Old 09-25-2015, 08:42 AM   #15
The air suspensions I've seen are bolt in systems (no welding). If generators and plumbing don't have to be relocated, the system can probably be installed DIY over a pair of weekends at less than half the price quoted above. But given the weight of the components involved and the custom wiring needed for the compressor, this wouldn't be a task for the inexperienced.
LB_3 is offline   Reply With Quote
Old 09-25-2015, 09:19 AM   #16
Boxster1971's Avatar
2013 Interstate Coach
Fulton , Maryland
Those bolt on systems are only air-bag assist devices. The full air suspension systems we are talking about in this thread require removal of the rear leaf springs and replacing them with a totally new rear suspension system.
- - Mike
2013 Lounge EXT on 2012 Sprinter
- - Mike
Old 09-26-2015, 12:23 AM   #17
- - Mike
Leaf springs are held on with bolts too. :-).
These systems replace each leaf spring with a trailing arm that bolts to the front leaf spring mounts. The chassis is then supported by 2 bags mounted to the trailing arms. This configuration has no lateral stability so i believe Glide Right and VB both use panhard bars.
That's unfortunate because a Watts link does a much better job of centering the axel as it translates up and down.
Rear leaf spring suspensions really don't have many parts so I can't imagine, even with all the stability control and antilock brakes, not being able to remove an axel before noon on a Saturday. Some model Interstates have the generator tucked in close to the differential which has to be relocated before the panhard bar will fit. Lucky for us, ours Interstate isn't one of those models. I just need to convince Interblog that this is an upgrade she needs.
Old 09-26-2015, 08:42 AM   #18
Fulton , Maryland
Good points LB_3. I see your thinking about bolt-on. But as you said the weight of the components you need to remove is problematic.
- - Mike
- - Mike
Old 09-26-2015, 10:06 AM   #19
73shark's Avatar
2011 Interstate Coach
Overland Park , Kansas
Not to mention the fact that you're dealing with a 5 ton vehicle. You will need a substantial floor jack and jack stands to support this weight.
And getting to the jack points on this unibody vehicle with all the equipment added under the body is not an easy task.
Old 11-21-2015, 09:17 AM   #20
Amg
2016 Interstate Lounge Ext
Pittsburgh , Pennsylvania
I have now had my 2016 Lounge ext with air suspension for a month. The ride in the back is like night and day compared to my 2015 without air suspension. I use my Interstate as a day coach and a good ride for my rear passengers is important. It was well worth the cost of trading in my 2015 for a new unit. I guess if the rear is not used for passengers it is not necessary.
Amg is offline   Reply With Quote
Old 12-04-2015, 09:45 PM   #21
Trying to Retire
MILATV's Avatar
Decatur , Illinois
This is great news - looking at trading my 2014 for 2016 for this exact reason.
Do you have 2015 or 2016 chassis? Dealer is telling me the 2016 Chassis has smaller fuel tank and less airbags; anyone else have knowledge of 2016 v 2015 Chassis?
Mike
If you work until you have everything you 'WANT' - it will probably be too late to enjoy it.
Live in the Moment and enjoy today.
MILATV is offline   Reply With Quote
Old 12-05-2015, 07:34 AM   #22
Tulsa , Oklahoma
Is the rear air suspension only an aftermarket addition? I can not find it on the possible options from M/Benz.
https://sprinterguy.files.wordpress....an-options.pdf
The all wheel drive is a pricy option.
Road Jager
Road Jager
Living On Tulsa Time
RoadJager is offline   Reply With Quote
Old 12-05-2015, 09:06 AM   #23
Amg
I have a 2016. I know the propane tank is listed as being smaller but it is the same size. They just changed the capacity to the limit the tank can hold which is 80%. The only change I noticed as a result of the air bag suspension is the elimination of the recessed cooler storage area by the rear door. The needed it for the air bag suspension equipment. The fuel tank to my knowledge is the same as in the 2015.
Old 12-05-2015, 09:09 AM   #24
Fulton , Maryland
Road Jager
The VB Air Suspension installed by Airstream in the new Interstates is an aftermarket item in USA. It is approved by Mercedes and available as a factor option in Europe. The VB system is also installed by Advanced RV on their B-vans. VB has been growing their USA presence and has several dealers around the country.
http://www.vbairsuspensionusa.com/us/
Having this system installed on an older Interstate will involve dropping several of the under body tanks to get access to the rear suspension mounting points. I've been looking at the VB and Glide-Rite air suspension, but they are very expensive - like $10,000 installed as an aftermarket item. I think I saw a post that the Interstate option price was about $8,000, which sounds about right.
