Old 05-22-2018, 09:40 AM   #1
2017 Interstate Lounge Ext
Plano , Texas
AI parked at home - keep main disconnect switch on, etc?
So we are fortunate enough to have a place to park the 2017 AI Lounge at our house and not get in trouble with the Homeowners Association.
I am still planning on getting a 30amp outlet installed but in the mean time I am just keeping the AI plugged in via 120v converter.
I have been keeping the fan on, windows cracked a little and the frig running (24x7). Is this what others are doing that have the same home set up? Any issues I should be aware of?
Yesterday for the first time I heard the Refrig compressor running constantly (still running). Not sure if it is because of the increase in temps outside (90's now in north Texas) and the AI does get morning and early afternoon sun (on same side as refrig). 3pm or so it starts getting shade.
Just started making me think that maybe I should hit the main disconnect switch during downtime. Only issue would be interior heat without the fan. Just keeping drinks in the fridge so not a big issue there if it was room temp while stationary.
What are others doing in similar situation?
Tobbun is offline   Reply With Quote
Old 05-22-2018, 10:01 AM   #2
FlyFishinRVr's Avatar
Northern , California
Yes, Main Disconnect needs to be ON for your '17 in order to keep the batteries charged. You still may have trouble with your chassis battery thanks to the BIM, so keep an eye on it.
Re. the fridge, I would keep it OFF (turn knob all the way to "0") and keep the door open. No reason to waste all that energy, and compressor refrigerators cool very quickly so if you want to go somewhere, just turn it on and close the door and in 1-2hrs it will be cold inside.
A few other notes: I keep my bathroom vent OPEN just to keep odors from building up in there. No water comes in, even during heavy rain. I only close it when I'm driving. Keep a bit of water in the toilet bowl to keep the seal moist, and keep the plugs in the two sinks screwed down tight to keep any gray tank odors from creeping into the van.
Oh, and speaking of odors, I use Happy Campers Organic holding tank treatment and NEVER have a problem with either of my tanks producing bad odors. I use it in both the black and gray tanks per the instructions (put one scoop into the tanks with about 1 gallon of water). It's a powder so there's never going to be an issue with the packets not dissolving and clogging the macerator (a VERY common problem, and one that's a nightmare to clean out for obvious reasons) and it's organic so there's no harsh chemicals doing "bad things" to your plumbing or the environment should you ever pump into a pit toilet at a campground (one of the benefits of a macerator....pump uphill!!!!).
FlyFishinRVr is offline   Reply With Quote
Old 05-22-2018, 10:11 AM   #3
Plano , Texas
Got some Happy Camper ordered (love amazon and same day delivery). The RV place gave us those packets. I really would like to avoid any issues with the macerator...
I will keep an eye on the battery... BIM replacement is towards the top of the list.
I could also park the AI so the refrig side stays in the shade more.
ID:	311706   Click image for larger version
Old 05-22-2018, 10:18 AM   #4
My feeling on that is still to keep it off w/ door open. Here's why: If your power ever goes out while you're away, first, you're going to flatten your house batteries that much faster with the fridge on, and second, with it on then off, you'll likely have moisture inside and with the heat you get down there, you're going to get mold, and fast. Not good.....
Old 05-22-2018, 10:42 AM   #5
Prof. of Pending Projects
wachuko's Avatar
2018 Tommy Bahama Interstate
Orlando , Florida
We do the same... keeping the fridge and the ARB cooler on... this is while hooked to 15amp power source. Main switch is on... Fan is on auto... windows are slightly cracked open to allow flow when fan comes on...
I did a test for about two weeks of disconnecting from 15amp source and validating how it worked with just solar charge (nice sunny days) and all was fine... but now with rainy days, not taking any risk. So we keep it plugged in.
If unplugged... I turn off both ARB and Fridge and doors of those are kept open to avoid mold. Do not leave the door on the fridge closed if the power is off... unless you are into cultivating strange mold cultures...
Safe travels!
Wachuko
WBCCI #26769
2018 Airstream Interstate 3500 Lounge EXT Tommy Bahama w/ARS
wachuko is offline   Reply With Quote
Old 05-22-2018, 10:58 AM   #6
Pahaska's Avatar
2014 Interstate Ext. Coach
Hays County , Texas
Unless there has been some substantial changes since my 2014.5 Lounge, the venting for the refrigerator in the Lounges is almost criminally poor. For that reason, when the temperature hits 90 and above, the compressor struggles to keep up. Before I improved my venting, the box would go up in the 40s as soon as it got hot outside, especially with the sun on the side of the coach. With insulation and proper venting, mine now stays in the mid-30s.
You might look at some of my mods; do a search on "venting."
