode on dry pavement unless you enjoy the sounds of binding driveline components."
Plus an Airstream still won't have enough ground clearance for real "offroading" except gravel roads and such. I wanted one but didn't want to wait for it so I got the regular ol' 2WD.
03-17-2016, 04:49 PM
San Diego
I just looked at that video again and man those things are jacked up
One thing I didn't see is if there is an auto mode for the 4wd. Didn't sound like it. For example, my GMC Sierra has 2wd, auto, 4 wheel Hi and 4 wheel Lo. I run around in the winter (OK it rains once in a while ) in auto mode a lot, if you start to lose traction the 4 wheel drive will kick in. Could be helpful.
03-17-2016, 05:06 PM
San Diego
I think you can switch on the fly. I used to run my 2011 F350 in 4wd on rainy days while driving down the freeway and then switch back to 2wd anytime I needed to turn past 4 degrees to keep it from binding. Worked great off the line too. Traded it in this past Monday on my new Airstream...
03-17-2016, 06:06 PM
Sedona
Anyone notice the apparent ripples in the plank-effect flooring about 1 minute into the video? That would irritate me!
03-17-2016, 06:14 PM
2011 Interstate Coach
Overland Park
, Kansas
Can't say that I did on a re-watch.
2011 Interstate SOLD! Upfitted 2017 Transit 350. SOLD!
03-17-2016, 06:52 PM
2024 Interstate 19
Fulton
, Maryland
Yes - I also noticed those ripples. Must be another feature of Airstream quality. 😀
- - Mike
2013 Interstate Lounge EXT on 2012 Sprinter
- - Mike
2024 Airstream Interstate 19e AWD
Previous: 2013 Airstream Interstate 3500 Ext Lounge
04-06-2016, 11:29 PM
2020 27' Globetrotter
2019 Interstate Lounge Ext
Jackson Hole - Tetons
, Wyoming
We saw the all wheel drive version a week ago in Boise while passing through the area. We liked it and have ordered one. This will be our third ASI in three years, and we'll likely keep this unit for a bit longer than the rest.
The additional height of the vehicle was negligible to me, but the clearance underneath was a welcome addition. The real reason for the purchase was the extra winter traction for us - we'll benefit by expanding our winter travel options because of the all wheel drive.
Scott
04-07-2016, 09:19 AM
San Diego
Were you able to drive one? Curious how the increased center of gravity will feel especially in windy conditions and on uneven transitions like driveways.
Regardless, Congrats! And enjoy your new toy.
04-07-2016, 10:23 AM
From All Over
Height of the CG might not even increase. Sure you've got a (slight) increase in ground clearance. But mounting both house batteries under the floor lowers the CG versus having them in a tray above floor level on older models. Having a 4×4 drivetrain lowers the CG versus a 2WD drivetrain due to the weight of the transfer case and front differential below floor level but also increases the unsprung weight on front wheels— which makes front end alignment and tire balancing even more critical. The added weight below floor level might lower the CG enough to offset the increased CG due to added ground clearance. I haven't crunched the numbers to see.
04-07-2016, 10:52 AM
San Diego
True, really hard to say. One thing for sure is the wind will continue to push our vans around. Probably not gonna be much different.
04-07-2016, 02:25 PM
League City
I took a look at a RoadTrek 4x4 the other day. ....
For which model(s) is it offered? I didn't see that on their website.
04-07-2016, 08:03 PM
Sedona
It's an option on their ordering process for all their Mercedes-based models.
04-07-2016, 11:01 PM
, Wyoming
Ron -
Hi, no we couldn't drive the unit since it was sold and awaiting pickup.
I am comfortable with the increased chassis height, and I like the CG argument Protagonist is floating above.
We don't have it yet though...
Since we're looking at a 2017 model, we've been told we'll want to time our order for an Oct delivery (17 chassis/17 body).
Our current 2016 unit only has only 7,300 miles on it and Bre will use it (9 passenger) for her Adventure_Ninja.com company. (Adventure Travel)
Scott
04-08-2016, 08:56 AM
2024 Interstate 19
Fulton
, Maryland
Originally Posted by ScottP
...... Since we're looking at a 2017 model, we've been told we'll want to time our order for an Oct delivery (17 chassis/17 body).......
Scott
You may end up with a 2016 Sprinter if you take delivery of a 2017 Interstate in October. When I bought my 2013 Interstate in October 2012 all the 2013 Interstates were built on 2012 Sprinters.
- - Mike
2013 Lounge EXT on 2012 Sprinter
- - Mike
04-08-2016, 11:01 PM
, Wyoming
Thanks Mike, good feedback and agreed.
We've been told the 4x4 (6) allotment/allocation is significantly smaller than the normal allocation for rwd's ...the chassis glut won't be an issue. But in the end, who really knows right? If we are faced with a 16/17, we have a clause to walk away and re-order at our discretion.
Scott
06-14-2016, 09:29 PM
Portland
, Oregon
Did you get a chance to drive your new Interstate 4x4? We live in Portland and are trying to decide between the air suspension option that we test drove and the 4x4 which was not available to drive. The air suspension had very impressive performance but Mt Hood passes had snow today so 4x4 sounds attractive.
