Old 08-11-2015, 09:42 PM   #1
k9jackie's Avatar
2015 Interstate Ext. Coach
Great Falls , Virginia
AI Ext Sofa bed bar broken
This weekend, while on a trip to Canada, the slide out bar came off from underneath the sofa bed. I slept without it on my last day and everything seemed fine. What exactly does it do besides hold the fold down extended pieces? Do I really need it if I don't need the additional length?
2014.5 Airstream Interstate Ext.
k9jackie is offline   Reply With Quote
Old 08-11-2015, 10:04 PM   #2
73shark's Avatar
2011 Interstate Coach
Overland Park , Kansas
Having never seen one except in brochure pics, I'd say you don't need it if you aren't using the fold down extension. And if you're not using them, you could remove them and gain some space and less weight.
Old 08-12-2015, 01:40 AM   #3
UKDUDE's Avatar
2014 Interstate Ext. Coach
Sedona , Arizona
It's just a support for the fold down extension for the bed for anyone who needs a bed longer than 6'2". More to go wrong in my opinion.
Old 08-12-2015, 01:46 PM   #4
Boxster1971's Avatar
2013 Interstate Coach
Fulton , Maryland
Jackie - as others have pointed out you don't need that slide out bar unless you use the two fold down bed extensions. Since I don't need the bed extensions I removed both the slide bar and fold downs to give me more rear area storage
- - Mike
2013 Interstate Lounge EXT on 2012 Sprinter
- - Mike
Old 08-12-2015, 03:36 PM   #5
k9jackie's Avatar
Well, I'm considering selling my AI next year. And getting a class A. If this fix is covered under the warranty, I should probably just get it repaired but thanks for the info. Glad to know it is not important.
Old 08-19-2015, 10:14 AM   #6
lamato's Avatar
Sacramento , California
- - Mike
Hi Mike. We also have a 2013 extended, and we're thinking of removing the bar to gain a little more storage under the bed. How big of a process is it to remove the bar? We are not exactly the mechanical types!
lamato is offline   Reply With Quote
Old 08-19-2015, 12:56 PM   #7
Fulton , Maryland
If I recall it is just held in by pop rivets. They can be drilled out, but take some effort as they are steel rivets. I then also removed the side fold down bed extensions as they are just held in place by a few screws into the side paneling.
- - Mike
2013 Lounge EXT on 2012 Sprinter
- - Mike
Old 08-19-2015, 04:36 PM   #8
Rockwell , North Carolina
I removed mine when I eliminated the side fold down extensions. Since they could not be used when I installed my two vertical cabinets that go from the floor to the rear overhead cabinet, I removed the small netted storage areas on each side. This gave me more room to store tall items between the extra cabinets and the outside wall like an ironing board, drying clothes rack, umbrella's, brooms, etc.
By the way, after using the cabinets this year on our trips, installing these cabinets are, by far, the best modification that I have made to the AI. They dramatically increased the storage area behind the seats.
jerhofer is offline   Reply With Quote
Old 08-19-2015, 06:56 PM   #9
lamato's Avatar
Thanks for your input. Was the sliding bar difficult to remove? Was it installed using screws or rivets as mentioned by Mike?
Old 08-19-2015, 07:14 PM   #10
It was fastened with rivets. Easily drilled out. Only took a few minutes.
Old 08-19-2015, 10:02 PM   #11
kaylorsan's Avatar
2012 Interstate Coach
Los Gatos , California
Mine broke, however I replaced it with more durable sliding rails. For us, the primary purpose of use is to store our collapsible camp chairs, fire tools, etc. We basically treat it a a pullout shell. Never use it to support the bed fold down arms.
2012 Interstate EXT
kaylorsan is offline   Reply With Quote
Old 09-02-2015, 12:55 PM   #12
Correction!!!
The track for the bar is held in by rivets. And I thought I remembered drilling out the rivets, but I didn't. That bar works just like a cabinet drawer. If you push in on the releases on each side, the bar will slide off the track. I then used a couple zip ties to keep the track from sliding in and out.
Old 09-10-2015, 05:02 AM   #13
k9jackie's Avatar
I went to Colonial yesterday and the awesome repair crew fixed it on warranty. Apparently this happens a lot.
Old 09-20-2015, 08:37 PM   #14
lamato's Avatar
Correction!!!
Thanks for the picture, Jerhofer! It doesn't look complicated after all. We made it on this trip with the bar, but it is nice to know that it is easily removed.
Laura and Vince
Sofa bed, dinette/bed, swivel chairs and fold out table Don Landis Argosy Motorhomes 9 09-07-2011 06:56 PM
Sofa bed, dinette/bed, swivel chairs and fold out table Don Landis General Interior Topics 0 04-21-2009 01:18 AM
Bed vs. Sofa Bed ardenrj General Interior Topics 4 03-20-2007 08:56 PM
Torsion Bar vs Sway Bar acrane Hitches, Couplers & Balls 9 07-31-2006 06:11 AM
