Old 10-02-2013, 02:35 PM   #1
2010 22' Interstate
Vincennes , Indiana
Air Conditioner / Furnace Thermostat
I have a 2010 Interstate 3500. My thermostat has no readings; no functions at all. I can't set fan, air or heat because i have no reading on the unit. Any ideas?
aa9zz is offline   Reply With Quote
Old 10-02-2013, 02:43 PM   #2
Ottawa , ON
Start with the basics: check the fuse panel. Look around: anything else electronic not working? Is your battery OK?
Old 10-02-2013, 02:47 PM   #3
2010 22' Interstate
Vincennes , Indiana
The circuit breaker is on, I checked the 20 amp fuse at the driver's seat and it measured as not blown. Starting battery new, house batteries charged. No other issues that I have noticed.
Old 10-02-2013, 03:14 PM   #4
wayneskid's Avatar
2010 22' Interstate
Anchorage , Alaska
According to the manual the thermostat is fed by CKT 5. Copied from page H-15:
CIRCUIT 5, 20 AMP, BLUE
BATH CEILING VENT
MAIN AREA CEILING VENT
LOUNGE READING LIGHTS
FURNACE & THERMOSTAT
AC & THERMOSTAT (OPTION)
ENERGY MANAGEMENT DISPLAY MODULE
Hope this helps,
Wayne
- wayne
2010 Interstate 3500 Twin Bed
(2008 Freightliner CRD Sprinter)
AIR #44779
TAC AK-1 !!
wayneskid is offline   Reply With Quote
Old 10-02-2013, 03:21 PM   #5
2010 22' Interstate
Vincennes , Indiana
My unit had a 20 amp fuse five spaces from the left and not #5. I'll check the other circuits you mentioned.
The unit is at a Freightliner service center right now to get a 30,000 mile check-up, but I should get it back later this week.
And, Maggie, I didn't ask them to check the cabin filter. I may have to do that myself.
Old 10-02-2013, 03:43 PM   #6
wayneskid's Avatar
2010 22' Interstate
Anchorage , Alaska
The fuse I'm talking about is in the 12v Distribution panel installed by Airstream, not the fuse panel under the seat. Ckt. #5 in the 12v panel is the 5th fuse up from the bottom.
If all the other loads listed for Ckt. #5 are working, then the fuse is not your problem.
- wayne
AIR #44779
TAC AK-1 !!
Old 10-02-2013, 04:34 PM   #7
2010 22' Interstate
Vincennes , Indiana
Where is the 12 volt distribution panel? I did not get an Airstream manual.
Old 10-02-2013, 05:20 PM   #8
73shark's Avatar
2011 Interstate Coach
Overland Park , Kansas
On the lounge model its under the rear seat to the left side.
Old 10-03-2013, 08:18 AM   #9
wayneskid's Avatar
2010 22' Interstate
Anchorage , Alaska
It depends on which model you have. For the Lounge model, according to page H-11 of the owners manual:
"...12-volt distribution panel, located inside the rear center lounge door..."
On the Twin model, it is under the forward end of the roadside bed.
FWIW; you can get a copy of the Owners Manual in pdf format from the AS website.
- wayne
AIR #44779
TAC AK-1 !!
Old 10-08-2013, 06:22 AM   #10
2010 22' Interstate
Vincennes , Indiana
Let me first say that if you ever want to sell your unit and have it professionally cleaned to look it's best, you should have my wife do it. We don't have a business but a glass of wine and good conversation might coax her to help you. (I would suggest the wine following the cleaning.)
That being said, we found our issue. During a cleaning of the unit, a switch on the heating unit was accidently turned to the "off" position. This caused a shutdown of the entire circuit and left us with no power to the thermostat. This was found by a local RV repair shop as they verified the circuit breaker and fuses were good and then traced the wiring to the switch on the heating unit. turning it on activated the thermostat.
You were all very helpful and I thank each of you and appreciate your help. I posted this as I thought it would be helpful in future situations if this cropped up as a question or issue and to bring closure for those of you who have been trying to help.
In the meantime, I have purchased a bag of fuses to keep with us to help with future issues.
Old 10-08-2013, 07:40 AM   #11
73shark's Avatar
Was this which internal to the furnace?
Old 10-08-2013, 07:41 AM   #12
73shark's Avatar
Was this switch internal to the furnace?
Old 10-08-2013, 08:00 AM   #13
wayneskid's Avatar
2010 22' Interstate
Anchorage , Alaska
It is really a circuit breaker. You can see it as item #20 on the parts blow up drawing on page 8 of the Atwood manual but it isn't clear where it's physically located. Logically, it would be found behind the front cover.
- wayne
AIR #44779
TAC AK-1 !!
Old 10-08-2013, 10:15 AM   #14
2010 22' Interstate
Vincennes , Indiana
It is directly behind the front cover. As the cover was removed to clean dust from the vents then to clean the front of the unit under the outside cover, the breaker or switch was accidently bumped to off.
Advice Needed: Duo Therm Air Conditioner & Heat Pump BKBroiler67 Furnaces, Heaters, Fireplaces & Air Conditioning 19 07-22-2015 05:40 AM
Removing privacy curtain so air conditioner can be removed saltrm1 Furnaces, Heaters, Fireplaces & Air Conditioning 5 04-11-2013 05:26 PM
Air conditioner cover havec1 Roof Vents, Skylights & Fans 4 08-12-2011 09:35 AM
Air conditioner shroud repair for 1974 Sovereign Shamock Furnaces, Heaters, Fireplaces & Air Conditioning 3 05-09-2011 06:30 PM
Suburban furnace thermostat install? adwriter73 Furnaces, Heaters, Fireplaces & Air Conditioning 6 04-04-2011 02:05 PM
