Old 10-14-2014, 07:54 PM   #29
PSchw's Avatar
2005 39' Skydeck 390 SD
Livingston , Texas
No they did not tell me and I was a little flabbergasted by the invoice the presented to me. They made it look like a good deal 1/2 of the alignment.
I did complained about it that I had this wear with 10k and was told it is the tire. I had to change the tires on the road because of the dangers condition. Now they install special bolts I am still under 36k miles and they want me to pay for the alignment?
I have Konis for the front and will install them then it needs to be alignment again the I make sure it will be 0 to +1.
Peter
PSchw is offline   Reply With Quote
Old 10-14-2014, 10:48 PM   #30
Boxster1971's Avatar
2013 Interstate Coach
Fulton , Maryland
Originally Posted by 73shark View Post
What's a set of the special camber bolts cost?
Checked my invoice -- bolts were $30 for a pair. The alignment was $125.
- - Mike
Old 10-15-2014, 02:54 AM   #31
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Front end alignments are not warranty repairs; they're routine maintenance.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 10-15-2014, 05:49 AM   #32
r carl's Avatar
Lin , Ne
Unless it came from the dealer outside of factory alignment specs.
Old 10-15-2014, 05:53 AM   #33
Unfortunately, since it came to you through an upfitter (Airstream) and not direct from MB, that's hard to prove, unless you had a front-end alignment done right after you bought it.
WBCCI #1105
TAC LA-4
Old 10-15-2014, 07:25 AM   #34
CapriRacer
CapriRacer's Avatar
I'm in the , US
Originally Posted by gambita View Post
Thanks to all, I will mention this tips to the service manager when I bring her on oct 13th
An update would be very helpful for future learning.
CapriRacer is offline   Reply With Quote
Old 10-15-2014, 08:11 AM   #35
r carl's Avatar
Lin , Ne
Remember, front end alignments don't change unless some part wears or gets bent.
Old 10-15-2014, 08:14 AM   #36
You obviously haven't driven in New Orleans lately. Potholes and bumps can shake things loose just from the vibration, even if there's no excessive wear or bent parts. smacking a curb too hard can do it, too.
WBCCI #1105
TAC LA-4
Old 10-15-2014, 08:56 AM   #37
Ron_CA's Avatar
2015 Interstate Ext. Coach
San Diego , California
Seems to me if the outside of the tires are wearing then either the tires are towed in a bit or the alignment has overcompensated for the additional weight.
Ron_CA is offline   Reply With Quote
Old 10-15-2014, 09:03 AM   #38
r carl's Avatar
Lin , Ne
Oh well, that's just what they told me at the Bee Line's frame and alignment correction school back in 1986.
Training | Course Overview | Bee Line
Old 10-15-2014, 09:10 AM   #39
When I lived in Oklahoma, I thought the same as Bee Line. I guess that just shows how bad New Orleans streets really are, that they're an exception. Every vehicle I've owned in New Orleans (except my Interstate, which gets 98% of its mileage outside the city) has needed a front end alignment twice a year, every year because not a danged one of them has been able to maintain its alignment for a full 12 months.
WBCCI #1105
TAC LA-4
Old 10-15-2014, 09:51 AM   #40
gambita's Avatar
Framingham , Massachusetts
Update: So I brought Interstate on 10/13/14 at the dealer .
Technician test drove it and confirm vibration and wiggle. He balanced tire, not sure if he did road force balance but did ni solve problem.
I ended up leaving the airstream at the dealer for further testing. They ordered new tire. As of now no updates/call from the service manager.
gambita is offline   Reply With Quote
Old 10-15-2014, 09:57 AM   #41
73shark's Avatar
2011 Interstate Coach
Overland Park , Kansas
GM will do one alignment within the first 7,000 miles for original owner.
Old 10-15-2014, 09:57 AM   #42
Zil
egg harbor city , South Jersey
Bouncing curbs and potholes does "bend" stuff, if only the rubber bushings in the control arms and strut rods. Bee Line is a good franchise.
Zil is offline   Reply With Quote
2015 MOUNTAIN AIR Rally April 17-20 2015 shermantic Forum Rallies & Meet Ups 2 01-13-2015 08:43 AM
AI steering vibration at over 60 mph tishaeisha Sprinter and B-van Forum 32 06-19-2014 07:24 PM
Steering Wheel replacement rvlover Classic Motorhomes 19 09-21-2008 08:17 AM
2 speed wiper switch has no low speed rdm Mechanics Corner - Engines, Transmission & More... 6 01-09-2003 09:47 PM
GM option--4 wheel steering Kistler Our Community 4 01-08-2003 03:30 AM
