Old 09-27-2014, 05:58 PM   #1
Boxster1971's Avatar
2013 Interstate Coach
Fulton , Maryland
Airstream 'How To' Touring Coach 2014
I came across this "How To" video on the Airstream u-Tube channel. It's for the 2014 model Interstates, but has many things that also apply to the older Interstates.
Description:
This is a fairly comprehensive video that explains how to access and use the majority of systems in an Airstream Touring Coach. The two large areas of focus are Hook-up and Interior Systems. We hope you find this video informative and beneficial.
Length: 14:20
- - Mike
Old 09-28-2014, 11:25 AM   #2
2014 Interstate Coach
Good video. It's actually better than the walk-through I got from my dealer. I'd love to see Airstream do more of these.
migriffin is offline   Reply With Quote
Old 09-28-2014, 02:37 PM   #3
Ron_CA's Avatar
2015 Interstate Ext. Coach
San Diego , California
Good find.
Ron_CA is offline   Reply With Quote
Old 09-28-2014, 03:00 PM   #4
73shark's Avatar
2011 Interstate Coach
Overland Park , Kansas
Great video. I noticed that when he retracted the macerator hose, he didn't show how difficult it is to get the end of it back inside.
Old 09-28-2014, 03:09 PM   #5
Kwils25's Avatar
2014 Interstate Ext. Coach
Taylor Ridge , Illinois
Yes, I noticed that too. I've found that taking off the threaded disc at the end of the hose helps in getting back in without crimping/breaking the hose. It only took me repairing the hose once to figure that out!
Kwils25 is online now   Reply With Quote
Old 09-28-2014, 04:51 PM   #6
Fulton , Maryland
I also remove the adapter disc and leave a loop of hose so I can get it back in compartment easier. These is some extra space on the inside above the door. I also like to use hot water from the outdoor shower to back flush the black tank.
- - Mike
2013 Lounge EXT on 2012 Sprinter
- - Mike
Old 09-29-2014, 07:34 AM   #7
toskeysam's Avatar
Townsend , Tennessee
Hope this attachment works....I took this photo to remind me how much loopto leave and orientation of things to get it ALL in the space. The black ring is to the right of the nozzle. Everything fits.Click image for larger version
FMCA # 436814
toskeysam is offline   Reply With Quote
Old 09-29-2014, 09:46 AM   #8
73shark's Avatar
Since I have access to the sanitary sewer in my garage, I fashioned an extension that screws into the white fitting and allows me to pump out at home at the end of the trip.
Old 09-29-2014, 10:40 AM   #9
Ron_CA's Avatar
Ditto, did this as well. Only needed about a 5 foot extension to dump through one of my cleanouts.
Old 09-29-2014, 12:32 PM   #10
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Originally Posted by toskeysam View Post
Hope this attachment works....I took this photo to remind me how much loopto leave and orientation of things to get it ALL in the space. The black ring is to the right of the nozzle. Everything fits.Attachment 223203
After two full years of never once using that black hard rubber ring, I discarded it. The extra space freed up by discarding it definitely helps.
In its place, I bought a pair of 1-pound wrist weights for exercise, that secure with Velcro. If I need to weight down the end of the hose to hold it in place, I wrap one of the wrist weights around the nozzle.
Slinky owners make do with a flat rock or tree branch to hold down the end of their slinky, but we macerator pump users aren't so limited.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 10-05-2014, 08:21 AM   #11
FunWaggin's Avatar
Raleigh , North Carolina
Thanks for the video recommendation! I'm a new owner and have been searching for this. My dealer walk-through was not as thorough.
FunWaggin'
FunWaggin is offline   Reply With Quote
Old 10-24-2014, 01:35 PM   #12
scottsdale , Arizona
battery disconnect question
I watched this video and I am still confused about the battery disconnect switch near the door. When the switch is in the down position is that systems off, or when it is in the up position. Also is the red light supposed to go off when battery is disconnected or does it remain on? Seems like whether I put the switch down or up the same thing happens- the red light blinks for a bit and then remains solid on. help??
e93pvaz is offline   Reply With Quote
Old 10-24-2014, 01:37 PM   #13
toskeysam's Avatar
My 2013 flashes and goes out when turned off
FMCA # 436814
Old 10-24-2014, 01:51 PM   #14
do you flip the switch up or down for off??
2011 airstream interstate touring coach - blow - out $104,842.00!!!!!!!! eBay Watch Airstreams on eBay 0 01-20-2012 03:30 PM
2011 airstream avenue class b touring coach - blow - out !!! $69,995 !!!!! eBay Watch Airstreams on eBay 0 01-19-2012 09:00 PM
Airstream Insterstate 3500 Class A Touring Coach eBay Watch Airstreams on eBay 0 12-08-2010 12:40 PM
Airstream Insterstate 3500 Class A Touring Coach eBay Watch Airstreams on eBay 0 11-18-2010 10:20 AM
2009 Airstream Interstate Touring Coach Class B eBay Watch Airstreams on eBay 0 09-03-2009 11:00 AM
