Old 10-08-2013, 10:24 AM   #15
73shark's Avatar
2011 Interstate Coach
Overland Park , Kansas
Good to know info. I will check mine since I had the cover off to clean a recently.
Old 10-08-2013, 11:03 AM   #16
wayneskid's Avatar
2010 22' Interstate
Anchorage , Alaska
Originally Posted by aa9zz View Post
It is directly behind the front cover. As the cover was removed to clean dust from the vents then to clean the front of the unit under the outside cover, the breaker or switch was accidently bumped to off.
Good to know; I didn't even know it was there. Thanks!
- wayne
2010 Interstate 3500 Twin Bed
(2008 Freightliner CRD Sprinter)
AIR #44779
TAC AK-1 !!
wayneskid is offline   Reply With Quote
Advice Needed: Duo Therm Air Conditioner & Heat Pump BKBroiler67 Furnaces, Heaters, Fireplaces & Air Conditioning 19 07-22-2015 05:40 AM
Removing privacy curtain so air conditioner can be removed saltrm1 Furnaces, Heaters, Fireplaces & Air Conditioning 5 04-11-2013 05:26 PM
Air conditioner cover havec1 Roof Vents, Skylights & Fans 4 08-12-2011 09:35 AM
Air conditioner shroud repair for 1974 Sovereign Shamock Furnaces, Heaters, Fireplaces & Air Conditioning 3 05-09-2011 06:30 PM
Suburban furnace thermostat install? adwriter73 Furnaces, Heaters, Fireplaces & Air Conditioning 6 04-04-2011 02:05 PM
