Old 10-02-2017, 07:56 PM   #1
3bcamper's Avatar
2009 22' Interstate
St. Paul , Minnesota
Air Conditioning On Generator
Hello, sometimes when my air conditioner compressor starts, it overwhelms the 2.5 kw generator and causes it to shut down. Other times, the generator just bogs down, but then recovers. Is this usual, or do I possible have a bad start capacitor? There is scant electrical information in the ac manual, so I cannot find the running current, let alone the inrush current. Any insight would be appreciated.
3bcamper is offline   Reply With Quote
Old 10-02-2017, 08:00 PM   #2
Half a Rivet Short
Carlisle , Pennsylvania
Hi
To be "comfortable" with the stock AC, you need about a 3KW generator. Bogging down is a bad sign. You likely will damage the AC and the generator.
Old 10-02-2017, 08:13 PM   #3
gandttimes's Avatar
2014 25' FB International
2007 20' Safari SE
2005 19' Safari
Qualicum Beach , British Columbia
" micro air easy start" will solve your issues. There are a couple of threads on this subject.
gandttimes is offline   Reply With Quote
Old 10-02-2017, 08:24 PM   #4
DaveP's Avatar
2004 28' Classic
Monument , Colorado
Hi
Agree with Uncle Bob. Also agree with grandtimes (if you live below 5000 feet elevation).
DaveP
2004 Airstream Classic 28 "Willard"
2014 Ford F150 FX4 Ecoboost
DaveP is offline   Reply With Quote
Old 10-02-2017, 08:52 PM   #5
HowieE's Avatar
Princeton , New Jersey
Images: 12
The sometimes is not just the AC but what else you are running at that time. The frig on electric, the convertor, are the 2 bigger loads but any AC usage will add and cause the problem.
Get a plug in AC volt meter and watch it while using the Air. If the voltage drops below 105 volts, from your combined loads, don't leave the Air as you will damage it before it shuts itself off.
2004 Excursion 4x4
Old 10-02-2017, 09:18 PM   #6
+1 on the Easy Start.
LB_3 is offline   Reply With Quote
Old 10-02-2017, 09:26 PM   #7
70CT's Avatar
1974 21' Globetrotter
2016 30' International
Houston , Texas
http://www.airforums.com/forums/show...d.php?t=162618
Quite a few threads on the subject. If you are okay with the initial cost, the answer is “Easy”.
70CT is offline   Reply With Quote
Old 10-03-2017, 08:12 AM   #8
Boxster1971's Avatar
2013 Interstate Coach
Fulton , Maryland
The Easy Start is one solution. On my Interstate when I've had this issue of generator not holding the load from A/C in hot weather I discovered the problem was the Power Control System (PCS) installed by Airstream on the later model Interstates. I have always been able to get the generator to power the A/C by turning off all the other 120VAC breakers. In my research I determined that the PCS trips the power in "GEN" mode at 18A, when the generator is actually able to but out +20A.
- - Mike
Old 10-03-2017, 08:46 AM   #9
3bcamper's Avatar
2009 22' Interstate
I'll be doing the voltage test today, but in any case, it seems that the "easy start" is a no-brainer, as the generator capacity is not well-matched to the ac load. Is that correct? Does anyone know what the start and run amperes are?
Old 10-03-2017, 08:47 AM   #10
3bcamper's Avatar
2009 22' Interstate
Never mind on the amperes; just found online.
Old 10-03-2017, 10:22 AM   #11
2016 27' International
Anacortes , Washington
Yep, the "Easy Start" is a solution
I installed our Easy Start a few months ago, with no issues. Buy the installation part pkg too, if you decide to buy this system. Type in "airstream" in the right place and get a $40 discount.
Pat Pierce is offline   Reply With Quote
Old 10-03-2017, 01:48 PM   #12
3bcamper's Avatar
2009 22' Interstate
Now that I have found the RLA to be nearly 15 amps (compressor and fan together) and the generator peak amps to be about 20, that even under ideal conditions, they're not a great match. Will need, at a minimum, the easy start capacitor system. Can't believe that the gen can actually hold up under the inrush current.
Old 10-03-2017, 08:48 PM   #13
Mike1997's Avatar
1998 36' Land Yacht Widebody
Shepardstown , West Virginia
Images: 14
The add-on items are good for short term usage but you might want to start looking at upgrading the Generator. My AS has 2 roof top units that also have electric heat strips. The generator is a 6500kw Onan propane generator. Actually would prefer it to be diesel but at least the generator can handle the loads with no problem. It takes more to heat than to cool and I can still run the microwave while the roof units are operating.
Mike1997 is offline   Reply With Quote
Old 10-03-2017, 08:57 PM   #14
Stay CazuaL
cazual6's Avatar
2018 25' Flying Cloud
2014 19' Flying Cloud
Reseda , California
Turn OFF eco mode or whatever your generator calls it.
"No job is so simple that it cannot be done wrong."
"Everyone is entitled to be stupid, but some abuse the privilege."
"Either I will find a way, or I will make one."
"Sweat is your fat crying"
WBCCI 9164
cazual6 is offline   Reply With Quote
New AS Air Conditioning - Does It Work? DreamStream Furnaces, Heaters, Fireplaces & Air Conditioning 14 02-27-2004 07:01 PM
air conditioning cowling and vent disintegration Rickj Furnaces, Heaters, Fireplaces & Air Conditioning 7 12-30-2003 01:04 PM
Air Conditioning Help Please!!! 85MH325 Furnaces, Heaters, Fireplaces & Air Conditioning 26 08-16-2003 08:58 AM
Air Conditioning Leak ccphoto Furnaces, Heaters, Fireplaces & Air Conditioning 5 06-15-2003 09:18 PM
Fantastic Fan or Air Conditioning??? Charcigar Roof Vents, Skylights & Fans 15 01-21-2003 08:19 PM