John W. Irwin
WBCCI #9632
Old 05-22-2018, 11:00 AM   #7
wachuko's Avatar
Orlando , Florida
Thumbs up
John, thank you for the reminder... this was something that I had forgotten to follow up on... let me add it to my list before I forget again.
Safe travels!
Wachuko
WBCCI #26769
Old 05-22-2018, 12:40 PM   #8
Pahaska's Avatar
Hays County , Texas
I have kept the fridge running for 20 years, 3 Airstream trailers, and my AI. I pay for 30a power at the storage yard and I installed a 30a outlet on my workshop at home.
My AI, as were the trailers, is my "man cave." It is my refuge when ladies are at the house and it is where I stop after lunch for a quick nap and, maybe, some TV watching. It is also where I design my many modifications to the AI.
John W. Irwin
WBCCI #9632
Old 05-22-2018, 01:14 PM   #9
Clifton , Virginia
My "man cave" is parked in my driveway with a 30 amp so the fridge and the A/C is always on.
cjrdad is offline   Reply With Quote
Old 05-22-2018, 05:37 PM   #10
2017 Interstate Grand Tour Ext
Fort Lauderdale , Florida
We keep it in the driveway plugged into regular house 15 amp service. We shutdown everything in-between trips. Pull out food/beverages from frig/freezer moving to the garage frig. Then leave the frig/freezer doors open. I cut a 1/2" pvc pipe to the exact length to wedge into the light switch in the frig to turn that off when the door is left open. We crack open the back windows and leave the roof vent open but no fan on.
We have learned the hard way to keep the main battery switch on for the BIM. Still wrestling with a 1.6A draw on the main battery which kills it in 5 days. Hope to get that resolved next week. I know 1A is Fusion.
We are recovering boaters by nature so shutting down as much as possible that is not needed is in our genes.
Land Stitchy is offline   Reply With Quote
Old 05-22-2018, 08:00 PM   #11
2013 Interstate Coach
Raymond , Iowa
I turn the fridge, lights, fans, water pump, propane switch, radio, etc. OFF but leave the main battery connect ON. I have 200W solar with MPPT controller and that is enough to keep the batteries charged, even if it is rainy for several days in a row. In the above configuration I think the only things drawing power are the LPG and CO detectors. (My smoke detector is now battery-only.) I drain black and gray tanks at the end of the trip and have never noticed an odor. (I use the bagged chemicals but cut a corner of the bag and pour it in, instead of letting the bag not dissolve and clog the macerator.) If it is month or more until the next trip I drain the fresh tank and sanitize it just before the next trip. And every couple of years I use vinegar in the water heater tank to remove the sulfur smell.
Titus is offline   Reply With Quote
Old 05-23-2018, 10:57 AM   #12
2016 27' International
Larkspur , Colorado
We park ours at home in the garage. We turn everything off and leave the fridge doors open. I leave the screen door closed but open the door for ventilation. I have a reminder in my phone to plug in every two weeks for two days to top off the batteries. No problems with this system so far.
MHammy is offline   Reply With Quote
Old 05-23-2018, 04:55 PM   #13
2015 30' Classic
Saint Augustine , Florida
Storage electric
We have our 31-15 Classic parked off site(HOA rules), but it is in a large garage. I have power there and could run more, but just leave the battery disconnect on, so the batteries charge and I leave a small fan running in the galley with the galley window cracked open to keep the air moving in the coach. I do not run the fridge, but keep the doors cracked open so no odors are born and I keep one of the roof vents open; usually in the shower to help provide and air flow. The owner of the building told me I could run anything I want, such as fridge, A/C or whatever, but I think what I have running is sufficient and prudent.
accordionman is offline   Reply With Quote
Old 05-24-2018, 05:19 AM   #14
DudleyD
Victor , Idaho
Good stuff here thanks. Just picked up our 18 AI. Heading for a long weekend to test her out. What is BIM. BTW we just had 2 addl batteries installed and 1 addl solar panel up on top by AI in Jackson City. In our brief trip to bring it home we found it was not going to work well off the grid.
Dudley
Jdurossjr is offline   Reply With Quote
Parked Along the Westcoast of B.C.? Why It's a Good Idea to Keep Your TV Hitched Fly at Night On The Road... 1 01-23-2018 11:44 AM
HughesNet Gen 5, ZTE Mobley, etc., etc... Jaxon Electronics & Connectivity 1 09-12-2017 08:47 PM
To disconnect or not to disconnect urnmor Towing, Tow Vehicles & Hitches 36 02-22-2017 10:24 AM
Need some help w/ Main Disconnect and solar FlyFishinRVr Sprinter and B-van Forum 20 09-10-2016 04:49 PM
12V main disconnect Mifair 2011 - 2015 International 10 10-27-2011 10:36 PM
