Closed Thread
Old 06-04-2016, 09:11 PM   #57
2015 Interstate Ext. Coach
Lake Mary , Florida
For curiosity, today I removed the microwave to look what is behind it. Removal was simple with 6 screws and sliding out the unit.
I m not sure who said the electricity is not made good, but for my opinion it's done well and in accordance with residential contractor codes, with proper wires gauges, recepricals, groundings, joint boxes and etcetera.
Plumbing is also made with proper construction materials, pipes, fittings, elbows, and foams.
Only what I would have been done at the manufacturing is to engineer and accommodate all those stuff in some channels or boxings, just to make it looks more "professional" but not like in a house's attic.
Generally I was satisfied with what I saw under the galley.
Mr. B is offline
Old 06-04-2016, 09:30 PM   #58
I would never use solid core wire in a vehicle. It's just to susceptible to vibrations. If it develops a crack, there is no bypassing the cracked strand like in a multi strand wire. That added resistance is a potential fire source.
Does it mean that we're all driving time bombs? No, but there is a reason that marine construction standards differ from residential building codes. The entire industry does this so that isn't specific to Airstream or Thor.
LB_3 is offline
Old 06-05-2016, 01:02 PM   #59
Lake Mary , Florida
Sounds logical, but if the solid wires were already used in 110V electrical connectivity in our vans, it is not justified to replace them. I believe nothing will happen with 14 gauge wire due to vibrations ever, but if it would, there are 110V 15A breakers every wire is connected to. So we may drive our Interstates with a safe peice in mind with no concern in this regard.
Thus, In consideration of electrical and plumbing I did not notice anything wrong with Airstream.
Yet )))))
Mr. B is offline
Old 06-05-2016, 05:15 PM   #60
73shark's Avatar
2011 Interstate Coach
Overland Park , Kansas
Every time I pull something out or remove a panel, I find all sorts of detris left behind e.g., wire clippings, insulation strippings, sawdust, drilled hole debris, etc. Nothing the shop vac can't handle but just shouldn't be necessary.
73shark is offline
Old 06-05-2016, 09:23 PM   #61
lewster's Avatar
Naples, FL , Hood River, OR
Actually, ABYC marine wiring standards are light years ahead of any RV standards used today.
When I took my ABYC Marine Electrician certification course, all of the marine guys ( and a specially the instructors) were absolutely horrified as I described the typical wiring and terminations used in most RVs.
They totally lost it when I showed them an RV 'speed wire ' 120 VAC outlet that uses brass grab forks to pierce the Romex as it is pressure fit between them. They simply could not believe it was allowed!!!!!! I can't either!!!!
Another reason I use marine wiring standards exclusively.
Lew Farber
ABYC Certified Master Marine Electrician
AM Solar Certified Installation Center*AMS Lithium Batteries
Lifeline AGM Batteries**Magnum Inverters***Victron Energy Components
541-490-6357
lewster is offline
Old 06-05-2016, 09:48 PM   #62
Thanks for pointing that out Lew. That speed wire 120 AC outlet is still in our AI. I was shocked when I first saw it. It will be gone when I rewire the van.
LB_3 is offline
Old 06-05-2016, 10:30 PM   #63
lewster's Avatar
No charge!!
lewster is offline
Old 06-06-2016, 06:22 PM   #64
Lake Mary , Florida
I appreciate all the adequate Ladies and Gentelmen for being cooperative in the past 5 months communication with Mr. B.
Wish all of you good days and miles on the roads!
Sincerely,
Mr. B
Mr. B is offline
Old 06-07-2016, 09:00 AM   #65
2009 22' Interstate
Lake City , Michigan
When you go all the way to Jackson Center and have an "experienced" tech tell you your fridge is only 110 volt AC but the ID tag on the fridge lists 12 volt DC & 110 volt AC. Something is wrong... VERY WRONG!
jpkski is offline
Old 06-07-2016, 09:11 AM   #66
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
Mr B.
You have apparently never travelled in a Zetros!
An interstate is a mere toy in compare!
AtomicNo13 is offline
Old 06-07-2016, 09:19 AM   #67
2009 22' Interstate
I very love my bus and it is the most usable and the most convenient vehicle in the park of my cars.
I love my bus, because it is a Mercedes, and because nothing better but Airstream Interstate on the van-sized body you can buy for a hundred + some thousand dollars.
However, having enormous experience with hi-end vehicles and different benzes in the past, I was not able not to open this thread of unprofessional craftsmanship of the Airstream in producing a conversion of Sprinters. They made a great furniture and excellent engineering of the Interstate. However, they cut corners doing their assembling job very fast, they did not pay attention to any details, they simply used workers with two left hands in a production line of Sprinter conversions (forgive me, left-handers, that was not about you).
Insufficient glues, not pressed double-side tapes, leaking vents, non-tighten screws, and a lot of other small things which are pain in the bottom... Every day I fix the flaws in my bus, doing it more and more precise. Yes, it comes better every time my hands touch it.
But I can't believe that for these money Airstream is not able to hire a good technicians in assembly line, instead of those whose job place must be asking "paper or plastic" in a food supermarket.
jpkski is offline
Old 06-07-2016, 09:53 AM   #68
Gainesville , Florida
Sincerely,
Mr. B
Going somewhere?
xrvr is offline
Old 06-07-2016, 12:22 PM   #69
Bellevue , Washington
But they are not mandatory in boating industry either. I can't tell you how many things I have improved to make ABYC or better compliant in boats. It is a voluntary standard but should be mandatory given the life and death impact in a boat as opposed to RV.
amirm is offline
Old 06-07-2016, 12:27 PM   #70
Lily&Me's Avatar
Normal , Illinois
<Mod Hat On>
One of the things the Community Rules here requires is:
"Public discussion about moderation or moderator decisions is not allowed. If a moderator deletes or edits one of your posts and you disagree with the action, contact the moderator concerned. Do not repost deleted material."
We have recently removed posts for these reasons.
Please comply.
Maggie
Lily&Me is offline
Closed Thread
AVION~1970~24'overall~VERY Clean~NO Dents or Flaws~Like~ AIRSTREAM~Ready to use eBay Watch Airstreams on eBay 0 03-26-2013 11:00 AM
AVION~1970~24'overall~VERY Clean~NO Dents or Flaws~Like~ AIRSTREAM~Ready to use eBay Watch Airstreams on eBay 0 02-25-2013 01:30 PM
AVION~1970~19 '~VERY Clean~ NO Dents or Flaws~Like~ AIRSTREAM~Ready to be USED eBay Watch Airstreams on eBay 0 02-12-2013 09:20 AM
AVION~1970~21 '~VERY Clean~ NO Dents or Flaws~ AIRSTREAM~Neon~ eBay Watch Airstreams on eBay 0 11-19-2012 06:30 PM
Manufacturing Flaws smily General Repair Forum 3 02-22-2003 08:41 AM
