Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Sprinter and B-van Forum
Old 05-24-2018, 04:20 PM   #21
Mansderm161's Avatar
NORTH MYRTLE BEACH , South Carolina
Check all the wheels on the screen...roll them completely around. Mine fell off in my hand the first time i used it becase a roller is chipped in 2 places
Mansderm161 is offline   Reply With Quote
Old 05-24-2018, 04:35 PM   #22
2018 Interstate Lounge Ext
LV , Nevada
Originally Posted by Jdurossjr View Post
Thanks I am hoping the technology these units doesn’t become a monster. I read these threads and they scare me to death. My wife is already saying if this isn’t fun it goes back[emoji30] screen door came off and I’ve worked on the adjustment for an hour to no avail.
Don't get too intimidated by the tech. A lot of us in the forum just like to vent, especially the former techies, because we have our own ideas of how things ought to be built. There WILL BE problems & bugs to fix. But that is true of any new stuff as complicated as an rv. The AI, although small compared to a 40 ft class A, still has the same systems installed, just in smaller scale. And both are just rolling small homes. If you have built a new home from scratch, it is a headache from start to finish. I keep saying I will never do it again, but we are on #4 . In spite of some start-up problems, we are having fun & enjoying our AI. I would do it all over again, anytime, especially knowing I have lots of helpful experience here.
Alex AVI is offline   Reply With Quote
Old 05-24-2018, 05:45 PM   #23
rowiebowie's Avatar
2012 Avenue Coach
Corpus Christi , Texas
It's frustrating when things break, but a motor home is a combination of a home & a vehicle and all the mechanical features that go with each. My AS Avenue is well out of warranty so I don't have to deal with that aspect.
The main problem is the RV dealers I've dealt with charge an hourly rate higher than most local plumbers, electricians, and mechanics and yet don't have much expertise in diagnosing/fixing problems. I've gotten pretty good at DIY repairs because, after all, I can't break something that's already broken.
rowiebowie is offline   Reply With Quote
Old 05-25-2018, 05:53 AM   #24
DudleyD
Victor , Idaho
Originally Posted by Pahaska View Post
The large refrigerator and freezer on the Grand Tour precludes overnighting without hookups on the installed batteries.
A GT has a 550 ohm resistor in the control circuit for the refrigerator. That, alone, runs the compressor at about 2750 rpm rather than the 2000 rpm of the Lounge. This resistor probably increases the amp-hours needed for the refrigerator by at least 50%. Add the amp-hours of the freezer, and you are using a lot of amp-hours for the two boxes.
My Lounge will just safely go overnight in hot weather. There is no way that a GT will do so without additional batteries, generator, or idling the engine.
I had AI install 2 addl batteries and solar pane but seems to have made no difference
We intend to use without hook up and am afraid we’ve made the wrong decision.
Jdurossjr is offline   Reply With Quote
Old 05-25-2018, 07:38 AM   #25
2017 Interstate Lounge Ext
Plano , Texas
I think you will want to look at that MPPT controller.
I felt very similar after the purchase thinking I miss understood the capabilities and really over sold the functionality to the wife. This forum has a ton a great people that have a lot of wisdom and guidance. Your AI might not be perfect today but it is a journey and it has the opportunity to be customized to different needs. Hang in there.
Tobbun is offline   Reply With Quote
Old 05-25-2018, 08:08 AM   #26
Prof. of Pending Projects
wachuko's Avatar
2018 Tommy Bahama Interstate
Orlando , Florida
You made the right decision... you just have some components that are working against you... BIM and Solar controller...
Change those and things should improve significantly...
I did mine... here is the link where I documented some of it:
http://www.airforums.com/forums/f240...ml#post2047788
And a photo of both items installed... Blue Sea ACR that replaced the BIM and the Victron that replaced the solar controller...
Blue Sea ML-ACR 7622
Victron SmartSolar 100/30 MPPT Solar Charge Controller (the Smart version is the newer one with built-in Bluetooth... go with that one).
Safe travels!
Wachuko
WBCCI #26769
2018 Airstream Interstate 3500 Lounge EXT Tommy Bahama w/ARS
wachuko is offline   Reply With Quote
Old 06-01-2018, 11:59 AM   #27
Sue 1235
2003 34' Classic
1994 34' Limited
2013 Interstate Coach
DADE CITY , FL
I would like to know where to go if I want to make these changes. Sorry but it is well past my DYI abilities. I boondock once a year at my granddaughters, they live off the grid so no power. Also I am interested in a caravan with boondocking stops. When i had an Airstream TT it had a full solar system and was great for off the grid.
Sue
2013 Interstate
WBCCI #1235
Sue Yeutter is offline   Reply With Quote
Old 06-01-2018, 12:58 PM   #28
wachuko's Avatar
Orlando , Florida
Contact Lew Farber (lewster in this forum)
https://www.solartechenergy.net
http://www.airforums.com/forums/memb...ter-10325.html
He is located in Naples, FL.
Safe travels!
Wachuko
WBCCI #26769
Old 06-01-2018, 12:59 PM   #29
Plano , Texas
What he said...
Old 06-03-2018, 10:25 AM   #30
RJC
Reston , Virginia
I read enough pages of the linked thread that my brain needed a rest but still not sure, in lay terms, what the net result of those two modifications are. It does seem based on what I'm reading that it is a high priority for anyone with unpredictable power access.
And to clarify, are people adding a 4th 100w solar panel to an AI that shipped with 300w, or a 2nd to one with 100w standard?
Reed
Finalizing my AI GT order!
RJC is offline   Reply With Quote
Old 06-03-2018, 12:58 PM   #31
LV , Nevada
Yes (some would argue for every AI), Yes, & Yes.
Parked Along the Westcoast of B.C.? Why It's a Good Idea to Keep Your TV Hitched Fly at Night On The Road... 1 01-23-2018 11:44 AM
HughesNet Gen 5, ZTE Mobley, etc., etc... Jaxon Electronics & Connectivity 1 09-12-2017 08:47 PM
To disconnect or not to disconnect urnmor Towing, Tow Vehicles & Hitches 36 02-22-2017 10:24 AM
Need some help w/ Main Disconnect and solar FlyFishinRVr Sprinter and B-van Forum 20 09-10-2016 04:49 PM
12V main disconnect Mifair 2011 - 2015 International 10 10-27-2011 10:36 PM
