Old 03-12-2019, 05:10 PM   #99
Mansderm161's Avatar
NORTH MYRTLE BEACH , South Carolina
You will love it! It is life changing! I did all that in December at AM solar....top of the line. Enjoy!
Mansderm161 is offline   Reply With Quote
Old 03-12-2019, 08:02 PM   #100
2017 Interstate Lounge Ext
Plano , Texas
Great pics. That kind of an upgrade is on the list and I have bugged Lew a few times. Wish they were closer to Texas. Keep the pics coming.
Tobbun is offline   Reply With Quote
Old 03-12-2019, 09:14 PM   #101
Prof. of Pending Projects
wachuko's Avatar
2018 Tommy Bahama Interstate
Orlando , Florida
Check at 14:32... great to finally see the new Sprinter chassis in an RV...
Safe travels!
Wachuko
WBCCI #26769
2018 Airstream Interstate 3500 Lounge EXT Tommy Bahama w/ARS
wachuko is online now   Reply With Quote
Old 03-12-2019, 09:21 PM   #102
Panama City Beach , Florida
I too have become a satisfied Lew customer
Just got back from Naples with 400 w solar panels and 400 aH Lithium. Great work by Lew and Michael.
ID:	335521   Click image for larger version
tk.1217 is offline   Reply With Quote
Old 03-12-2019, 09:30 PM   #103
wachuko's Avatar
Orlando , Florida
Sweet!!!!! ^^^
Safe travels!
Wachuko
WBCCI #26769
Old 03-12-2019, 09:58 PM   #104
2011 Interstate Coach
Muskogee , Oklahoma
I'm curious how he wired it up to allow for the engine alternator charging. That's what has me a bit worried when installing 400amp or higher load batteries. Lots of different ways it can be done.
2011 Interstate WD/Lounge
gmillerok1 is offline   Reply With Quote
Old 03-12-2019, 10:47 PM   #105
Tucson , Arizona
The line item they are installing is a "Victron Cyrix-Li-ct 12/24V-230A Intelligent Li-ion battery cmb", which is just a chassis battery boost I think. I'm not sure of anything else but I know they are doing something as there is about 6 hours of labor. I told them I definitely want the plumbing for the second alternator so it might be some of that. I'm considering adding a Nations second alternator for the house but it's not cheap with install. They tell me the factory alternator will bring me up to about 80% state-of-charge and the overall solar will help top that up a bit (I travel in the south primarily). The 2nd alternator is probably my next upgrade but for now I will see how the factory alternator performs. I opted for more aH of lithium over the alternator to give me a bigger base of power and I plan on plugging in every 3-7 days.
ChrisCow is offline   Reply With Quote
Old 03-13-2019, 06:04 AM   #106
Originally Posted by wachuko View Post
Check at 14:32... great to finally see the new Sprinter chassis in an RV......
Check out that magnificent new table system that Winnebago has revealed - such innovative thinking!! Not just the same old clunky floor-pedestal table design, but an actual ergonomic thought process involving two receivers (front and rear) and both indoor and outdoor capability!
Old 03-13-2019, 06:17 AM   #107
Plano , Texas
Seems like you have the W as fans and subscribers of your blog. Where is your royalties on helping them with their design choices?
Old 03-13-2019, 07:25 AM   #108
wachuko's Avatar
Orlando , Florida
InterBlog, your mounting solution is still more elegant and better executed, imho.
Safe travels!
Wachuko
WBCCI #26769
Old 03-13-2019, 08:06 AM   #109
LOL thank you, I thought so too, but I having a rare moment in which I was feeling graceful and so I did not say that.
Old 03-13-2019, 10:41 AM   #110
Boca Raton , Florida
I was hoping that Airstream would put the Truma in the new AIs since they did that in the AI19. My sources tell me that the Truma is in the AI19 was only because of the limited interior space and won't be going into the 2020 AI. The upgrade from the Suburban (?) furnace and gas water heaters would cost Airstream about $1,000 per van. Apparently they don't think that buyers will pay more for the added storage space and a more efficient and comfortable heat/water system. Winnebago's Boldt is a bet that we will. Hope Airstream goes with Truma. The huge box under the back seat is really unnecessary. Temperatures would be more consistent when heat is on. The Truma saves a few holes in the side of the van too.
Fixin2Drive is offline   Reply With Quote
Old 03-13-2019, 11:21 AM   #111
Tucson , Arizona
My last van had a Truma Combi and it was amazing compared to my AI now. Super even heat, extremely quiet (nearly silent!) and the hot water actually worked well. The AI heater is shockingly loud and only the front of the van is warm. I have to run a small radiant oil heater in the back. I'm sure everyone is aware of what I'm talking about
I've been giving a lot of thought on installing a Truma Combi where the existing water heater is. I actually think it's do-able.
Old 03-13-2019, 12:06 PM   #112
There is plenty of room to install a Truma Combi in another place and you can free up the storage space where your current water heater is located. At the January Tampa RV Show I removed the vent that's thumbscrewed in under the refrigerator on a 2019 AI GT and it would fit there. Then you could also remove your Suburban gas furnace and put in a huge drawer. That would leave several holes in the side of the van that could be closed by an auto body shop. The concentric air inlet/exhaust on the Truma Combi are typical German engineering perfection.
Issues with sound and air circulation issues caused by the Suburban RV Furnace could make this a worthwhile upgrade. The Truma Combi's 4 flexible heat ducts to tiny outlets located your van will take care of any cold spots.
Which would you rather? Better brakes, better hitch, or better wheels/tires? bjmckernan General Repair Forum 30 07-17-2016 06:47 AM
Herd of Airstreams PasturePrime Our Community 7 08-25-2014 10:21 AM
Adding to the herd balrgn Vintage Kin 146 01-12-2013 06:30 PM
Latest addition to the herd balrgn 1970 - 1973 Overlander 221 06-15-2011 03:24 PM
We're off like a herd of girdles! bobfowler On The Road... 17 08-06-2007 06:08 PM
