Old 10-24-2014, 01:56 PM   #15
toskeysam's Avatar
2013 Interstate Coach
Townsend , Tennessee
I have a rocker switch on mine. On when pushed in on top.
FMCA # 436814
toskeysam is offline   Reply With Quote
Old 10-24-2014, 01:58 PM   #16
toskeysam's Avatar
Name:	ImageUploadedByAirstream Forums1414180671.887768.jpg
On
Name:	ImageUploadedByAirstream Forums1414180685.256082.jpg
Off
FMCA # 436814
Old 10-24-2014, 01:59 PM   #17
scottsdale , Arizona
Originally Posted by toskeysam View Post
Attachment 225026
On
Attachment 225027
Off
Thank you- i found another thread where someone else is having same problem with the red light never going out even when switched down (to off)
e93pvaz is offline   Reply With Quote
Old 10-24-2014, 02:27 PM   #18
toskeysam's Avatar
That does ring a bell.... Something about the motor not driving the disconnect switch all the way off.
FMCA # 436814
Old 10-24-2014, 05:30 PM   #19
Boxster1971's Avatar
Fulton , Maryland
Personally I think the "disconnect" switch provided by Airstream is useless since it really disconnects so little. What's really needed is a switch to completely disconnect the coach battery.
- - Mike
2013 Lounge EXT on 2012 Sprinter
- - Mike
Old 10-24-2014, 05:31 PM   #20
toskeysam's Avatar
Amen to that......not sure what the value of the present switch really is.
FMCA # 436814
Old 10-24-2014, 06:53 PM   #21
73shark's Avatar
2011 Interstate Coach
Overland Park , Kansas
The BIM must be powered at all times for it to function. It cannot be disconnected from the Coach battery. Not sure why the antenna power does not shut off with the battery disconnect switch.
Old 10-24-2014, 06:54 PM   #22
toskeysam's Avatar
Bad day at Jackson Center maybe
FMCA # 436814
Old 10-25-2014, 06:13 AM   #23
Clifton , Virginia
My antenna power turns off with the battery switch off. Same with LP.
cjrdad is offline   Reply With Quote
Old 10-25-2014, 08:14 AM   #24
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
You may be the only one. On my 2012, when it was still new and I was still learning the ropes, I ran my house batteries stony dead by leaving the antenna amplifier switched on because I thought it was also routed through the disconnect. Now I know better, and I make a point of shutting it off separately.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 10-26-2014, 07:59 AM   #25
Trying to Retire
MILATV's Avatar
Decatur , Illinois
Mine is a 2013 - I'm going to have to check and see what really switches off; but based on the battery going dead in 24hrs while the disconnect was OFF; I doubt mine turns off antenna or LP.
Took me two trips and battery dropping to 8v to realize the antenna & LP even had cut-offs!
Best advise to newbies: "Turn off the antenna & LP when not in use!"
(planning to finally install 2nd LP switch in rear curbside cabinet today)
Mike
If you work until you have everything you 'WANT' - it will probably be too late to enjoy it.
Live in the Moment and enjoy today.
MILATV is offline   Reply With Quote
Old 10-26-2014, 05:33 PM   #26
Kwils25's Avatar
2014 Interstate Ext. Coach
Taylor Ridge , Illinois
(planning to finally install 2nd LP switch in rear curbside cabinet today)[/QUOTE]
Absolutely! Adding the second LP switch inside was well worth the effort for us!
Kwils25 is offline   Reply With Quote
2011 airstream interstate touring coach - blow - out $104,842.00!!!!!!!! eBay Watch Airstreams on eBay 0 01-20-2012 03:30 PM
2011 airstream avenue class b touring coach - blow - out !!! $69,995 !!!!! eBay Watch Airstreams on eBay 0 01-19-2012 09:00 PM
Airstream Insterstate 3500 Class A Touring Coach eBay Watch Airstreams on eBay 0 12-08-2010 12:40 PM
Airstream Insterstate 3500 Class A Touring Coach eBay Watch Airstreams on eBay 0 11-18-2010 10:20 AM
2009 Airstream Interstate Touring Coach Class B eBay Watch Airstreams on eBay 0 09-03-2009 11:00 AM