- - Mike
- - Mike
Old 12-05-2015, 09:13 AM   #25
Fulton , Maryland
I was at a Mercedes tech briefing earlier this year and the representative from Mercedes USA said all Sprinters would now have the slightly smaller fuel tank used in the 4x4 Sprinters. It was a parts simplification efforts to save a few $'s.
- - Mike
- - Mike
Old 01-02-2016, 07:04 AM   #26
2015 Interstate Ext. Coach
Chicago , Illinois
I own a 2015 Interstate Lounge purchased new in November. We use it for day trips with our children and grandchildren. It has been mostly problem free and we enjoy it. Not so enjoyable is the ride for the people in the back. When the 2016 came out with air suspension we test rode one and found it to be a night verses day better ride. We looked at retrofitting it but it would require the removal of most of the tanks and generator to do the installation. We had concerns about having problems with the coach after the installation. Neither I nor my wife are mechanical at all.
I decided to trade in my coach for a new 2016. I will be picking it up in a few weeks. I now have concerns after reading all the horor stories about electrical, generator, A/C, macerator and other problems. Further, I recently visited the Jackson Center Airstream facility and saw an Interstate being assembled. It is a small assembly line with three stations. They allow each unit to be at the station for two hours. If longer is required they pull it off to the side. All the installation is done manually with many workers screwing things on running wires etc. One can see how easily something could be missed or misinstalled.
Now wondering if I made a mistake and should have done the retrofit.
Did you ever pick up the new 2016 w/ air suspension? If so, what's your verdict?
Marks71 is offline   Reply With Quote
Old 01-02-2016, 08:10 AM   #27
Trying to Retire
MILATV's Avatar
Decatur , Illinois
I picked up the 2016; but the air suspension model was $7000 more so I ended up going with standard 2016 suspension package (Mercedes High Center of Gravity). I believe it is better than my 2013 chassis was from the factory; but rear seat bounce is still an issue; as is buffeting behind large rigs (side roll when exiting driveway is not as bad in '15 chassis as 13; but may be because i now live in different house and driveway isn't as bad).
I would not upgrade to 2016 model for ONLY the suspension unless springing for the Air Package. I bet it is worth the $7,000 difference I would have had to pay - I'm sure it transfers to trade in/resale like 4x4 does on a truck. Just hard to swallow that I have a $150,000 van in the driveway and no Corvettes, SL600s or maybe even a Ford GT
We drove it to IL and back (1500mi) and I am VERY happy with the lane departure, screen doors, and electric window shades. The larger TV is nice (although the angle from 2nd row seats is still tough on the neck!
I also like the layout of the Electrical switches, generator and water heater controls being in the cabinet behind the driver, it's easier to access than walking all the way to the back when I connect to a 20AMP shore connection.
Still no clue why a Propane Cutoff wasn't installed in the Cabin (ahead of the exterior one); seems like that is a simple low cost improvement that does wonders to extend battery life! It was best mod I made to my 2014 model.
The addition of the cabinet over the curbside 2nd row seat is nice. (though loss of the storage below the 2nd Row Curbside seat is a bummer (we kept dog bowls, water and food & leash there).
RE: Lane Departure: the beep when you leave your lane gets really annoying when trying to read email messages (which was good since it forced me to have my wife read them to me and respond)
Not really advertised bonus was the LED light strip added to the awning & under the curbside frame, with controls on curbside front row seat with awning; making the van look pretty cool when parked with awning out.
The rear storage area now has LED lights on the left and right side; which seemed like a pretty cool idea, except once you pile in the bags the LED lights are not reachable! Placing them on the overhead would have seemed to made more since - so I'll probably still be installing a cabin light overhead in the far rear section.
There are also Clothes hanger hooks overhead on both port and starboard side behind the rear couch, as well as interior LED lighting in both the Front over cab cabinet, and rear center cabinet (figured out the overhead lights need to be on for the rear cabinet interior light to work), the front one has a switch on it.
Hope this is helpful. FYI: still some small QC issues with the new van, hoping to get back to dealer next week to get those fixed, but overall very happy with purchase.
Mike
Old 01-02-2016, 10:34 AM   #28
Chicago , Illinois
never mind ... I saw your earlier post from Nov that you got it and are happy THX
2015 interstate grand tour problems plus! zingara Sprinter and B-van Forum 69 09-26-2015 02:12 PM
2015 Grand Tour Kenwood & Internet access curmugeon Sprinter and B-van Forum 3 07-29-2015 07:53 PM
Screens for 2015 Grand Tour tlundell Sprinter and B-van Forum 11 05-25-2015 07:37 AM
2015 Airstream Interstate Grand Tour EXT 24 - Florida ineed2golf Airstream Classifieds 0 04-14-2015 07:00 AM
First trip in our new 2015 Interstate Grand Tour LizabethLane Sprinter and B-van Forum 40 10-29-2014 02:06 PM
