09-27-2014, 05:58 PM
2024 Interstate 19
Fulton
, Maryland
Airstream 'How To' Touring Coach 2014
I came across this "How To" video on the Airstream u-Tube channel. It's for the 2014 model Interstates, but has many things that also apply to the older Interstates.
Description:
This is a fairly comprehensive video that explains how to access and use the majority of systems in an Airstream Touring Coach. The two large areas of focus are Hook-up and Interior Systems. We hope you find this video informative and beneficial.
Length: 14:20
- - Mike
2024 Airstream Interstate 19e AWD
Previous: 2013 Airstream Interstate 3500 Ext Lounge
09-28-2014, 11:25 AM
2014 Interstate Coach
Austin
Good video. It's actually better than the walk-through I got from my dealer. I'd love to see Airstream do more of these.
09-28-2014, 02:37 PM
2015 Interstate Ext. Coach
San Diego
Good find.
09-28-2014, 03:00 PM
2011 Interstate Coach
Overland Park
, Kansas
Great video. I noticed that when he retracted the macerator hose, he didn't show how difficult it is to get the end of it back inside.
2011 Interstate SOLD! Upfitted 2017 Transit 350. SOLD!
09-28-2014, 03:09 PM
2020 27' Globetrotter
Taylor Ridge
Yes, I noticed that too. I've found that taking off the threaded disc at the end of the hose helps in getting back in without crimping/breaking the hose. It only took me repairing the hose once to figure that out!
09-28-2014, 04:51 PM
2024 Interstate 19
Fulton
, Maryland
I also remove the adapter disc and leave a loop of hose so I can get it back in compartment easier. These is some extra space on the inside above the door. I also like to use hot water from the outdoor shower to back flush the black tank.
- - Mike
2013 Lounge EXT on 2012 Sprinter
- - Mike
09-29-2014, 07:34 AM
2013 Interstate Coach
Townsend
, Tennessee
Hope this attachment works....I took this photo to remind me how much loopto leave and orientation of things to get it ALL in the space. The black ring is to the right of the nozzle. Everything fits.
FMCA # 436814
09-29-2014, 09:46 AM
Overland Park
, Kansas
Since I have access to the sanitary sewer in my garage, I fashioned an extension that screws into the white fitting and allows me to pump out at home at the end of the trip.
09-29-2014, 10:40 AM
San Diego
Ditto, did this as well. Only needed about a 5 foot extension to dump through one of my cleanouts.
09-29-2014, 12:32 PM
Figment of My Imagination
2012 Interstate Coach
From All Over
, More Than Anywhere Else
Originally Posted by toskeysam
Hope this attachment works....I took this photo to remind me how much loopto leave and orientation of things to get it ALL in the space. The black ring is to the right of the nozzle. Everything fits. Attachment 223203
After two full years of never once using that black hard rubber ring, I discarded it. The extra space freed up by discarding it definitely helps.
In its place, I bought a pair of 1½-pound wrist weights for exercise, that secure with Velcro. If I need to weight down the end of the hose to hold it in place, I wrap one of the wrist weights around the nozzle.
Slinky owners make do with a flat rock or tree branch to hold down the end of their slinky, but we macerator pump users aren't so limited.
10-05-2014, 08:21 AM
2016 Interstate Lounge Ext
Raleigh
, North Carolina
Thanks for the video recommendation! I'm a new owner and have been searching for this. My dealer walk-through was not as thorough.
FunWaggin'
10-24-2014, 01:35 PM
scottsdale
battery disconnect question
I watched this video and I am still confused about the battery disconnect switch near the door. When the switch is in the down position is that systems off, or when it is in the up position. Also is the red light supposed to go off when battery is disconnected or does it remain on? Seems like whether I put the switch down or up the same thing happens- the red light blinks for a bit and then remains solid on. help??
10-24-2014, 01:37 PM
Townsend
, Tennessee
My 2013 flashes and goes out when turned off
FMCA # 436814
10-24-2014, 01:51 PM
scottsdale
do you flip the switch up or down for off??
10-24-2014, 01:56 PM
Townsend
, Tennessee
I have a rocker switch on mine. On when pushed in on top.
FMCA # 436814
10-24-2014, 01:58 PM
Townsend
, Tennessee
On
Off
FMCA # 436814
10-24-2014, 01:59 PM
scottsdale
Thank you- i found another thread where someone else is having same problem with the red light never going out even when switched down (to off)
10-24-2014, 02:27 PM
Townsend
, Tennessee
That does ring a bell.... Something about the motor not driving the disconnect switch all the way off.
FMCA # 436814
10-24-2014, 05:30 PM
2024 Interstate 19
Fulton
, Maryland
Personally I think the "disconnect" switch provided by Airstream is useless since it really disconnects so little. What's really needed is a switch to completely disconnect the coach battery.
- - Mike
- - Mike
10-24-2014, 05:31 PM
Townsend
, Tennessee
Amen to that......not sure what the value of the present switch really is.
FMCA # 436814
